ECG.2B.316.CLL
ECG.2B.316.CLL
    LEMO(雷莫)
    ECG.2B.316.CLL
ECG.2B.316.CLL 数据手册
ECG.2B.316.CLL www.lemo.com SUMMARY # Wires Low voltage 16 Image is for illustrative purpose only Series 2B Termination type Female solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 0.00 - 0.00 mm Status active Matching parts FGG.2B.316.CLAD42Z Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model EC*: Fixed receptacle with two nuts (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 17.49 g Performance Configuration 2B.316 : 16 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 6 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) Max. Stranded Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1250 V (AC), 1770 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E L M N S1 S3 e mm. 20 19.2 6.5 26.7 3.5 24.6 13.5 17 M15x1.0 in. 0,79 0,76 0,26 1,05 0,14 0,97 0,53 0,67 RECOMMENDED BY LEMO Tools Spanner 2: DCH.91.201.PA Spanner wrench: Socket for torque wrench DCM.65.170.AZ and DCM.2S.M15.6 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.16.T22.076QGZE TPR (medical) CMN.16.T28.059PGZE Grey Grey CMN.16.T28.059PNZE CMN.16.T28.070NNZZ CMN.16.T30.047QGZE TPR (medical) Grey 116080 PUR Black 116280 PVC Black 16050 PVC Black 216220 PVC Black 216240 PVC Black 216260 PVC Black 316250 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ECG.2B.316.CLL 价格&库存
很抱歉,暂时无法提供与“ECG.2B.316.CLL”相匹配的价格&库存,您可以联系我们找货
