ECG.2B.310.CLL
www.lemo.com
SUMMARY
# Wires
Low voltage
10
Image is for illustrative purpose only
Series
2B
Termination type
Female solder
IP rating
50
AWG wire size
30.00 - 22.00
Cable Ø
0.00 - 0.00 mm
Status
active
Matching parts
FGG.2B.310.CLAD62Z
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
EC*: Fixed receptacle with two nuts (back panel mounting)
Keying
1 key (alpha=0, plug: male contacts, receptacle: female contacts)
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
17.31 g
Performance
Configuration
2B.310 : 10 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
8 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 4.8 mOhm
Vtest (contact-shell): 1300 V (AC), 1840 V (DC)
Vtest (contact-contact): 1450 V (AC), 2050 V (DC)
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Others
Endurance (Shell): 5000
Temp (min / max): -55°C / +250°C
Humidity (max): 1000 hr
DRAWINGS
Dimensions
A
B
E
L
M
N
S1
S3
e
mm.
6.5
26.7
3.5
24.6
13.5
17
M15x1.0
in.
0,79
0,76
0,26
1,05
0,14
0,97
0,53
0,67
RECOMMENDED BY LEMO
Tools
Spanner 2:
DCH.91.201.PA
Spanner wrench:
Socket for torque wrench DCM.65.170.AZ and DCM.2S.M15.6
2/3
Cables
CMN.10.T22.068QGZE
TPR (medical)
CMN.10.T28.052PGZE
Grey
Grey
CMN.10.T28.052PNZE
CMN.10.T28.053QGZE
TPR (medical)
Grey
110220
PVC
Black
110240
PTFE
White
110260
PTFE
White
110280
PVC
Black
210140
PVC
Grey
210240
PVC
Black
210250
PVC
Grey
210260
PVC
Black
3/3
很抱歉,暂时无法提供与“ECG.2B.310.CLL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+464.389621+59.50374
