BGE.2M.200.XAZ
BGE.2M.200.XAZ
    LEMO(雷莫)
    BGE.2M.200.XAZ
BGE.2M.200.XAZ 数据手册
M Series Connectors ratchet coupling ® ® ® ® Precision modular connectors to suit your application Since its creation in Switzerland in 1946 the LEMO Group has been recognized as a global leader of circular Push-Pull connectors and interconnect solutions. Today LEMO and its affiliated companies, REDEL and COELVER, are active in more than 80 countries with the help of over 40 subsidiaries and distributors. Over 90000 connectors The modular design of the LEMO range provides over 90000 connectors from miniature ø 3 mm to ø 50 mm, capable of handling cable diameters up to 30 mm and for up to 114 contacts. This vast portfolio enables you to select the ideal connector configuration to suit almost any specific requirement in most markets, including medical devices, test and measurement instruments, machinery, audio video broadcast, telecommunications and military. LEMO’s ratchet 3/4 turn connection system This highly robust 3/4 turn screw locking system is recognized worldwide for the most demanding applications as a safe, secure and quick screw mating system. Its special ratchet mechanisms provides ultra high reliability in the most severe vibrations environments, shocks or pull on the cables. Triple start thread Triple start thread l 3/4 turn locking l l Very fast coupling nut engagement in the socket Stable thread engagement making tilted nut engagement impossible 3/4 turn locking Spring loaded ratchet system Quick and fast connection requiring less than a full turn for complete mating l Full mating possible with a single hand movement Spring loaded ratchet on locking nut Secure mating in high vibration environments No specific mating torque required to secure l No tools required; hand torquing force is sufficient to secure l l UL Recognition LEMO connectors are components recognized by the Underwriters Laboratories (UL), facilitating the UL approval of the complete system (including LEMO connector, cable and your equipment). CE marking CE marking means that the appliance or equipment complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. REACH and RoHS LEMO connector specifications comply with the requirements of the RoHS directive (2011/65/EU) and REACH regulation (1907/2006/EU) of the European Parliament and latest amendments. These REACH and ROHS regulations specify the restrictions of the use of hazardous substances in LEMO products marketed in Europe. Product safety notice & disclaimers Please read and follow all instructions specified on the last page or on our website carefully and consult all relevent national and international safety regulations for your application. Improper handling, cable assembly, or wrong use of connectors can result in hazardous situations. LEMO products and services are provided “as is.” LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. In no event shall LEMO be liable for any direct, indirect, punitive, incidental, special consequential damages, to property or life, whatsoever arising out of or connected with the use or misuse of LEMO’s products. www.lemo.com ® ® Introduction This catalogue provides a complete description of the LEMO M series portfolio. M series connectors are lightweight triplestart ratchet coupling type connectors designed for avionics, military, security, motorsport and heavy duty applications. The M series is a COTS (Commercial Off-The-Shelf) product, that fulfills the harshest MIL-DTL-38999 requirements in a more compact and lightweight package. It features a very wide range of configurable options to fulfill every applications. The LEMO engagement for supplying innovative solutions which meets users highest expectations translates thought the M series in a highly reliable interconnect solution that helps our customers reduce their maintenance and downtime in critical applications. The LEMO quality arises from years of expertise in design, manufacturing and quality system where all single M series connectors get identified with a laser engraved part number and production batch number for full traceability from raw materials to fully assembled product. Table of contents Technical characteristics.................................................................................................................................................................................................... 2 M Series Interconnections....................................................................................................................................................................................................... 4 Standard models part numbering system, Others models part numbering system, Part section showing internal components............................. 5 Locking nuts options, Backshell options................................................................................................................................................................... 