860-005-213R004
860-005-213R004
    NORCOMP
    860-005-213R004
860-005-213R004 数据手册
DESCRIPTION: M12 FEMALE - PANEL MOUNT (REAR) - 5 POS. SPECIFICATIONS: MATERIALS: HOUSING: CONTACTS: PBT, UL94 V-0, BLACK GOLD PLATED BRASS (SEE P/N KEY BELOW) (SEE P/N KEY BELOW) (SEE P/N KEY BELOW) EPDM, BLACK NUT: SHELL: ORING: ELECTRICAL: RATED CURRENT: RATED VOLTAGE: INSULATION RESISTANCE: CONTACT RESISTANCE: 100 MOhms MIN. 10 mOhms MAX. ENVIRONMENT: OPERATING TEMPERATURE: WATER PROOF: -40°C TO +85°C IP67 4A 60V 860-005-213R00Y Full stainless steel variant successfully passes 96-hour salt spray testing per ASTM B117 RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inch [mm] DRAWN: M. SIGMON DATE: 03/07/2016 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 1 860-005-213R00Y 5
860-005-213R004 价格&库存
很抱歉,暂时无法提供与“860-005-213R004”相匹配的价格&库存,您可以联系我们找货
860-005-213R004
    860-005-213R004
