IPL1-102-01-L-S-RA-K 数据手册
IPL1-1XX-XX-XXX-S-XX-X-XX
REVISION W
(No OF POS x .100[2.54])
+.060[1.52] REF
.080 2.03 REF
(No OF POS -1)
x .100[2.54] REF
01
LEAD STYLE
-01: THROUGH HOLE
(USE T-1S64-XX-XX)
-02: SURFACE MOUNT
(SEE FIG. 2, SHT 2)
(USE T-1S64-XX-XX)
02
.240 6.10
REF
CL
.010 0.25 REF
TERMINAL OFFSET
FOR POLARIZATION
.040 1.02 REF
ROW SPECIFICATION
PLATING SPECIFICATION
-S: SINGLE (USE IPL1-XX-S)
-F: FLASH SELECTIVE (USE T-1S64-XX-F)
-L: LIGHT SELECTIVE (USE T-1S64-XX-L)
-S: SELECTIVE (USE T-1S64-XX-S)
-H: HEAVY GOLD (USE T-1S64-XX-H)
-FM: FLASH SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-F)
-LM: LIGHT SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-L)
-SM: SELECTIVE/MATTE TIN TAILS (USE T-1S64-XX-S)
-STL: LIGHT SELECTIVE TIN/LEAD (USE T-1S64-XX-STL)
CL
.100 2.54 REF
DO NOT
SCALE FROM
THIS PRINT
PACKAGING
BLANK: TUBES (SEE NOTE 12)
-TR: TAPE & REEL (SEE NOTES 12 & 13)
(AVAILABLE WITH -02 LEAD STYLE ONLY)
(MUST USE K-DOT-.177-.281-.005)
(SEE FIG 5, SHT 3)
-FR: FULL REEL QTY. TAPE & REEL (SEE NOTES 12 & 13)
POLARIZATION OPTION
-K: KEYED POLARIZATION
(USE IPL1-XX-S-K)
(SEE FIG 4, SHEET 3)
(LEAVE BLANK FOR NO POLARIZATION, SAMTEC WILL
ONLY SUPPORT EXISTING BUSINESS AS OF REV J)
OPTION
-RA: RIGHT ANGLE (SEE FIG 3, SHT 3)
(AVAILABLE WITH -01 LEAD STYLE ONLY)
No OF POSITIONS
-02 THRU -25
IPL1-XX-S
SEE NOTE 7 C
SEE NOTE 4
"A"
.300 7.62
REF
.215 5.46
REF
.320 8.13
REF
.120 3.05 REF
T-1S64-07-XXX
C
2° MAX SWAY
(EITHER DIRECTION)
C
C
"A"
.025 0.64 SQ REF
2° MAX SWAY
(EITHER DIRECTION)
SECTION "A"-"A"
.100 2.54
C
((No OF POS - 1) x .100[2.54])±.008[0.20]
NOTES:
1.
REPRESENTS A CRITICAL DIMENSION.
2. MINIMUM TERMINAL RETENTION: 1 LB [4.45 N].
3. PARTS TO BE MOLDED TO POSITION.
4. POST MUST BE WITHIN .005[0.13] OF EACH OTHER.
5. ALL PIN TO PIN DIMENSIONS TO BE MEASURED FROM TIP TO TIP.
6. DIMENSION TO BE MEASURED AT BEND.
7. TIP TO BE FLUSH TO .015[0.38] BELOW TOP OF SHROUD.
8. NOTE DELETED.
9. PACKAGE ALL POSITIONS.
10. NOTE DELETED.
11. NOTE DELETED.
12. ORDERS WILL BE PACKAGED ACCORDING TO THE SAMTEC
PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON
WWW.SAMTEC.COM
13. ATTACH LABEL-4X2 TO EACH REEL.
FIG 1
IPL1-106-01-XXX-S SHOWN
CPC
THIS SHEET
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01[0.3]
.XXX: .005[0.13]
.XXXX: .0020[0.051]
C1, C2, C3,
C4, C5
MATERIAL:
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 3:1
STANDARD INSULATOR: LCP UL94-V0, COLOR: BLACK
-K INSULATOR: LCP UL94-V0, COLOR: NATURAL
TERMINAL: PHOS BRONZE
F:\DWG\MISC\MKTG\IPL1-1XX-XX-XXX-S-XX-X-XX-MKT.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.100[2.54] SINGLE ROW TERMINAL ASSEMBLY
DWG. NO.
BY: D PURVIS
05/02/2005 SHEET 1 OF 3
REVISION W
01
C
(SEE NOTE 7)
02
.106 2.69 C
.119 3.02 REF
+0°
90° - 4°
.215 5.46
.231 5.87 REF
.345 8.76
SEE TABLE 2
T-1S64-08-XXX
.028 0.72 REF
T-1S64-08-XXX
-02: SURFACE MOUNT IN-PROCESS 1
.277 7.04 REF
FIG 2
STYLE -02: SURFACE MOUNT
IPL1-106-02-XXX-S SHOWN
[DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1]
PT-1-24-01-123
PT-1-24-04-40
PT-1-24-01-127
C
+0°
90° - 4°
.125 3.18
.277±.010 7.04±0.25
-02: SURFACE MOUNT IN-PROCESS 2
CPC
THIS SHEET
PACKAGING VIEWS
(PARTS TO HAVE POSITION #1 LOADED
IN SAME DIRECTION AS ARROW ON TUBE)
C6, C7, C10
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: D PURVIS
05/02/2005
SHEET 2 OF 3
REVISION W
.110 2.79 C
.040 1.02
REF
90° C
.115 2.92 REF
.655 16.64 REF
.545 13.84
REF
.160 4.06
IPL1-06-S-K
.085 2.16 REF
T-1S64-19-XXX
01
FIG 4
-RA: IN-PROCESS 2
-RA: IN-PROCESS 1
(IPL1-106-01-XXX-S-K SHOWN)
(SAME AS FIG 1 UNLESS OTHERWISE STATED)
02
.240 6.10
REF
T-1S64-19-XXX
((NO OF POS x .100[2.54] - .117 [2.97]) / 2) .020 [0.51]
(SEE NOTE 7)
C
"B"
.031±.020 0.80±0.51
.215 5.46
REF
.350 8.89
.177 4.50 REF
.060 1.52
(SEE NOTE 6)
"B"
FIG 5
.085 2.16 REF
(IPL1-106-02-XXX-S-TR SHOWN)
(SAME
AS FIG 2,"B"-"B"
SECTION
FIG 3
-RA: RIGHT ANGLE
IPL1-106-01-XXX-S-RA SHOWN
CPC
THIS SHEET
C8, C9, C11
PROPRIETARY NOTE
SHEET SCALE: 2:1
PHONE: 812-944-6733
FAX: 812-948-5047
code 55322
DESCRIPTION:
DWG. NO.
BY: D PURVIS
05/02/2005
SHEET 3 OF 3
