KRL1632E-M-R270-F-T5
    SUSUMU
    贴片电阻 1206 270mΩ ±1% 3/4W ±50ppm/℃
KRL1632E-M-R270-F-T5 数据手册
Metal foil low resistance chip resistors (short-side terminal) ■KRL series AEC-Q200 Compliant Features ・ High current sensing short side terminal low resistance chip resistor ・ Two types available: high temperature (operating temperature up to 175°C), low emf type ( operating temperature up to 155°C). ・ High current handling capability and wide range of power ratings ・ Size: 0510 ~ 50110, power ratings: 0.2W ~ 5W, resistance value range: 5m ~ 1000mΩ ・ Face down construction. Choice between bottom only or wrap around terminal KRL series Current sensing surface mount resistors Applications ・ Automotive electronics ・ Power source devises, ACDC converters, DCDC converters ・ Motors, inverters, office automation equipment ◆Part numbering system KRL 1220E - C - R010 - F - T1 Series code Packaging quantity: T1(1,000pcs), T5(5,000pcs) Resistance tolerance Size: KRL0510, KRL0816, KRL1220, KRL1632 KRL2550, KRL3264, KRL50110 Nominal resistance value Temperature characteristics type: C (high operating temperature ), M (low EMF) Terminal type: D (bottom terminal), E (wrap around terminal) ◆Electrical Specification Power ratings Type Temperature coefficient of resistance (ppm/°C) 0.2W KRL0816 0.3W KRL1220 0.5W KRL1632 0.75W KRL2550 1.5W KRL3264 3W KRL50110 5W 51 ±1% (F) Resistance value series Operating temperature C ±2% (G) Packaging quantity M ±50 *2 KRL0510 *1 *2 *3 *1 Resistance range(Ω) Resistance tolerance 10,000pcs 50m≦R≦100m ±100 ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦500m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦1000m ー ±100 ー 5m≦R≦9m(1m step) ±50 10m≦R≦1000m ー ±100 ー 5m≦R≦9m(1m step) *3 E-6 / E-12 We can meet your requirement for resistance value not specified in above table. Please contact our sales office. For KRL0510, please contact our sales office We can meet your requirement outside of E-6/E-12 series resistance. Please contact our sales office. -55℃ ~ 175℃ -55℃ ~ 155℃ T1 T5 T1 ◆Dimensions L Size Type W (inch) L W t a KRL0510 0402 1.00±0.20 0.50±0.20 0.40±0.20 0.30±0.20 KRL0816 0603 1.60±0.20 0.80±0.20 0.50±0.20 0.30±0.15(47mΩ~)/0.55±0.15(20~39mΩ) 0.70±0.15(10~18mΩ) KRL1220 0805 2.00±0.20 1.25±0.20 0.50±0.20 0.40±0.20 KRL1632 1206 3.20±0.20 1.60±0.20 0.50±0.20 0.50±0.20(9mΩ∼)/1.10±0.20(5 ∼ 8mΩ) D Type KRL2550 2010 5.00±0.20 2.50±0.20 0.50±0.20 0.60±0.20(9mΩ∼ /1.40±0.20(5 ∼ 8mΩ) L KRL3264 2512 6.30±0.20 3.10±0.20 0.50±0.20 1.00±0.20(9mΩ∼)/1.90±0.20(5 ∼ 8mΩ) KRL50110 4320 11.00±0.20 5.00±0.20 0.65±0.20 2.36±0.30(8mΩ∼)/3.60±0.30(5 ∼ 7mΩ) t a a W (unit:mm) a Current sensing surface mount resistors t a E Type Ratio to rated power (%) KRL series ◆Derating Curve C(high operating temperature) M(low EMF) 100 50 0 -55     0     50  100 120 155 175 Ambient temperature (℃) Ratio to rated power (%) KRL1632E-3A series (1W) is also in our line-up. 100 50 0 -55    0    50 70 100 150 175 Terminal temperature(℃) 52
KRL1632E-M-R270-F-T5 价格&库存
很抱歉,暂时无法提供与“KRL1632E-M-R270-F-T5”相匹配的价格&库存,您可以联系我们找货
  • 5000+1.013565000+0.13017
  • 10000+0.9422410000+0.12101
  • 15000+0.9056115000+0.11630
  • 25000+0.8641825000+0.11098
  • 35000+0.8394935000+0.10781
  • 50000+0.8153650000+0.10471
库存:38691
  • 1+4.051111+0.52025
  • 10+2.5745910+0.33064
  • 25+2.1829125+0.28034
  • 50+1.9377150+0.24885
  • 100+1.72791100+0.22190
  • 250+1.49840250+0.19243
  • 500+1.35416500+0.17391
  • 1000+1.231701000+0.15818
库存:38691
