70-OAC5RLY
70-OAC5RLY
    GRAYHILLINC.
    Module
    OUTPUT MODULE STD 26MA 5VDC
70-OAC5RLY 数据手册
Dry Contact and Mechanical Relay Output Modules FEATURES • SPST, Normally Open • UL, CSA Certified • 1500 Vac Optical Isolation • G5 and OpenLine® Modules Provide Replaceable 5x20mm Glass Fuse • Built-in Status LED • Lifetime Warranty • Switch AC or DC with the Same Module • Very Low Off-State Leakage Current for AC loads • No Off-State Leakage Current for DC loads 70L-ODC5R 70G-ODCR/OACRLY 70-ODCR/OACRLY 70M-ODCR CIRCUITRY Standard, Mini, G5 LOAD VAC/VDC 1 OpenLine® 1 2 5 LOAD 2 +VCC 3 AMP 6 7 AMP INPUT 4 3 8 AMP 4 9 GROUND 5 Fuse and status LED in G5 modules only. I/O Modules SPECIFICATIONS BY PACKAGE STYLE Package Style Specifications Isolation Voltage Vibration2 Mechanical Shock3 Storage Temp. Range Operating Temp. Range 1 2 1 Std (70-) Units Vrms 1500 MIL-STD-202 MIL-STD-202 -40 to 70 -40 to 70 Mini (70M-) G5 (70G-) OpenLine® (70L-) °C °C 1500 MIL-STD-202 MIL-STD-202 -40 to 70 -40 to 70 1500 MIL-STD-202 MIL-STD-202 -40 to 70 -40 to 70 1500 IEC68-2-6 IEC68-2-7 -40 to 70 -40 to 70 Field to logic and channel-to-channel if Grayhill racks are used. MIL-STD-202, Method 204, 20 G, 10-2000 Hz or IEC68-2-6, 0.15 mm/sec2, 10-150 Hz. 3 MIL-STD-202, Method 213, Condition F, 1500 G or IEC68-2-27, 11 mS, 15g. I/O 10 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com Dry Contact and Mechanical Relay Output Modules SPECIFICATIONS BY PART NUMBER Standard and Miniature Modules Type/Function Miniature, Normally Open Standard, Normally Open Specifications Maximum Line Voltage Load Voltage Range Maximum Contact Rating Maximum Switching Current1 Maximum Carry Current1 Minimum Life Expectancy @ 10 Vdc/10 mA @ 48 Vdc/100 mA @ 120 Vac/80 mA @ 30 Vdc or 230 Vac/3A Maximum Contact Resistance Maximum Off-State Leakage Maximum Turn-On Time2 Maximum Turn-Off Time2 Nominal Logic Voltage (Vcc) Logic Voltage Range Maximum Logic Supply Current @ Nominal Vcc Nominal Input Resistance (Rx) Minimum Drop-Out Voltage Maximum Reverse Logic Voltage Units Vdc/Vac Vdc/Vac W A A Cycles Cycles Cycles Cycles mΩ mA mSec mSec Vdc Vdc mA Ω Vdc Vdc 100/120 0-100/0-120 10 0.5 1.0 200 x 106 500 x 103 500 x 103 — 250 .002 1 1 5 4.8-6.0 10 500 2.5 -5 110/250 0-110/0-250 90 3.0 5.0 — — — 100 x 10 6 250 .002 11 11 5 4.8-6.0 26 200 4.8 -5 100/120 0-100/0-120 10 0.5 1.0 200 x 106 500 x 103 500 x 103 — 250 .002 1 1 24 20-30 16 1700 23 -5 70M-ODC5R 70-ODC5R Grayhill Part Number 70-OAC5RLY 70M-ODC24R 70-ODC24R G5 and OpenLine® Modules Type/Function G5 Fusible, Normally Open Specifications Maximum Line Voltage Load Voltage Range Maximum Contact Rating Maximum Switching Current1 Maximum Carry Current1 Minimum Life Expectancy @ 1Vdc/10 mA @ 10 Vdc/10 mA @ 48 Vdc/100 mA @ 120 Vac/80 mA @ 30 Vdc or 230 Vac/3A Maximum Contact Resistance Maximum Turn-On Time2 Maximum Turn-Off Time 2 Max. Off-State Leakage @ Max. Line Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Nominal Input Resistance (Rx) Minimum Drop-Out Voltage 1 2 Grayhill Part Number 70L-ODC5R Units Vdc/Vac Vdc/Vac W A A Cycles Cycles Cycles Cycles Cycles mΩ mSec mSec mA Vdc Vdc mA Ω Vdc 200/200 0-200/0-200 10 0.5 1.5 1000 x 106 — — 500 x 103 300 1 1 .002 5 4.5-6.0 30 max./channel 167 4.5 100/120 0-100/0-120 10 0.5 1.0 — 200 x 106 500 x 103 500 x 103 — 250 1 1 .002 5 4.8-6.0 10 500 1 110/250 0-110/0-250 90 3.0 5.0 — — — — 100 x 106 250 11 11 .002 5 4.8-6.0 26 200 1 100/120 0-100/0-120 10 0.5 1.0 — 200 x 106 500 x 103 500 x 103 — 250 1 1 .002 24 18-32 23 1200 23 70G-ODC5R 70G-OAC5RLY 70G-ODC24R I/O Modules Inductive loads require diode suppression or RC network. Times include debounce. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com I/O 11
70-OAC5RLY 价格&库存
很抱歉,暂时无法提供与“70-OAC5RLY”相匹配的价格&库存,您可以联系我们找货
