EGG.1B.308.CYM
EGG.1B.308.CYM
    LEMO(雷莫)
    EGG.1B.308.CYM
EGG.1B.308.CYM 数据手册
EGG.1B.308.CYM www.lemo.com SUMMARY # Wires Low voltage 8 Image is for illustrative purpose only Series 1B Termination type Female crimp IP rating 50 AWG wire size 26.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.1B.308.CYCD72Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EG*: Fixed receptacle, nut fixing Keying No keying Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 10.11 g Performance Configuration 1B.308 : 8 Low Voltage Insulator Y: PEEK for crimp contacts Rated Current 5 Amps Specifications Contact Type: Crimp Contact Retention: 22 N Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Min. Conductor: 0.14 mm^2 (AWG 26) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1300 V (AC), 1840 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Vtest (contact-contact): 1300 V (AC), 1840 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 14 16 7.5 23 1.5 21.1 10.5 14 M12x1.0 in. 0,55 0,63 0,30 0,91 0,06 0,83 0,41 0,55 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Crimp Tool: DPC.91.701.V Crimp settings: AWG/Selector = 22-24-26/6-5-5 Positionner: DCE.91.071.BVM Extractor: DCC.07.04B.LAG Replacement contact: EGG.1B.655.ZZM Cables CMN.08.T22.059QGC TPR Grey CMN.08.T22.059QGZE TPR (medical) Grey CMN.08.T26.042QGZE TPR (medical) Grey 108220 PVC Black 108240 PTFE White 108260 PTFE White 16080 PVC Grey 180240 PVC Black 180260 PVC Black 280250 PVC Grey 335990 PVC Black 335991 PVC Black 42265 PVC Yellow 80140 PVC Grey 8050 PVC Black 8280 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EGG.1B.308.CYM
1. 物料型号:EGG.1B.308.CYM,属于LEMO的B系列室内键控连接器。 2. 器件简介:该连接器具有8个低电压接触点,适用于26-22 AWG线规,具有推拉式锁定系统,固定面板前安装插座/插座。 3. 引脚分配:文档中提到“1B.308 - 8 Low Voltage”,表示有8个低电压接触点,4个高速差分对。 4. 参数特性: - 接触终止:压接 - 最大电阻:6.1毫欧 - 额定电流:5A - 接触-接触电压测试:1300V(AC)/1840V(DC) - 接触-外壳电压测试:1300V(AC)/1840V(DC) - 接触保持力:22N - 最大导体尺寸:0.34 mm²(AWG 22) - 最小导体尺寸:0.14 mm²(AWG 26) - 桶直径:0.8 mm - 接触直径:0.7 mm 5. 功能详解:该连接器适用于音视频、能源工业、医疗、半导体、特殊用途、测试测量、交通、航空航天和无人机等多个技术领域。 6. 应用信息:环境密封等级为IP50,温度范围为-55°C至+250°C,气候类别为50/175/21,湿度最大为95%(在60°C/140°F时),屏蔽效能最小为75 dB(10 MHz)和40dB(1 GHz),耐冲击100 g [6 ms],耐振动15 g[10 Hz - 2000 Hz],耐盐雾腐蚀超过1000小时。 7. 封装信息:外壳材料为黄铜(镀铬[SAE AMS 2460]),壳体和卡箍螺母,锁紧套和中间件为镍镀铬[SAE AMS QQ N 290]黄铜,重量为10.11克。
EGG.1B.308.CYM 价格&库存
很抱歉,暂时无法提供与“EGG.1B.308.CYM”相匹配的价格&库存,您可以联系我们找货
EGG.1B.308.CYM
  • 1+447.152911+57.84606
EGG.1B.308.CYM
    • 1+221.959721+28.44042
    库存:243
