IPBT-103-H1-T-S-RA-K
    SAMTEC(申泰)
    弯插,P=4.2mm
    线对板针座 1x3P 弯插 间距:4.2mm
IPBT-103-H1-T-S-RA-K 数据手册
REVISION R IPBT-1XX-XX-XX-S-XX OPTION -RA: RIGHT ANGLE (SEE FIG 2, SHT 2) [STYLE -H2 NOT AVAILABLE] -GP: GUIDE POSTS (USE IPBT-XX-S-GP, SEE FIG 4, SHT 3) *-K: KEYED POLARIZATION (USE IPBT-XX-S-K) (SEE FIG 5, SHT 2) (NOT AVAILABE W/-GP OPTION) No OF POSITIONS -02 THRU -10 DO NOT SCALE FROM THIS PRINT LEAD STYLE -H1: HIGH POWER, THRU HOLE (USE T-1S55-XX-XX-2) -H2: HIGH POWER, SURFACE MOUNT (USE T-1S55-XX-XX-2) ((No OF POSITIONS x .165[4.19]) + .0525) REF .109 2.76 REF (No OF POSITIONS -1) x .165[4.19] REF 01 .259 6.58 REF 02 PLATING SPECIFICATION -T: MATTE TIN CONTACT AND TAIL (USE T-1S55-XX-T-2) -TM: MATTE TIN CONTACT AND TAIL (USE T-1S55-XX-T-2) -L: 10μ" GOLD ON CONTACT, TIN ON TAIL (USE T-1S55-XX-L-2) -S: 30μ" GOLD ON CONTACT, TIN ON TAIL (USE T-1S55-XX-S-2) CL CL .205 5.21 REF .050 1.27 REF "A" .380 9.65 REF C ROW SPECIFICATION -S: SINGLE (USE IPBT-XX-S) IPBT-XX-S .259 6.58 REF .260 6.60 REF .405 10.29 REF "A" 2 MAX SWAY (EITHER DIRECTION) 'A' REF .130 3.30 C (SEE NOTE 4) C .165 4.19 .045 1.14 SQ REF 2 MAX SWAY C (EITHER DIRECTION) T-1S55-01-X-2 C (* = LEAVE BLANK FOR NO KEYED OPTION. SAMTEC WILL ONLY SUPPORT EXISTING BUSINESS AS OF REV F) ((No OF POSITIONS -1) x .165[4.19]) .008[.20] SECTION "A"-"A" NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. PARTS TO BE MOLDED TO POSITION. 3. MINIMUM TERMINAL RETENTION: 1 LB[4.45 N]. 4. POST MUST BE WITHIN .005[.13] OF EACH OTHER. 5. PARTS TO BE TUBE PACKAGED, SEE PACKAGING VIEWS SHT 3. 6. THIS FEATURE NOT PRESENT ON -02-S AND -03-S POSITIONS. ONLY CORNER RIBS (4 PLCS) ARE PRESENT. 7. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. IPBT-108-H1-XX-S SHOWN FIG 1 F:\DWG\SW\Exisprod\Assembly\165\IPBT-1XX-XX-XX-S-XX-ASM.SLDDRW UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL 94 VO COLOR: BLACK TERMINAL: HIGH COPPER ALLOY SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .165 SINGLE ROW TERMINAL ASSEMBLY DWG. NO. IPBT-1XX-XX-XX-S-XX BY: KEVIN B 05/06/03 SHEET 1 OF 3 REVISION R .036 0.90 REF LATCH 90° .173 4.38 REF IPBT-05-S-K FIG 5 -K: POLARIZATION (IPBT-105-H1-XX-S-K SHOWN) (SAME AS FIG 1 UNLESS OTHERWISE STATED) .686 17.43 REF C .3936±.0050 9.998±0.127 .1475±.0050 3.75±0.13 .147 3.73 REF SEE NOTE 6 T-1S55-03-X-2 .036 0.90 REF IN-PROCESS 2 IN-PROCESS 1 2 MAX SWAY C (EITHER DIRECTION) IPBT-03-S FIG 6 (IPBT-103-H1-XX-S-K SHOWN) (SAME AS FIG 1 UNLESS OTHERWISE STATED) .259 6.58 REF 01 02 T-1S55-03-X-2 "B" 90° C .260 6.60 REF "B" .060 1.52 C (MEASURE AT BEND) FIG 2 .147 3.73 REF SECTION "B"-"B" -RA: RIGHT ANGLE (IPBT-108-H1-XX-S-RA SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) (STYLE -H2 NOT AVAILABLE) F:\DWG\SW\Exisprod\Assembly\165\IPBT-1XX-XX-XX-S-XX-ASM.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: .165 SINGLE ROW TERMINAL ASSEMBLY DWG. NO. IPBT-1XX-XX-XX-S-XX BY: KEVIN B 05/06/03 SHEET 2 OF 3 01 REVISION R .46 11.6 .160 4.06 REF 02 .607 15.42 REF "C" .327 8.31 C .260 6.60 REF T-1S55-02-X-2 +0° IN-PROCESS 1 90° - 4° C .450 11.43 C C SEE TABLE 2 "C" T-1S55-02-X-2 SECTION "C"-"C" +0° 90° - 4° FIG 3 STYLE -H2: SURFACE MOUNT (IPBT-108-H2-XX-S SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) .145 3.68 .46 11.6 IN-PROCESS 2 ((No OF POSITIONS x .165[4.19]) +.240[6.10] REF 01 02 RIGHT ANGLE .160 4.06 REF .259 6.58 REF THROUGH HOLE TUBE: PT-1-24-06-51 PLUG: TP-07 TUBE: PT-1-24-01-40 PLUG: TP-13 .110 2.79 REF SURFACE MOUNT TUBE: PT-1-24-01-58 PLUG: TP-13 PACKAGING VIEW [PARTS TO HAVE POSITION #1 LOADED IN SAME DIRECTION AS ARROW ON TUBE] IPBT-XX-S-GP .135 3.43 REF * ((No OF POSITIONS x .165[4.19]) +.483[12.27] REF FIG 4 -GP: GUIDE POSTS (IPBT-108-H1-XX-S-RA-GP SHOWN) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1, 2 OR 3) (AVAILABLE WITH THROUGH HOLE, SURFACE MOUNT & -RA OPTION) F:\DWG\SW\Exisprod\Assembly\165\IPBT-1XX-XX-XX-S-XX-ASM.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DWG. NO. .165 SINGLE ROW TERMINAL ASSEMBLY IPBT-1XX-XX-XX-S-XX BY: KEVIN B 05/06/03 SHEET 3 OF 3
IPBT-103-H1-T-S-RA-K 价格&库存
很抱歉,暂时无法提供与“IPBT-103-H1-T-S-RA-K”相匹配的价格&库存,您可以联系我们找货
    • 1+9.50400
    • 10+9.25560
    • 40+9.09360
    • 80+8.93160
    库存:99
      • 40+11.65573
      • 80+10.62799
      • 120+8.99571
      • 520+7.79870
      • 1000+7.37552
      • 2000+6.77097
      • 5000+5.82787
      • 10000+5.32004
      库存:15612
