DESCRIPTION: M12 MALE - BOARD MOUNT - 5 POS.
SPECIFICATIONS:
MATERIALS:
HOUSING:
CONTACTS:
PBT, UL94 V-0, BLACK
GOLD PLATED BRASS
(SEE P/N KEY BELOW)
(SEE P/N KEY BELOW)
(SEE P/N KEY BELOW)
NUT:
SHELL:
ORING:
EPDM & NBR
ELECTRICAL:
RATED CURRENT:
RATED VOLTAGE:
INSULATION RESISTANCE:
CONTACT RESISTANCE:
100 MOhms MIN.
10 mOhms MAX.
ENVIRONMENT:
OPERATING TEMPERATURE:
WATER PROOF:
-40°C TO +85°C
IP67
4A
60V
860-005-113R00Y
Full stainless steel variant successfully passes
96-hour salt spray testing per ASTM B117
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = inch [mm]
DRAWN:
M. SIGMON
DATE:
03/07/2016
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
1
860-005-113R00Y
5
很抱歉,暂时无法提供与“860-005-113R004”相匹配的价格&库存,您可以联系我们找货
