FTSH-110-01-L-DH
FTSH-110-01-L-DH
    SAMTEC(申泰)
    SMD,P=1.27mm,卧贴
    特性:绝缘体材料:黑色液晶聚合物。端子材料:磷青铜。镀层:50 μin(1.27 μm)镍上镀锡或金。额定电流(FTSH/CLP):每引脚3.4 A(2引脚供电)。工作温度范围:-55°C至+125°...
FTSH-110-01-L-DH 数据手册
REVISION BV DO NOT SCALE FROM THIS PRINT PATENT NUMBERS No OF POSITIONS THRU -50 5713755 / 5961339 -02 (PER ROW) LEAD STYLE -01: .120 [3.05] -02: .075 [1.91] -04: .150 [3.81] PLATING SPECIFICATION -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -H: 30µ" GOLD IN CONTACT AREA, 3µ" GOLD ON TAIL -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -LTL: 10µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10+/-5%) TAIL .000±.002 0.00±0.05 -G: 10µ" GOLD IN CONTACT AREA, (SEE NOTE 6) C 3µ" GOLD ON TAIL -STL: 30µ" SELECTIVE GOLD IN CONACT AREA, TIN/LEAD (90/10 +/-5%) ON TAIL DETAIL 'B' SCALE 14 : 1 (No OF POS x .0500[1.270]) (No OF POS x .0500[1.270] 02 +.005[0.13] -.010[0.25] +.002[0.04] .0500[1.270]) -.004[0.10] NON-CRITICAL AREA (SEE NOTE 4) .135 3.43 REF 03 FTSH-50-DH .016 0.41 SQ REF (TYP) "A" 'B' T-1S15-17-XXX SEE NOTE 3 2 MAX SWAY (EITHER DIRECTION) C .006[0.15] .070 1.78 REF (CONTACT AREA) 2 MAX SWAY (EITHER DIRECTION) .032 0.82 REF .21 5.3 NON-CRITICAL AREA (SEE NOTE 4) CRITICAL AREA (SEE NOTE 4) DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: FTSH-1XX-XX-XXX-DH SHOWN TAIL OPTION -DH: DOUBLE HORIZONTAL C UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: FIG 1 OPTIONS -TR: TAPE AND REEL -A: ALIGNMENT PIN (SEE FIG 2, SHEET 2 & FIG 3, SHEET 3) (MOLDED TO POSITION OR STAKED) (SAMTEC DISCRETION WHICH -A PIN IS USED) (STAKED 6 POSITION MIN. SEE FIG 3, SHEET 3, USE FTSH-50-DH) (MOLDED 5 POSITION MIN. SEE FIG 2, SHEET 2, USE FTSH-50-DH-AXX) -C: POLYIMIDE FILM (USE K-DOT-.197-.344-.005) (SEE FIG 4, SHEET 3) .099 2.51 REF 04 .0500 1.270 01 FTSH-1XX-XX-XXX-DH-XX NOTES: 1. C REPRESENTS A CRITICAL DIMENSION 2. MINIMUM PUSH OUT FORCE: .5 LB. 3. MAXIMUM BURR ALLOWED: .002[.05]. 4. MAXIMUM CUT FLASH: -NO CUT FLASH ALLOWED ON THE BOTTOM -MATING SURFACE CUT FLASH ALLOWED .010[0.25], THE REST NONCRITICAL AREA ALLOWED .015[0.38]. -LOOSE CUT FLASH MUST BE REMOVED. 5. MAXIMUM HEIGHT VARIATION .005[.13] BETWEEN ROWS. 6. APPLIES TO FIRST AND LAST PIN. * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4.5:1 INSULATOR: LCP, UL 94-V0 COLOR: BLACK TERMINAL: PHOSPHOR BRONZE, ALLOY No. 510, GRADE A, FED. SPEC. QQ-B-750, SPRING TEMPER F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DH-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 C.L. DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DH-XX BY: BRATCHER 01/04/1995 SHEET 1 OF 3 REVISION BV .099 2.51 REF "A" (SEE TABLE 1) .102 2.59 IN-PROCESS 1 .099 2.51 REF "A" (SEE TABLE 1) 'C' C +0.08 .000+-.003 .001 0.000 - 0.03 .09 2.3 (SEE NOTE 6) .022 0.56 REF IN-PROCESS 2 .099 2.51 REF "A" (SEE TABLE 1) FTSH-50-DH-AXX .255 6.48 IN-PROCESS 3 (No OF POS - 2) x .050 [1.27] REF .040 1.02 REF .035 0.89 REF FIG 2 -A: ALIGNMENT PIN (MOLDED) OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DH-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 C.L. DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DH-XX BY: BRATCHER 01/04/1995 SHEET 2 OF 3 REVISION BV C .040 1.02 C SM-A9H .035 0.89 REF (No OF POS - 2) x .050 [1.27] REF FIG 3 -A: ALIGNMENT PIN (STAKED) OPTION DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2 "R" (SEE NOTE) .140 3.56 "S" (SEE NOTE) .049±.020 1.24±0.51 .197 5.00 REF FIG 4 -C: POLYIMIDE FILM NOTE: "R" = USED MEASURED DIMENSION (REF) "S" = (("R" - .1969 [5.001]) / 2) ±.020 [.51] PT-FTSH001-DH * PACKAGING NOTES: 1. PACKAGE POSITIONS 10 THROUGH 50 IN TUBES. 2. POSITIONS 02 THROUGH 09 ARE TO BE LAYER PACKAGED. EXCEPT FOR -C OPTION, TUBE POSITIONS 05 THROUGH 50. 3. ALL PART POSITIONS 05 THROUGH 50 USE PT-FTSH001-DH. 4. USE TP-24 PLUG. PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 PACKAGING VIEW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. F:\DWG\MISC\MKTG\FTSH-1XX-XX-XXX-DH-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .050 x .050 C.L. DOUBLE HORIZONTAL TERMINAL STRIP DWG. NO. FTSH-1XX-XX-XXX-DH-XX BY: BRATCHER 01/04/1995 SHEET 3 OF 3
FTSH-110-01-L-DH 价格&库存
很抱歉,暂时无法提供与“FTSH-110-01-L-DH”相匹配的价格&库存,您可以联系我们找货
