70-IAC15A
70-IAC15A
    GRAYHILLINC.
    Module
70-IAC15A 数据手册
AC Input Modules FEATURES • Transient Protection: Meets the requirements of IEEE 472, “Surge Withstanding Capability Test” • UL, CSA, CE, TÜV Certified (TÜV not available on OpenLine) • Optical Isolation • OpenLine® and G5 Modules have Built-in Status LED • Lifetime Warranty 70L-IAC 70G-IAC 70-IAC 70M-IAC CIRCUITRY Standard, Mini, G5 + 1 OpenLine® I/O MODULE PIN # TYPICAL WIRING FOR MODULE 70 6 A INPUT DEVICE Rx VDC 2 Vcc CH. A STATUS GND 1 1 FILTER OPTICAL ISOLATION HYSTERESIS 7 5 2 +VCC 3 2 INPUT VOLTAGE HYST. CIRC. CURRENT REGULATING INPUT DEVICE 3 3 FILTER OPTICAL ISOLATION B HYSTERESIS 8 CH. B STATUS OUTPUT 4 * 4 TERMINAL BLOCK # BASE OR RACK GROUND 5 4 MODULE 0Ω 9 MODULE ID Status LED in G5 modules only. * Separate supplies may also be used. SPECIFICATIONS: By Package Style Package Style Specifications Output Current Range Minimum Output Breakdown Voltage Maximum Turn-On Time Maximum Turn-Off Time Isolation Voltage 1 Vibration2 Mechanical Shock3 Storage Temp. Range Operating Temp. Range Warranty 1 2 3 Std (70-) Units mA Vdc mS mS Vrms 1-50 50 20 20 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime Mini (70M-) G5 (70G-) OL (70L-) I/O Modules °C °C 1-50 50 20 20 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 20 20 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 20 20 2500 IEC68-2-6 IEC68-2-27 -40 to +100 -40 to +85 Lifetime Field to logic and channel-to-channel if Grayhill racks are used. MIL-STD-202, Method 204, 20 G, 10-2000 Hz or IEC68-2-6, 0.15 mm/sec2, 10-150 Hz. MIL-STD-202, Method 213, Condition F, 1500 G or IEC68-2-27, 11 mS, 15g. I/O 14 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com AC Input Modules SPECIFICATIONS: By Part Number Standard and Miniature Modules Type/Function Miniature Standard Specifications Units 120 90-140 8 22K 90 25 5 3-6 10 240 180-280 6 60K 180 50 5 3-6 10 120 90-140 8 22K 90 25 15 8-18 10 240 180-280 6 60K 180 50 15 8-18 10 120 90-140 8 22K 90 25 24 15-30 10 240 180-280 6 60K 180 50 24 15-30 10 70M-IAC5 70-IAC5 70M-IAC5A 70-IAC5A Grayhill Part Number 70M-IAC15 70M-IAC15A 70M-IAC24 70-IAC15 70-IAC15A 70-IAC24 70M-IAC24A 70-IAC24A Nominal Input Voltage Vac Vac/Vdc Input Voltage Range1 Input Current @ Maximum Input Voltage mA, rms Nominal Input Resistance (Rx) Ω Maximum Pick-Up Voltage (Output Low) Vac Minimum Drop-Out Voltage (Output High) Vac Nominal Logic Voltage (Vcc) Vdc Logic Voltage Range Vdc Max. Logic Supply Current @ Nominal Vcc mA G5 Modules Type/Function G5, Status LED Specifications Nominal Input Voltage Input Voltage Range1 Input Current @ Maximum Input Voltage Nominal Input Resistance (Rx) Maximum Pick-Up Voltage (Output Low) Minimum Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Units Vac Vac/Vdc mA, rms Ω Vac Vac Vdc Vdc mA 120 90-140 8 22K 90 25 5 4.5-6 10 240 180-280 6 60K 180 50 5 4.5-6 10 120 90-140 8 22K 90 25 15 10-18 10 240 180-280 6 60K 180 50 15 10-18 10 120 90-140 8 22K 90 25 24 17-30 10 240 180-280 6 60K 180 50 24 17-30 10 70G-IAC5 70G-IAC5A Grayhill Part Number 70G-IAC15 70G-IAC15A 70G-IAC24 70G-IAC24A OpenLine® Modules Type/Function Dual, Status LED Specifications Nominal Input Voltage Input Voltage Range1 Input Current @ Max. Input Voltage Nominal Input Resistance (Rx) Max. Pick-Up Voltage (Output Low) Min. Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Module ID Resistance to Logic Ground 1 Grayhill Part Number 70L-IAC Units Vac Vac/Vdc mA, rms Ω Vac Vac Vdc Vdc mA Ω 120 0-140 8 22K 90 25 5 4.5-28 6/CH 0 240 0-280 6 64K 180 50 5 4.5-28 6/CH 0 70L-IACA Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. I/O Modules For input voltages in the range of 15-32 Vac, or 35-60 Vac, see DC input Modules with the NP or G suffix. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com I/O 15
70-IAC15A 价格&库存
很抱歉,暂时无法提供与“70-IAC15A”相匹配的价格&库存,您可以联系我们找货
