BRA.3T.200.PCZN
BRA.3T.200.PCZN
    LEMO(雷莫)
    BRA.3T.200.PCZN
BRA.3T.200.PCZN 数据手册
COAXIAL & TRIAXIAL CONNECTORS FOR BROADCASTING 3T SERIES 3T Series (75 Ω) for TV camera applications Particularly intended for outdoor use, the product range of coaxial and triaxial connector of the 3T Series guarantees a protection index of IP66 as per IEC 60529 standard (mated connectors). The 3T Series models are fully intermatable with the ULC Series size III C75 (coaxial 75 Ω) and size III TCX75 (triaxial 75 Ω). Technical Characteristics Characteristics Impedance Operating frequency VSWR (f= GHz) Contact resistance Contact resis. internal screen Insulation resistance Watertightness Recommended cables Coax Triax Standard 75 Ω 1.9 GHz 1.03 + 0.09f < 2.5 m Ω – > 1012 Ω IP66 75 Ω 1.2 GHz 1.02 + 0.15f < 2.5 m Ω < 1.2 m Ω > 1012 Ω IP66 – – IEC 60169-1-1 IEC 60512-2 – IEC 60512-2 IEC 60529 Type Imp. (Ω) Cable groupe RG.216/U 7784A 7785A 9192-9232 9267 63990 Triax 8 Coax Triax Triax Triax Triax Triax Triax 75±3Ω 75±3Ω 75±3Ω 75±3Ω 75±3Ω 75±3Ω 75±3Ω 5 4 3 2 1 4 1 Triax Triax Type Type Type Triax Triax Triax Triax Triax 75±3Ω 75±3Ω 75±3Ω 75±3Ω 75±3Ω 4 3 1 2 6 Reference RG.11A/U Belden Belden Belden Belden NEK DRAKA RG.144/U DRAKA DRAKA Triax Triax Triax FFA 11 14 A2 B2 C2 Straight plug with cable clamping L Type B L S1 Cable groupe Coax Triax Triax Triax Triax Triax 20 20 20 28 28 28 71 69 69 88 88 88 18 18 18 26 26 26 5 1 4 2 3 6 øB ø 18 Part Number S1 Note: Chrome-plated brass outer shell, PTFE insulator, solder male contact, cable clamping, soldered external shield (part number ending with «S»). FFA.3T.275.CTAY11 FFA.3T.675.CTAY92S FFA.3T.675.CTAY11S FFA.3T.675.CTAY13S FFA.3T.675.CTAY14S FFA.3T.675.CTAY17S ERA Fixed socket, nut fixing 32 2.5 Part Number ø 30 M 22 x 1 ø 27 S 24 ERA.3T.275.CTL ERA.3T.675.CTL S 20.5 16 maxi Type Weight (g) Coax Triax 43.5 46.0 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact. EBC Fixed socket with square flange, visible shell, screw fixing 32 29 23 ø 3.2 Part Number EBC.3T.275.CTL EBC.3T.675.CTL 16 Type Weight (g) Coax Triax 55.5 58.0 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact. EHP Fixed socket, nut fixing, visible shell ~34 ø 23.5 ø 27 M 20 x 1 S 24 Part Number EHP.3T.675.CTL Type Weight (g) Triax 51.0 S 18 7 maxi Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact. PSA Fixed socket with cable clamping, nut fixing ~L S 24 2.5 S1 S2 16 maxi ø 30 øB M 22 x 1 Part Number S 20.5 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact, cable clamping, soldered external shield (part number ending with «S»). PSA.3T.275.CTLY11 PSA.3T.675.CTLY92S PSA.3T.675.CTLY11S PSA.3T.675.CTLY13S PSA.3T.675.CTLY14S PSA.3T.675.CTLY17S Type B L S1 S2 Cable groupe Coax Triax Triax Triax Triax Triax 20 20 20 28 28 28 81 74 74 95 95 95 18 18 18 26 26 26 16 16 16 16 16 16 5 1 4 2 3 6 Note: all dimensions are in millimetres. ø 11 maxi PCA Free socket with cable clamping ~L øB ø 24 Part Number PCA.3T.675.CTLY92S PCA.3T.675.CTLY11S PCA.3T.675.CTLY13S Type B L S1 Cable groupe Triax Triax Triax 20 20 28 76 76 87 18 18 26 1 4 2 S1 