EYG.1B.306.CLN
www.lemo.com
SUMMARY
# Wires
Low voltage
6
Image is for illustrative purpose only
Series
1B
Termination type
Female print PCB
IP rating
50
AWG wire size
0.00 - 0.00
PCB Altium Pattern
Cable Ø
0.00 - 0.00 mm
PCB KiCad Pattern
Status
active
Catalog
Matching parts
FGG.1B.306.CLAD42Z
Download
Request a quote
PCB Eagle Pattern
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EY*: Fixed receptacle for printed circuit, nut fixing (back panel mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
12.37 g
Performance
Configuration
1B.306 : 6 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
7 Amps
Specifications
Contact Type: Print (straight)
Contact Dia.: 0.7 mm (0.028in)
R (max): 6.1 mOhm
Vtest (contact-shell): 1200 V (AC), 1700 V (DC)
Vtest (contact-contact): 1050 V (AC), 1490 V (DC)
Others
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
12NC part number: 4022.438.73760
DRAWINGS
Dimensions
A
B
C
D
E
M
N
P
e
mm.
14
12
16
7.62
5
3.5
19
10
M11x0.5
in.
0,55
0,47
0,63
0,30
0,20
0,14
0,75
0,39
RECOMMENDED BY LEMO
Tools
Spanner wrench:
Socket for torque wrench DCM.1S.M11.4
2/3
3/3
很抱歉,暂时无法提供与“EYG.1B.306.CLN”相匹配的价格&库存,您可以联系我们找货
