8
7
6
5
4
3
2
2
3
2
3
2-#20
3
1
4
1
3-#20
4
1
4-#22
4
3
2 5
5
1
F
4
2
1
6
5-#26
SPECIFICATIONS:
3
2 5
MECHANICAL
Life:600 cycles minimum
Vibration: Mil-Std 202G Method 201A
Hex Nut Tongue: 5-6 in-lb
2
6
6-#26
7
7-#26
1
Feed the free end of cable through the handle, cable-clamp/grommet, and coupling ring
in the order shown.
E
0.375 MAX
9.5
Strip cable end and conductors as shown.
CABLE-CLAMP
HANDLE
D
GROMMET
(INSIDE)
CABLE
Connector Type:
C - Cord
P - Panel*
L - In-Line**
Packaging Options:
Leave blank for Bulk
K - Kit (one unit/bag)
# of Contacts:
2-3 for #20
4 for #22
5-7 for #26
EN2 CORD
CONNECTOR
CRIMP OR SOLDER
ENVIRONMENTAL
Operating Temperature Limits:-40ºC to +85ºC (-40ºF to +185°F),
see Current Rating Table.
Moisture Resistance: Mil-Std 202G Method 106G
Insulation Resistance: Mil-Std 202G Method 302
Thermal Shock: Mil-Std 202G Method 107G
Salt Atmosphere (Corrosion): Mil-Std 202G Method 101E
Wearthetight Ratings:
IP16, IP18, IP66, IP67, IP68 per IEC60529
NEMA 250 (6P), CFR 46 Part 110.20
PART NUMBER SCHEME:
EN2
0.188±0.015
4.8±0.4
COUPLING RING
Coupling Ring option:
Leave blank for Ribbed
W - Winged
Gender:
M - Male
F - Female
Grommet Code - Cable O.D. Range:
DC - Daisy Chain (all 3 sizes)
G1 - 0.100-0.140 (2.5-3.6)
G2 - 0.140-0.180 (3.6-4.6)
G3 - 0.180-0.220 (4.6-5.6)
Soldering or crimping conductors to contacts is recommended before insertion into connector.
If crimping, use hand or pneumatic crimp tool with crimp positioner per contact size.
If soldering after contacts are inserted in the connector, limit exposure of contacts to soldering iron
temperature to 4 sec. maximum. Soldering iron temperature should not exceed 650°F (343°C).
Contacts
2 #20
3 #20
Insert wired contacts into connector housing using an insertion tool and per contacts arrangements.
4 #22
5-7 #26
C
E
MATERIAL
Connector Housing ----- Thermoplastic, black
Hex Nut: ------------------- Thermoplastic, black
Coupling Ring ------------ Thermoplastic, black
Cable Clamp -------------- Thermoplastic, black
Handle (back-shell) ----- Thermoplastic, black
Insulator ------------------- Elastomer, black
Seal Grommet ----------- Elastomer, black
Contacts ------------------- Copper Alloy, plated
Contact Size:
Contact Style:
20 - #20
Leave blank for Solder or Crimp
22 - #22
P - PC tail (Panel connectors only)
26 - #26
* for mating Panel-mount connectors refer to EN2P SERIES drawing.
** Mating In-Line connectors not currently available.
CONTACTS
F
ELECTRICAL
Voltage Rating: 250 V AC/DC for 2 contact arrangement
125 V AC/DC for 3-7 contact arrangements
Insulation Resistance: 1000 MΩ minimum
Contact Resistance: 10 mΩ maximum
Current Rating: Refer to Current Rating Table
CONTACT ARRANGEMENTS
CORD CONNECTOR REAR (WIRING SIDE) VIEW
EN2 CORD CONNECTOR FIELD ASSEMBLY INSTRUCTIONS:
1
Wire
(awg)
24
26
24
26
24
26
26
28
30
Current Rating (A)
at Operating Temperature (°C)
45°C max. 55°C max. 65°C max. 75°C max. 85°C max.
7
6
5
4
3.5
5.5
5
4
3
2.5
5.5
5
4
3
2.5
4
3.5
2.5
2
1
6.5
5.5
4.5
3.5
2
5
4.5
3.5
3
1.5
5
4.5
3.5
3
1.5
3
2.5
2
1.5
0.5
5
4.5
3.5
3
1.5
4.5
4
3
2
1
4.5
4
3
2
1
3
2.5
2
1.5
0.5
3
2.5
2
1.5
1
2.5
2
1.5
1
0.5
2
1.5
1
0.5
0.5
D
C
Align coupling ring over housing and bring forward.
Align cable-clamp/grommet on the rear of housing. Make certain grommet is completely inside
the cable-clamp in the final position.
1.50 - 1.57
[38 - 40]
Bring forward and thread handle onto housing until tight. Do not exceed 2 in-lb torque.
B
PIN CONTACTS
(MALE)
0.94
23.8
B
0.16 [4.1] TYP
0.11 [2.8] FOR 5-7
#26 CONTACTS
0.53
13.5
TYPICAL CORD CONNECTOR
WITH RIBBED COUPLING RING
TOOL
TOOL TYPE
EN3CR
A
HAND CRIMP TOOL
EN3CRAUTO
PNEUMATIC CRIMP TOOL
HAND CRIMP TOOL
LARGE FRAME
EN2CRL
EN2CRAUTOL
LARGE FRAME
EN3INS20
EN3INS26
CONTACT
INSERTION/EXTRUCTION
8
SOCKET CONTACTS
(FEMALE)
0.70
17.8
WITH WINGED COUPLING RING
POSITIONER
CONTACT SIZE
WIRE SIZES
EN2POS20
EN3POS26
EN2POS20
EN3POS26
20 and 22
26
20 and 22
26
20 and 22 AWG
26, 28, and 30 AWG
20 and 22 AWG
26, 28, and 30 AWG
EN2POS20L
20 and 22
20, 22, 24, and 26 AWG
7
0.90
22.8
20 and 22
26
ALL DIMENSIONS FOR REFERENCE ONLY
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
WIDTH
MULT
- TWO PLACE DECIMALS
0.02
- THREE PLACE DECIMALS
0.005
09/20/12 PNK
SRC
TOOLS REVISED
05/14/12 PNK
DATE DRAWN
BY
CHKD
APVD
0A
PRELIMINARY
02/08/12 PNK
02/08/12
PNK
PNK
02/08/12
SRC
02/08/12
REV
ECO NUMBER
4
APVD
1.5:1
NAME
DO NOT SCALE DRAWING
SolidWorks CAD File
A
SPEC No.
SPECS UPDATED
BY
TEMPER
SCALE
0B
DATE
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
0C
REVISIONS
5
SIZE
FINISH
1. ALL DIMENSIONS IN INCHES
6
CUSTOMER DRAWING
EN2C SERIES CONNECTORS, RoHS
C
SHEET
PART No.
1
OF
EN2C SERIES
1
REV
0C
很抱歉,暂时无法提供与“EN2C4F22G2”相匹配的价格&库存,您可以联系我们找货
