ERA.1S.306.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
1S
Termination type
Female solder
IP rating
50
AWG wire size
32.00 - 24.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FFA.1S.306.CLAC42
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
ERA*: Fixed receptacle, nut fixing
Keying
Hermaphroditic keying (half moon insert) with female pin 1
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
8.73 g
Performance
Configuration
1S.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
7 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.7 mm (0.028in)
Bucket Dia.: 0.6 mm (0.024in)
Max. Solid Conductor: 0.25 mm^2 (AWG 24)
Max. Stranded Conductor: 0.14 mm^2 (AWG 26)
R (max): 6.1 mOhm
Vtest: 1500 V (AC), 2100 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000 mating cycles
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
S1
S3
e
mm.
14
16
7.5
21
1.5
10.5
14
M12x1.0
in.
0,55
0,63
0,30
0,83
0,06
0,41
0,55
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.1S.M12.4
2/3
Cables
CMN.06.T26.037QGZE
TPR (medical)
Grey
CMN.06.T28.031PGCE
PVC
GREY
CMN.06.T28.031PGZE
CMN.06.T28.031PNCE
Grey
PVC
Black
CMN.06.T28.031PNZE
CMN.06.T28.042QBCE
TPR (medical)
CMN.06.T28.044PGZE
Grey
CMN.06.T28.044PNZE
106240
PTFE
White
12080
PVC
Grey
160140
PVC
Grey
160260
PVC
Black
260250
PVC
Grey
60260
PTFE
White
6280
PVC
Black
3/3
很抱歉,暂时无法提供与“ERA.1S.306.CLL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+371.115201+48.03700
- 10+315.4238510+40.82833
- 30+291.9040830+37.78394
- 50+281.5793150+36.44751
- 100+268.15216100+34.70951
- 250+251.38548250+32.53923
