ERA.2S.310.CLL
ERA.2S.310.CLL
    LEMO(雷莫)
    ERA.2S.310.CLL
ERA.2S.310.CLL 数据手册
ERA.2S.310.CLL www.lemo.com SUMMARY # Wires Low voltage 10 Image is for illustrative purpose only Series 2S Termination type Female solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FFA.2S.310.CLAC52 Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model ERA*: Fixed receptacle, nut fixing Keying Hermaphroditic keying (half moon insert) with female pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 13.95 g Performance Configuration 2S.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 7 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.0354in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest: 800 V (AC), 1200 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M S1 S3 e mm. 18 19.6 8.5 24.5 1.8 13.5 17 M15x1.0 in. 0,71 0,77 0,33 0,96 0,07 0,53 0,67 RECOMMENDED BY LEMO Tools Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 CMN.10.T22.068QGZE TPR (medical) CMN.10.T28.052PGZE Grey Grey CMN.10.T28.052PNZE CMN.10.T28.053QGZE TPR (medical) Grey 110220 PVC Black 110240 PTFE White 110260 PTFE White 110280 PVC Black 210140 PVC Grey 210240 PVC Black 210250 PVC Grey 210260 PVC Black LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ERA.2S.310.CLL 价格&库存
很抱歉,暂时无法提供与“ERA.2S.310.CLL”相匹配的价格&库存,您可以联系我们找货
