IPBT-103-H1-T-D-K
IPBT-103-H1-T-D-K
    SAMTEC(申泰)
    插件,P=4.2mm
    线对板针座 2x3P 插件 间距:4.2mm
IPBT-103-H1-T-D-K 数据手册
IPBT-1XX-XX-XX-D-XX FIG 1 REVISION AJ (IPBT-108-H1-XX-D SHOWN) C DO NOT SCALE FROM THIS PRINT (No OF POSITIONS x .165[4.19]) + .053[1.33] REF C .109 2.76 REF (No OF POSITIONS - 1) x .165[4.19] 01 LEAD STYLE -H1: HIGH POWER, THRU HOLE (USE T-1S55-XX-X-2, SEE FIG 1, SHEET 1) -H2: HIGH POWER, SURFACE MOUNT (USE T-1S55-02-X-2, SEE FIG 3, SHEET 3) -H3: HIGH POWER. THRU HOLE, .670" STACKER (USE T-1S55-05-X-2, SEE FIG 5, SHEET 4) -H4: HIGH POWER. THRU HOLE, .748" STACKER (USE T-1S55-06-X-2, SEE FIG 5, SHEET 4) -H5: HIGH POWER. THRU HOLE, .787" STACKER (USE T-1S55-07-X-2, SEE FIG 5, SHEET 4) -H6: HIGH POWER. THRU HOLE, .984" STACKER (USE T-1S55-08-X-2, SEE FIG 6, SHEET 4) 02 C .378 9.60 REF .165 4.19 09 .050 1.27 REF .205 5.21 REF CL IPBT-08-D "A" .380 9.65 REF SEE NOTE 8 C (* = LEAVE BLANK FOR NO KEY OPTION, SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS AS OF REV W) .260 6.60 REF .510 12.95 REF T-1S55-01-X-2 .045 1.14 SQ REF (TYP) .165 4.19 (TYP) C C "A" 2 MAX SWAY ROW SPECIFICATION -D: DOUBLE (USE IPBT-XX-D) PLATING SPECIFICATION -T: MATTE TIN CONTACT AND TAIL (USE T-1S55-XX-T-2) -TM: MATTE TIN CONTACT AND TAIL (USE T-1S55-XX-T-2) -L: 10μ" GOLD ON CONTACT, TIN ON TAIL (USE T-1S55-XX-L-2) -S: 30μ" GOLD ON CONTACT, TIN ON TAIL (USE T-1S55-XX-S-2) .424 10.77 REF .405 10.29 REF .130 3.30 C OPTION -RA: RIGHT ANGLE (SEE FIG 2, SHEET 2) [STYLE -H1 ONLY] -GP: GUIDE POSTS (USE IPBT-XX-D-GP, SEE FIG 4, SHEET 3) (NOT AVAILABLE W/ -K OPTION) *-K: KEYED POLARIZATION (USE IPBT-XX-D-K)(SEE FIG 9, SHEET 5) (NOT AVAILABLE W/ -GP OPTION) No OF POSITIONS -02 THRU -15 (PER ROW) -02 (SEE SHEET 5, FIG.8) .045 1.14 SQ REF C 2 MAX SWAY .165 4.19 C SECTION "A"-"A" C (No OF POSITIONS - 1) x .165[4.19] ±.008[0.20] NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. COPLANARITY (FOR SURFACE MOUNT): SEE TABLE 2 SHEET 3. 3. MAX BURR ALLOWANCE: .0015 [.038]. 4. MINIMUM TERMINAL RETENTION: 1 LB. 5. IPBT-XX-D-XX AND IPBV-XX-D PARTS TO BE MOLDED TO POSITION, IPBE-XX-XX-D ARE TO BE CUT. 6. MAX HEIGHT VARIATION BETWEEN PINS: .005 [.13]. 7. ALL PIN TO PIN DIMENSIONS TO BE MEASURED FROM TIP TO TIP. 8. THIS NUMBER REPRESENTS THE NUMBER OF POSITIONS PER ROW ONLY AND IS NOT INTENDED TO BE USED IN POSITION NUMBERING. 9. ALL PARTS TO BE PACKAGED IN TUBES EXCEPT 2 AND 3 POS. 2 AND 3 POS PARTS TO BE LAYER PACKAGED. 10. MAX CUT FLASH: .005 [.13]. 