RR1220P-394-D
RR1220P-394-D
    SUSUMU
    贴片电阻 0805 390KΩ ±0.5% 1/10W ±25ppm/℃
RR1220P-394-D 数据手册
Metal thin film chip resistors (precision) ■RR series Features ・ Precision chip resistors excellent in resistance tolerance, TCR, frequency performance, noise characteristics, and linearity. RR series Thin film surface mount resistors * This product is not currently recommended for use in new design systems. Production may be discontinued in the near future. Applications ・ Consumer electronics that requires precision resistors ・ All purpose resistors in any area of electronics ◆Part numbering system RR 0816 P - 102 - D -(M)-(***) Series code only given to 3 digit coders for RR0816 E-96 series Size: RR0306, RR0510, RR0816, RR1220, Temperature coefficient of resistance Letter M is added for RR1220 E-96 series 4digit codes Nominal RR0306, RR0510, RR0816, RR1220 E-24: 3 digit, Resistance RR0306, RR0510, RR0816, RR1220 E-96: 4 digit, Resistance tolerance ◆Electrical Specification Type Power ratings RR0306 1/20W RR0510 1/16W RR0816 RR1220 Temperature coefficient of resistance Resistance range(Ω) Resistance tolerance (ppm/°C) ±0.1% (B) ±25(P) ー ±100(R) ー ±25(P) ー ±0.5% (D) 1/10W 15V 10≦R≦30 ー 100≦R≦100k ー ±25(P) ー ±50(Q) ー 5,000pcs E-24 10,000pcs 25V -55℃ ~ 125℃ 100≦R≦360k ー ±50(Q) Packaging quantity ±1% (F) 10≦R
RR1220P-394-D
1. 物料型号:RR系列,包括RR0306、RR0510、RR0816和RR1220尺寸。 2. 器件简介:这些是薄膜表面安装电阻器,具有优异的电阻公差、温度系数、频率性能、噪声特性和线性度。 3. 引脚分配:文档中没有提供具体的引脚分配信息。 4. 参数特性: - 电阻公差:±0.1%(B)、±0.5%(D)、±1%(F)。 - 温度系数:±25ppm/°C(P)、±100ppm/°C(R)、±50ppm/°C(Q)。 - 额定功率:1/20W、1/16W、1/10W。 - 最大电压:15V、25V、75V、100V。 - 电阻值系列:E-24、E-96。 - 工作温度范围:-55°C至125°C。 5. 功能详解:文档中没有提供详细的功能解释,但提到这些电阻器适用于需要精密电阻的任何电子领域。 6. 应用信息:适用于需要精密电阻的家用电器和其他电子产品。 7. 封装信息:提供了不同尺寸的电阻器的尺寸数据,包括长度、宽度和厚度。
RR1220P-394-D 价格&库存
很抱歉,暂时无法提供与“RR1220P-394-D”相匹配的价格&库存,您可以联系我们找货
RR1220P-394-D
    • 1+1.057011+0.13741
    • 100+0.84231100+0.10950
    • 300+0.53677300+0.06978
    • 500+0.47070500+0.06119
    • 1000+0.421161000+0.05475
    • 4000+0.388134000+0.05046
    • 5000+0.388135000+0.05046
    库存:35000
    RR1220P-394-D
    • 1+0.885821+0.11516
    • 10+0.2913610+0.03788
    • 50+0.2525150+0.03283
    • 100+0.23917100+0.03110
    • 500+0.20936500+0.02722
    库存:26362
    RR1220P-394-D
    • 5000+0.190665000+0.02479
    • 15000+0.1771115000+0.02303
    库存:26362