6 Standard models....................................................................................................................................................................................................... 7 Watertight model (unmated)................................................................................................................................................................................... 13 Vacuumtight model (unmated)................................................................................................................................................................................ 14 High Speed models................................................................................................................................................................................................ 15 USB 2.0 models...................................................................................................................................................................................................... 17 Fibre Optic models.................................................................................................................................................................................................. 18 High Power models................................................................................................................................................................................................. 20 Alignment key and Polarized keying system.................................................................................................................................................................. 22 Insert configuration Multipole................................................................................................................................................................................................................. 23 Mixed multipole, Multipole high speed ethernet cat6.............................................................................................................................................. 25 USB 2.0, Multi fibre and Hybrid fibre optic + low voltage........................................................................................................................................ 26 Mixed high speed coax, Multi coaxial..................................................................................................................................................................... 27 High Power............................................................................................................................................................................................................. 28 Contacts Crimp, High speed ethernet cat6............................................................................................................................................................................ 30 Coaxial, High Voltage, High Power, F7 Fibre Optic................................................................................................................................................ 31 Accessories....................................................................................................................................................................................................................... 32 Tooling................................................................................................................................................................................................................................ 38 Panel cut-outs and PCB drilling pattern.......................................................................................................................................................................... 41 Assembly instructions...................................................................................................................................................................................................... 46 Product safety notice........................................................................................................................................................................................................ 49 MM 0M 1M 2M 3M TM 4M LM 5M www.lemo.com 1 ® ® Technical characteristics Materials and treatments Shell material code 1) Component X C l 2) Outer shell, conical nut, coupling nut l Earthing crown L l 2) l Hexagonal nut l l l l Surface treatment (µm) chrome I l Material (Standard) nickel gold Aluminium alloy (AA 6262A or AA 6023) – 5 – Brass (UNS C 38500) 0.3 – – Aluminium alloy (AA 6262A or AA 6023) anodized Aluminium alloy (AA 6262A or AA 6023) – 14 – Bronze (UNS C 54400) or special brass – – 1.5 Brass (UNS C 38500) – 3 – Aluminium alloy (AA 6262A or AA 6023) – 5 – l Brass (UNS C 34500) – – 1.0 Female crimp contact l Bronze (UNS C 54400) – – 1.5 Clips l Cu-Be or special steel Insulator l PEEK Ratchet l Special PEEK Male crimp contact O-ring Sealing resin l l EPDM (HYl) l Silicone l l l l l FPM/FKM (Viton®) l l without treatment Epoxy (Araldite®) (HEl) l Silicone (Elastosil®) (HYl) Cable rear seal l Fluorosilicone Spring l Stainless steel Note: standards for surface treatment are as follows: chrome-plated SAE AMS 2460; nickel-plated SAE AMS QQ N 290 or MIL DTL 32119; gold-plated ISO 27874. 