11. AFTER REVISION T OF COMPONENT PRINT IPT1-XX-D-XX-X, SAMTEC LOGO TO APPEAR ON CORE #1 FOR POSITIONS 1 THROUH 5. FOR POSITIONS 6 THROUGH 15, LOGO TO APPEAR ON CORE #1 AND THE LAST CORE WITHIN THE SAME ROW. 12. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. F:\DWG\MISC\Mktg\IPBT-1XX-XX-XX-D-XX-MKT.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .XX: .01[.3] .XXX: .005[.13] .XXXX: .0020[.051] MATERIAL: ANGLES 2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP UL 94 VO, COLOR: BLACK TERMINAL: HIGH COPPER ALLOY SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .165 DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPBT-1XX-XX-XX-D-XX BY: DEAN P 7/27/2001 SHEET 1 OF 5 REVISION AJ -RA: RIGHT ANGLE IN-PROCESS VIEWS IN-PROCESS 4 IN-PROCESS 3 IN-PROCESS 2 IN-PROCESS 1 LATCH .260 6.60 REF 90° .173 4.38 REF .260 6.60 REF 1.068 27.13 REF .6861 17.43 REF C C C .394 10.00 .1475±.005 3.75±0.13 C .060 1.52 C .688 17.48 .147 3.73 REF T-1S55-03-X-2 T-1S55-04-X-2 FIG 2 (IPBT-108-H1-XX-D-RA SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (AVAILABLE ONLY ON -H1) T-1S55-03-X-2 2 MAX SWAY (EITHER DIRECTION) 01 T-1S55-04-X-2 02 90° C .260 6.60 REF 09 C .217±.008 5.51±0.20 (SEE NOTE 7) C .060 1.52 "B" .147 3.73 REF SECTION "B"-"B" * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING "B" SHEET SCALE: 2:1 F:\DWG\MISC\Mktg\IPBT-1XX-XX-XX-D-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .165 DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPBT-1XX-XX-XX-D-XX BY: DEAN P 7/27/2001 SHEET 2 OF 5 REVISION AJ FIG 3 2 MAX SWAY (EITHER DIRECTION) 01 -H2: SURFACE MOUNT IN-PROCESS VIEWS (IPBT-108-H2-XX-D SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 IN-PROCESS 1 02 .160 4.06 REF C .607 15.42 REF .327 8.30 09 C "C" +0° C C .450 11.43 .260 6.60 REF SEE TABLE 2 "C" T-1S55-02-X-2 T-1S55-02-X-2 T-1S55-02-X-2 90° - 4° IN-PROCESS 2 .620 15.75 REF SECTION "C"-"C" +0° 90° - 4° (TYP) .145 3.68 FIG 4 (IPBT-108-H1-XX-D-RA-GP SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1, 2 OR 3) .620±.010 (No OF POSITIONS x .165[4.19]) +.240[6.10] REF 01 .160 4.06 REF 02 .424 10.77 REF .110 2.79 REF 09 IPBT-08-D-GP .135 3.43 REF * PROPRIETARY NOTE DO NOT SCALE DRAWING (No OF POSITIONS x .165[4.19]) + .483[12.27] REF C SHEET SCALE: 1:0.470588 F:\DWG\MISC\Mktg\IPBT-1XX-XX-XX-D-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .165 DOUBLE ROW TERMINAL ASSEMBLY IPBT-1XX-XX-XX-D-XX BY: DEAN P 7/27/2001 SHEET 3 OF 5 REVISION AJ FIG 5 (IPBT-108-H3-XX-D SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG.1) IN PROCESS 1 IPBT-08-D (FOR H4, H5, & H6 ONLY) (FOR H3 ONLY) CUT FROM IPBE-31-XX-D .130 3.30 IPBV-XX-D "C" REF (SEE TABLE 4) C "A" C (SEE TABLE 3) IPBV-XX-D IN PROCESS 1 C "D" (SEE TABLE 4) "C" REF (SEE TABLE 4) "D" (SEE TABLE 4) C T-1S55-05-X-2 C C .130 3.30 .130 3.30 C FIG 6 (IPBT-108-H6-XX-D SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG. 1) FIG 7 (IPBT-108-H6-XX-D-GP SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1, 5, OR 6) IPBT-08-D C "A" (SEE TABLE 3) CUT FROM IPBE-31-H6-D IPBT-08-D-GP CUT FROM IPBE-31-H6-D T-1S55-08-X-2 T-1S55-08-X-2 * (No. OF POSITIONS x .165[4.19]) + .033[0.84]±.005 (SEE NOTE 11) PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. C DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\Mktg\IPBT-1XX-XX-XX-D-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .165 DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPBT-1XX-XX-XX-D-XX BY: DEAN P 7/27/2001 SHEET 4 OF 5 REVISION AJ FIG 9 (IPBT-1XX-H1-XX-D-K SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) FIG 8 (IPBT-102-H1-XX-D SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) -102 POS SHOWN -105 POS SHOWN (DIFFERENT AS SHOWN) (TYPICAL FOR POSITIONS 3 THRU 15) 01 02 01 02 .035 0.89 REF 06 03 IPBT-05-D-K IPBT-02-D-K PACKAGING VIEWS [PARTS TO HAVE POSITION #1 LOADED IN SAME DIRECTION AS ARROW ON TUBE] (SEE NOTE 9) IPBT-1XX-H1-XX-D-XX SHOWN TUBE: PT-1-24-01-112 PLUG: TP-28 IPBT-1XX-H2-XX-D-XX SHOWN TUBE: PT-1-24-02-112 PLUG: TP-28 IPBT-1XX-H3-XX-D-XX SHOWN TUBE: PT-1-24-04-56 PLUG: TP-25 * IPBT-1XX-H5-XX-D-XX SHOWN TUBE: PT-IPBT001-H4-H6 PLUG: TP-28 IPBT-1XX-H6-XX-D-XX SHOWN TUBE: PT-IPBT001-H4-H6 PLUG: TP-28 IPBT-1XX-H1-XX-D-RA SHOWN TUBE: PT-1-24-19T-109 PLUG: TP-25 (2 EACH END) IPBT-1XX-H4-XX-D-XX SHOWN TUBE: PT-IPBT001-H4-H6 PLUG: TP-28 PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\Mktg\IPBT-1XX-XX-XX-D-XX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .165 DOUBLE ROW TERMINAL ASSEMBLY DWG. NO. IPBT-1XX-XX-XX-D-XX BY: DEAN P 7/27/2001 SHEET 5 OF 5
IPBT-103-H1-T-D-K 价格&库存
很抱歉,暂时无法提供与“IPBT-103-H1-T-D-K”相匹配的价格&库存,您可以联系我们找货
IPBT-103-H1-T-D-K
  • 20+11.14791
  • 50+10.03554
  • 100+8.57252
  • 500+7.37552
  • 1000+6.94024
  • 2000+6.43242
  • 5000+5.57396
  • 10000+5.05404
库存:1352
IPBT-103-H1-T-D-K
  • 1+11.106791+1.43966
  • 50+10.0487750+1.30252
  • 100+8.55021100+1.10827
  • 500+7.40431500+0.95974
  • 1000+6.963661000+0.90263
  • 2000+6.919502000+0.89690
库存:2382
