SDF-30J
SDF-30J
    CUIDEVICES
    CONN DIN 3POS FEMALE SHIELDED
SDF-30J 数据手册
Additional Resources: Product Page | PCB Footprint date 08/05/2022 page 1 of 9 SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR FEATURES • PCB mount • front shielded • right angle PART NUMBER KEY SDF - XX J Base Number Pin Options 30 = 3 pins* 40 = 4 pins 50 = 5 pins, 180 degrees 60 = 6 pins 70 = 7 pins* 80 = 8 pins 130 = 13 pins * Discontinued models SDF-30J & SDF-70J. SPECIFICATIONS parameter conditions/description min max 100 24 rated input voltage rated input current typ at 100 Vac at 24 Vdc contact resistance insulation resistance at 500 Vdc voltage withstand for 1 minute Vac Vdc 2 1 A A 20 mΩ 500 Vac 6.5 kg 5.0 kg 100 MΩ insertion force withdrawal force 1 operating temperature -40 life 85 1,000 flammability rating UL94V-0 RoHS yes units °C cycles SOLDERABILITY parameter conditions/description wave soldering for 10 seconds max hand soldering for 5±1 seconds cuidevices.com min typ 240 245 max units 260 °C 250 °C Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 2 of 9 MECHANICAL DRAWING (SDF-30J) units: mm tolerance: ±0.3 mm ITEM DESCRIPTION MATERIAL PLATING/COLOR 1 body PBT (UL94V-0) black nickel 2 shielded terminal brass 3 plate bakelite 4 terminals brass 14.8 0.583 20.7 0.815 2.2 0.087 7.0 0.276 1.6 0.063 (2 PLCS) 21.4 0.843 1 3 10.0 0.394 2 1.85 0.073 (2 PLCS) 18.4 0.724 6.0 0.236 6.5 0.256 2.7 0.106 (2 PLCS) 1.0 0.039 (2 PLCS) 5.0 0.197 5.0 0.197 14.7 0.579 1.3 0.051 (5 PLCS) 15.0 0.591 3 5.0 0.197 (2 PLCS) 2 1.0 0.039 (3 PCLS) 10.0 0.394 15.0 0.591 2.4 0.094 (2 PLCS) 3.5 0.138 (TYP) 2.7 0.106 1 10.0 0.394 (3 PLCS) 5.0 0.197 Mounting Hole (2 PLCS) Recommended PCB Layout Top View cuidevices.com tin Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 3 of 9 MECHANICAL DRAWING (SDF-40J) units: mm tolerance: ±0.3 mm unless otherwise noted ITEM DESCRIPTION MATERIAL PLATING/COLOR 1 body PBT (UL94V-0) black nickel 2 shield terminal brass 3 plate bakelite 4 contact brass tin         4 3     2 1 E Recommended PCB Layout Top View (Date Codes prior to 03/03/2022) E Recommended PCB Layout Top View (Date Codes after 03/03/2022) cuidevices.com Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 4 of 9 MECHANICAL DRAWING (SDF-50J) units: mm tolerance: ±0.3 mm unless otherwise noted ITEM DESCRIPTION MATERIAL PLATING/COLOR 1 body PBT (UL94V-0) black nickel 2 earth terminal brass 3 plate bakelite 4 contact brass tin 1 3 2 3 1 5 2 4 4 4 5 3 2 5 1 3 Recommended PCB Layout Top View (Date Codes prior to 03/03/2022) 4 2 1 Recommended PCB Layout Top View (Date Codes after 03/03/2022) cuidevices.com Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 5 of 9 MECHANICAL DRAWING (SDF-60J) units: mm tolerance: ±0.3 mm unless otherwise noted ITEM  DESCRIPTION MATERIAL PLATING/COLOR 1 body PBT (UL94V-0) black nickel 2 earth terminal brass 3 plate bakelite 4 contact brass tin        6 4 5  2 3     1 ( Recommended PCB Layout Top View (Date Codes prior to 03/03/2022) ( Recommended PCB Layout Top View (Date Codes after 03/03/2022) cuidevices.com Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 6 of 9 MECHANICAL DRAWING (SDF-70J) units: mm tolerance: ±0.2mm 20.7 0.815 7.0 0.276 MATERIAL PLATING housing PBT black shielded terminal brass nickel terminal brass tin 18.8 0.740 2.2 0.087 45° 7 6 3 21.4 0.843 1 4 5 10.0 0.394 2 1.85 0.073 (2 PLCS) 19.5 0.768 6.0 0.236 45° 6.5 0.256 2.70 0.106 (2 PLCS) 1.6 0.063 (2 PLCS) 1.0 0.039 (2 PLCS) 5.0 0.197 10.0 0.394 1.0 0.039 (7 PLCS) 12.5 0.492 15.0 0.591 2.40 0.094 (2 PLCS) 5.0 0.197 10.0 0.394 14.70 0.579 1.30 0.051 (9 PLCS) 3.5 0.138 (TYP) 2.7 0.106 15.0 0.591 Mounting Hole (2 PLCS) 10.0 0.394 7 5 3 10.0 0.394 (3 PLCS) 2 4 6 1 12.5 0.492 (4 PLCS) 5.0 0.197 (2 PLCS) 5.00 0.197 Recommended PCB Layout Top View cuidevices.com Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 7 of 9 MECHANICAL DRAWING (SDF-80J) units: mm tolerance: ±0.3 mm unless otherwise noted ITEM  DESCRIPTION MATERIAL PLATING/COLOR 1 body PBT (UL94V-0) black 2 shield terminal brass nickel 3 cover PBT (UL94V-0) black 4 contact brass tin             ( Recommended PCB Layout Top View (Date Codes prior to 03/03/2022)    ( Recommended PCB Layout Top View (Date Codes after 03/03/2022) cuidevices.com Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 8 of 9 MECHANICAL DRAWING (SDF-130J) units: mm tolerance: ±0.30 mm PCB: ±0.05 mm MATERIAL PLATING 1 terminal phosphor bronze silver 2 ground contact phosphor bronze silver 3 housing PBT 4815 UL94V-0 black 4 cover PBT 4815 UL94V-0 black 5 sealed plate copper alloy copper/tin Recommended PCB Layout Top View cuidevices.com Additional Resources: Product Page | PCB Footprint CUI DEVICES | SERIES: SDF-J | DESCRIPTION: STANDARD DIN CONNECTOR date 08/05/2022 | page 9 of 9 REVISION HISTORY rev. description date 1.0 initial release 02/23/2006 1.01 new template applied 04/02/2012 1.02 updated housings 04/05/2012 1.03 corrected SDF-50J and SDF-51J pinouts 07/15/2014 1.04 updated datasheet 09/08/2017 1.05 updated datasheet 07/24/2018 1.06 discontinued model SDF-30J 10/08/2019 1.07 discontinued model SDF-70J 02/17/2020 1.08 changed housing 04/13/2020 1.09 modified design and changed factory for SDF-40J, SDF-50J, SDF-60J, & SDF80J 02/21/2022 logo, datasheet style update 08/05/2022 1.10 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
SDF-30J 价格&库存
很抱歉,暂时无法提供与“SDF-30J”相匹配的价格&库存,您可以联系我们找货
