RG1005P-8061-B-T5
RG1005P-8061-B-T5
    SUSUMU
    贴片电阻 0402 8.06KΩ ±0.1% 1/16W ±25ppm/℃
RG1005P-8061-B-T5 数据手册
Metal thin film chip resistors (the highest precision) ■RG series AEC-Q200 Compliant Features ・ Long term stability with inorganic passivation ・ Less than ±0.1% drift after 10000 hours of reliability test Thin film surface mount resistors ・ High precision resistance tolerance: ±0.05%, very small TCR: ±5ppm/℃ ・ Thin film structure enabling low noise and anti-sulfur Applications ・ Automotive electronics ・ Industrial measurement instrumentation, industrial machines RG series ・ Various sensors, medical electronics ◆Part numbering system RG 1608 N - 102 - B - T5 Series code Packaging quantity: T5(5,000pcs), T10(10,000pcs) Size: RG0603, RG1005, RG1608, RG2012, RG3216 Resistance tolerance Temperature coefficient of resistance Nominal resistance value (E-24: 3 digit, E-96: 4 digit, RG3216: all 4 digit) ◆Electrical Specification Type Temperature coefficient of resistance Power ratings Low Regular (ppm/°C) High Resistance range(Ω)Resistance tolerance(%) ±0.05% (W) ±0.1% (B) ±10(N) RG0603 ±25(P) 1/20W 1/16W ー ±50(Q) 1/32W 1/16W 1/8W 1/16W 1/10W ±10(N) 47≦R≦100k ー 1/10W 1/8W 47≦R≦274k ±50(Q) ー 1/8W 1/4W ー 47≦R≦475k ±50(Q) ー 10≦R<47 ー 100≦R≦33.2k 47≦R≦1M ±25(P) ー ◆Dimensions Type a t T5 150V 47≦R≦2.7M 47≦R≦5.1M W E-24, E-96 -55℃ ~ 155℃ 10≦R<47 ー ±10(N) L 100V 47≦R≦1M 47≦R≦475k ±25(P) ±50(Q) T10 10≦R<47 ー 100≦R<10.2k ±5(V) RG3216 T10 30V T5 47≦R≦274k ±25(P) ±10(N) 1/4W Pakaging quantity 100≦R<5.1k ±10(N) ±5(V) RG2012 Operating temperature 75V 47≦R≦150k ±25(P) 1/6W Resistance value series 10≦R<47 100≦R<3k ±5(V) RG1608 47≦R≦56k ー ±5(V) ±100(R) Maximum voltage 100≦R<22k ー ±100(R) RG1005 ±0.5%(D) 10≦R<47 ー Size (inch) 200V L W a b t RG0603 0201 0.60±0.05 0.30±0.05 0.13±0.05 0.15±0.05 0.23±0.03 RG1005 0402 1.0±0.05 0.50±0.05 0.20±0.10 0.25±0.05 0.35±0.05 RG1608 0603 1.60±0.20 0.80±0.20 0.30±0.20 0.30±0.20 0.40±0.10 RG2012 0805 2.00±0.20 1.25±0.20 0.40±0.20 0.40±0.20 0.40±0.10 RG3216 1206 3.20±0.20 1.60±0.20 0.50±0.25 0.50±0.20 0.40±0.10 (unit:mm) 15 b ◆Reliability specification Test Items Low Condition (test methods) ≦47Ω *1 Short time overload 2.5 x rated voltage, 5 seconds Regular ≦47Ω ≧47Ω High ≧47Ω ±0.05%+0.01Ω ±0.05%+0.01Ω ±0.05%+0.01Ω ±0.05%+0.01Ω *1 70℃, rated voltage, 90min on 30min off, 1000hours ≦47Ω ー Typical ≧47Ω Low ±0.05%+0.01Ω ±0.05%+0.01Ω ±0.25% ±0.10% ±0.50% ±0.25% ー ±0.50% ±(0.01%) ±0.25% ±0.10% ±0.50% ±0.25% ー ±0.50% ±(0.05%) Temperature shock -55℃ (30min) ∼ 125℃ (30min) 1000cycles ±0.25% ±0.10% ±0.25% ±0.10% ー ±0.10% ±(0.01%) High temperature exposure 155℃, no bias, 1000hours ±0.25% ±0.10% ±0.25% ±0.10% ー ±0.10% ±(0.01%) Resistance to soldering heat 260±5℃, 10 seconds (reflow) Life (biased) High temperature high humidity 85℃, 85%RH, 1/10 of rated power, 90min on 30min off, 1000hours ー ±0.05%+0.01Ω ±0.05%+0.01Ω *1 Rated voltage is given by E= RxP E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. ◆10000 hour reliability test data 0.50 