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact, cable clamping, soldered external shield (part number ending with «S»). RMA Free coupler 50 ø 23 Part Number RMA.3T.275.CTM RMA.3T.675.CTM Type Weight (g) Coax Triax 76.0 79.0 Note: Chrome-plated brass outer shell, PTFE insulator, female-female contact (for mating 2 FFA plugs). RBR Fixed coupler with square flange, screw fixing 50 29 23 ø 3.2 Part Number RBR.3T.275.CTM RBR.3T.675.CTM 16 Type Weight (g) Coax Triax 83.0 86.0 Note: Chrome-plated brass outer shell, PTFE insulator, female-female contact (for mating 2 FFA plugs). 38 ø 30 M 22 x 1 ø 27 ASA Adapter, nut fixing, consisting of a LEMO socket and a coax SMA socket 2.5 S 24 Part Number ASA.3T.275.CTM S 20.5 16 maxi Type Weight (g) Coax 51.0 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact. AZA Adapter, nut fixing, consisting of a LEMO socket and a triax SMZ socket 36.7 11.5 ø 23.5 ø 27 M 20 x 1 17 6 maxi Part Number AZA.3T.675.CTL S 24 Type Weight (g) Triax 53.0 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact. ø 45 AZB Adapter, screw fixing, consisting of a LEMO socket and a triax SMZ socket 37 17 12 0° ø 3.4 ø 23.5 ø 27.5 Part Number AZB.3T.675.CTL Type Weight (g) Triax 100.0 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact. 0.3 FWZ Adapter, consisting of a LEMO socket and a REDEL F T75 socket ø 23.5 45.8 Part Number FWZ.T75.FTS Weight (g) 76.0 Note: Chrome-plated brass outer shell, PTFE insulator, solder female contact. All dimensions are in millimetres. Accessories BFA Plug cap 6 ø 24 17 120 ± 5 Part Number BFA.3T.100.NAS sliding loop For model FFA Weight (g) 27.0 Note: Body material: Nickel-plated brass (Ni 3µm) Lanyard material: Stainless steel Crimp ferrule material: Nickel-plated brass + polyolefin BFA Plug cap 23 18 ø 24 0 Part Number BFA.3T.100.PCZN For model FFA Weight (g) 13.0 Note: Body material: Black EPDM Cord material: Black polyester Crimp ferrule material: Nickel-plated brass BRA Blanking cap for fixed sockets 29.5 20 ø 24 0 Weight (g) For models Part Number ERA, EBC, EHP, PSA, BRA.3T.200.PCZN RBR, ASA, AZA, AZB ø 5.3 23 + 0.1 0 18.1 + 0.1 0 AZB ø 27.6 + 0.1 0 120° 22.3 + 0.1 0 + 0.1 0 20.6 EBC, RBR 19.3 + 0.1 0 ø 3.3 + 0.1 0 ø 39 ø 3.3 Note: all dimensions are in millimetres. LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. (+41 21) 695 16 00 - e-mail: info@lemo.com www.lemo.com Product safety notice & disclaimers: Please read and follow all instructions specified on https://www.lemo.com/en/about-lemo/product-safety-notice-and-disclaimers + 0.1 0 CAT.3T.LEN.P0206, © LEMO / Data subject to change, printed in Switzerland, February­­­2006, updated June 2019 S 7.0 4 7.5 14 3.5 18 7.0 4 6.5 4 3.5 18 AZA 20.2 V 30.0 7.5 11.5 41.0 8.0 11.5 41.5 8.0 12.0 33.5 11.0 11.5 26.5 4.5 11.5 41.5 8.0 12.0 EHP 20.2 U 1 2 3 4 5 6 ASA, ERA, PSA L S T U V + 0.1 0 L T Note: Body material: Black EPDM Cord material: Black polyester Crimp ferrule material: Stainless steel AISI 304 Panel cut-outs Cable stripping lengths (mm) 22.1 Cable group Cable stripping lengths 10.0
BRA.3T.200.PCZN 价格&库存
很抱歉,暂时无法提供与“BRA.3T.200.PCZN”相匹配的价格&库存,您可以联系我们找货
