DESCRIPTION: QUIK-LOQ - FEMALE - RIGHT ANGLE - PANEL MOUNT
UNITS = MM [INCHES]
CHARACTERISSTICS
MATERIALS
SHELL : BRASS
SHELL PLATING : NICKEL
NUT : BRASS
NUT PLATING : NICKEL
LATCH SLEEVE : BRASS
LATCH SLEEVE PLATING : NICKEL
CONTACTS : COPPER ALLOY
CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN.
INSULATOR : PPS (HIGH TEMPERATURE)
821B R YY - 2 1 3 R 00 1
1 = GOLD FLASH
SERIES
12.00 [0.475]
RoHS COMPLIANT
R = RIGHT ANGLE
NICKEL/CHROME PLATED SHELL
VERTICAL (PANEL MOUNT)
# OF POSITIONS
(Ex. 02)
**SEE CHART A**
MECHANICAL
DURABILITY: 5000 CYCLES
OPERATING TEMP. RANGE: -40 C ~ +200 C
PROCESS TEMPERATURE : 260 C FOR 5 SECONDS
MAX. TORQUE VALUE : 4.5 Nm [39 IN/lbs]
SHIELDING: 75dB @ 10MHz
40dB @ 1GHz
2 = FEMALE
0.551
14.00
1.063
27.00
IP RATING: 50
2 POSITION
15 AMP MAX.
= 1.30 [0.051]
PIN
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1500V
WORKING VOLTAGE = 500V
PANEL CUTOUT
0.025
0.64
TOLERANCE = +0.10, -0.0
[+0.004, -0.00]
0.118
3.00
0.524
13.30
0.197
5.00
(MAX. PANEL THICKNESS)
CHART A
76
0.551
14.00
M11*0.5
0.472
12.00
(ACROSS FLATS)
4
[0.
.1
12
0.022
0.56
0.496
12.60
= KEY LOCATION
3 POSITION
12 AMP MAX.
PIN
= 1.30 [0.051]
CONTACT
RESISTANCE = 5 mΩ
TEST VOLTAGE = 1300V
WORKING VOLTAGE = 430V
4 POSITION
10 AMP MAX.
PIN
= 0.90 [0.035]
CONTACT
RESISTANCE = 6 mΩ
5 POSITION
9 AMP MAX.
PIN
= 0.90 [0.035]
6 POSITION
7 AMP MAX.
PIN
= 0.70 [0.028]
7 POSITION
7 AMP MAX.
PIN
= 0.70 [0.028]
8 POSITION
5 AMP MAX.
PIN
= 0.70 [0.028]
CONTACT
RESISTANCE = 6 mΩ
TEST VOLTAGE = 1250V
WORKING VOLTAGE = 415V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 1050V
WORKING VOLTAGE = 350V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
WORKING VOLTAGE = 315V
CONTACT
RESISTANCE = 7.5 mΩ
TEST VOLTAGE = 950V
**NOTE**
SEE PAGE 2 FOR
BOARD LAYOUTS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF NorComp AND
SHALL NOT BE REPRODUCED, COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
NorComp
DRAWN:
DATE:
02-15-16
M. SIGMON
CHECKED:
DATE:
SCALE:
SHEET
N.T.S.
REV:
OF
1
DWG NO.
2
821BRYY-213R001
UNITS = MM [INCHES]
BOARD LAYOUTS
VIEW SHOWN FOR
CONNECTOR ORIENTATION
= KEY LOCATION
28
0.0 .71
2.54
0.025
0.64
(3-PLAC
ES )
0.050
1.27
TYP.
0.100
2.54
TYP.
0.300
7.62
0.100
2.54
TYP.
0.050
1.27
0.300
7.62
0.300
7.62
0.100
2.54
0.100
2.54
TYP.
8 POS
0.100
2.54
TYP.
7 POS
6 POS
25
0.0 .64 S)
0 E
AC
PL
0.100
2.54
TYP.
0.100
2.54
TYP.
0.100
2.54
TYP.
8
0.02
0.71
0.100
2.54
25
0.0 .64 S)
0 E
AC
PL
5
0.02 4
0.6 S)
E
L AC
(6-P
(7-
0.100
2.54
TYP.
0. 0
2
0. 7 8
1
(7-
5 POS
0.100
2.54
TYP.
0.300
7.62
0.300
7.62
0.300
7.62
28
0.0 .71
2
0. 7 8
1
4 POS
5
0.02
0.64 )
CES
-PLA
0.100
2.54
0.100
2.54
3 POS
0.100
2.54
TYP.
0.300
7.62
0.100
2.54
TYP.
28
0.0 .71
7.62
8
02 1
0 . 0 .7
0.100
2.54
2 POS
0.300
7.62
5
0.02
0.64 )
S
ACE
(4-PL
0.100
2.54
0.100
2.54
(5
0.300
7.62
0.02
5
(2-PL 0.64
ACE
S)
0.300
7.62
0.100
2.54
0.300
7.62
0.100
2.54
0.300
7.62
0.300
7.62
0.100
2.54
TYP.
RoHS COMPLIANT
N
C
NorComp
DRAWN:
DATE:
02-15-16
M. SIGMON
CHECKED:
DATE:
SCALE:
SHEET
N.T.S.
OF
2
DWG NO.
REV:
2
821BRYY-213R001
很抱歉,暂时无法提供与“821BR08-213R001”相匹配的价格&库存,您可以联系我们找货