0.20 0.10 Resistance drift(%) 0.30 0.00 −0.10 −0.20 1kΩ 10kΩ 56kΩ −0.30 −0.40 −0.50 100 10 Test duration(h) 1000 100kΩ 330kΩ 3000 0.10 0.00 −0.10 −0.20 −0.50 10000 0.20 0.00 −0.10 −0.20 −0.30 Test duration(h) 1000 3000 100kΩ 330kΩ 10000 High temperature exposure(155℃) −0.40 Number of cycles 1000 Sample : RG1608series Test Temperature155℃ conditions: n=100 0.40 0.30 0.20 0.10 0.00 −0.10 −0.20 1kΩ 10kΩ 56kΩ −0.30 56kΩ 100kΩ 100 100 10 0.50 0.10 10 1kΩ 10kΩ 56kΩ ○High temperature exposure Resistance drift(%) Resistance drift(%) 0.20 −0.40 Sample : RG1608series Test -55℃ (30min) →room temp (. 3min) → conditions: +125℃ (30min) →room temp (. 3min) n=50 0.30 −0.50 0.30 Temperature shock 0.40 Sample : RG1608series Test Temperature85℃ Humidity85%RH conditions: 1/10 rated power 90min.on/30min. off Rated power=0.1W n=100 0.40 −0.30 ○Temperature shock 0.50 High temperature high humidity bias (THB 85℃ 85%) 0.50 Sample : RG1608series Test Temperature85℃ conditions: Rated voltage 90 min. on/30min. off Rated power=0.1W n=100 0.40 Resistance drift(%) ○High temperature high humidity (biased) High temoperature life test (85℃) RG series ○Biased life test −0.40 −0.50 10000 10 100 Test duration(h) 1000 3000 100kΩ 330kΩ 10000 Ratio to rated power (%) ◆Derating Curve High power application Regular power application High precision 100 50 0 -55 0 50 155 70 85 100 Ambient temperature (℃) ◆Maximum pulse power limit Maximum pulse power limit(W) 100 Test procedure Voltage pulse is applied to the test samples mounted 10 1 0.1 0.0001 on the test board. 1005 1608 2012 3216 After each pulse, resistance drift is measured. Pulse type type type type 0.001 voltage is increased until the drift exceeds +/-0.5%. The power at that voltage is defined as the 0.01 0.1 Pulse duration (seconds) 1 10 Thin film surface mount resistors ±0.05%+0.01Ω ±0.05%+0.01Ω ±0.05%+0.01Ω ±0.05%+0.01Ω maximum pulse power. 16
RG1005P-8061-B-T5
物料型号:SUSUMU RG系列
器件简介:该系列电阻器是高精度的金属薄膜芯片电阻器,符合AEC-Q200标准,具有长期稳定性和无机钝化。
引脚分配:文档未明确提供引脚分配信息。
参数特性: - 电阻公差:±0.05%(W级)、±0.1%(B级)、±0.5%(D级) - 温度系数:±5ppm/℃ - 尺寸:RG0603、RG1005、RG1608、RG2012、RG3216 - 功率等级:低、常规、高 - 操作温度范围:-55°C至155°C
功能详解:薄膜结构使电阻器具有低噪音和抗硫特性。
应用信息: - 汽车电子 - 工业测量仪器、工业机器 - 各种传感器、医疗电子
封装信息:提供T5(5,000pcs)和T10(10,000pcs)的包装数量。
RG1005P-8061-B-T5 价格&库存
很抱歉,暂时无法提供与“RG1005P-8061-B-T5”相匹配的价格&库存,您可以联系我们找货
RG1005P-8061-B-T5
  • 1+1.404061+0.18165
  • 10+1.1966410+0.15482
  • 25+1.1083625+0.14339
  • 50+1.0468850+0.13544
  • 100+0.98869100+0.12791
  • 250+0.91838250+0.11882
  • 500+0.86999500+0.11256
  • 1000+0.826001000+0.10687
库存:14299
RG1005P-8061-B-T5
  • 1+1.364401+0.17380
  • 10+0.9982010+0.12710
  • 100+0.93880100+0.11960
  • 250+0.87110250+0.11090
  • 500+0.81050500+0.10320
  • 1000+0.768501000+0.09790
  • 5000+0.640205000+0.08150
  • 10000+0.6064010000+0.07720
库存:1346
RG1005P-8061-B-T5
  • 5000+0.803375000+0.10394
  • 10000+0.7702210000+0.09965
  • 15000+0.7526615000+0.09738
  • 25000+0.7323125000+0.09475
  • 35000+0.7199435000+0.09314
  • 50000+0.7076750000+0.09156
库存:14299