1) X = Nickel-plated aluminium alloy (standard). C = Chrome-plated brass. L = Anodized aluminium. I = NiCorAITM Nickel fluorocarbon polymer aluminium alloy. 2) anthracite colour. l First choice alternative   l Special order alternative Electrical performance Characteristics Value IEC international MIL-spec tests Insulation resist. (at ambient temp.) 1) > 1012 Ω, > 1010 Ω (after humidity) IEC 60512-2 test 3a EIA-364-21 Dielectric withstanding volt. (sea level) See table pages 23 to 28 IEC 60512-2 test 4a EIA-364-20 Contact resistance 3) See table below IEC 60512-2 test 2a EIA-364-06 Current rating See insulator configuration pages 23 to 28 IEC 60512-3 test 5a < 1.5m Ω IEC 60512-2-6 Shell to shell conductivity 2) Shielding effectiveness, low frequency 2) Shielding effectiveness, high frequency 2) EIA-364-83 ≥ 80 dB up to 1GHz EIA-364-66 ≥ 70 dB (3GHz), ≥ 58 dB (6GHz), ≥ 40 dB (10GHz) EIA-364-66 Contact resistance 3) IEC 60512-2 test 2a Value 0.5 0.7 0.9 1.3 4.0 5.0 6.0 8.0 ø A (mm) ≤ 8.3 ≤ 5.7 ≤ 4.2 ≤ 2.9 ≤ 0.3 ≤ 0.25 ≤ 0.2 ≤ 0.2 mΩ Note: 1) after humidity test: 21 days at 95% RH according to IEC 60068-2. Insulation resistance measured between the 2) no shell to shell conductivity for anodized aluminium versions (shielding and conductivity values do not apply). 3) after 3000 mating cycles and the salt spray test according to IEC 60512-6 test 11 f. contacts and contact/shell. 2 www.lemo.com ® ® Mechanical performance Characteristics Value IEC international 3000 cycles Endurance Gunfire vibration Vibration-Sine 1) 2) Vibration-Random 2) IEC 60512-5 test 9a MIL-spec tests EIA-364-09 25 to 2000 Hz, 3 axis (Apache helicopter) MIL-STD-810F method 519.5 30 g, 3 axis, 12 hr MIL-STD-202 method 204-G 50-2000 Hz, 37.8 g rms-3 axes; 4h amb IEC 60512-6-4 EIA-364-28 test cond. V letter I Shock 2) 300 g - 3 msec IEC 60512-6-3 EIA-364-27 condition D Acceleration 50 g acceleration Torque See table below MIL-STD-1344 - 2011-1, A Note: 1) amplitude: 30g. Frequency: 10 to 2000 Hz. Time per axis: 4 hours (X, Y, Z). 2) no signal discontinuity above 1 µs. Plug mating / unmating torque Series Coupling torque tightning (N.cm) Coupling torque untightning (N.cm) Series Coupling torque tightning (N.cm) Coupling torque untightning (N.cm) MM 8 4 TM 26 30 0M 4 5 4M 26 25 1M 10 11 LM 48 43 2M 20 14 5M 91 54 3M 34 29 Note: indicative values, tightening torque may vary depending on insert configuration. Environmental performance Characteristics Value IEC international MIL-spec tests Standard models operating temperature (mated) -55°C/+200°C (shell material code C + Silicone O-ring) Ingress protection index (mated) IP68 (at 2 m, 15Hr) Fungus Satisfied - by material analysis MIL-STD 810F-508.5 Flammability 60 sec. front and back face EIA-364-104A Fluid contamination 1) Fuels, gasoline, hydraulic oils, solvents, de-icing MIL-STD-810F method 504 Sand and dust 2) 6 hr, 55°C, blowing < 150 µm dust MIL-STD 810F-510.4 Lightning strike 10 K amps - 6 times EIA-364-75 Altitude-low temp 3) -65°C; 40’000 feet and 400 VAC EIA-364-105A 48 hours (shell material code X/L) IEC 60512-6 test 11f EIA-364-26 500 hours (shell material code I) IEC 60512-6 test 11f EIA-364-26 > 1000 hours (shell material code C) IEC 60512-6 test 11f EIA-364-26 Thermal shock (standard models) 5 cycles: -65°C to +150°C IEC 60512-11-4 EIA-364-32 test condition IV Altitude immersion No moisture on contacts EIA-364-03 Humidity 21 days at 95% IEC 60068-2 EIA-364-31 method IV Safety IP2X finger protection for high power connectors IEC 60529 Salt fog 4) -20°C/+200°C (shell material code I/X + FPM O-ring) IEC 60529 Note: 1) connectors immersed at both 70°C and 25°C according to specification. Connectors are then inspected, no visual signs of damage seen. Fuels: Kerosene, JP4, (Nato F40) at 70°C +/- 2°C. Gasoline: ASTM 4814. Hydraulic oils: Mineral oil based MIL-H-5606. Solvents: Isopropanol. De-icing fluids: 25% ethylene glycol. 2) no signs of damage, connectors opened and closed without difficulty. Dust or sand was not inside connector. 3) wired mated connectors = no voltage breakdown, shell to all contacts (connected together) w/400 VAC after 1 hour at -65° C at 40’000 feet altitude. 4) corrosion resistance. Inspection: salt deposits shall be removed by gentle wash in running water with light brushing using soft brush. www.lemo.com 3 ® ® M series The M Series connector offer a new innovative design for avionics, military, security, motorsport and heavy duty applications. When selected in one of the high-strength aluminium options, this connector is one of the lightest and most compact of the LEMO product line. A one-grip ratchet locking system enables quick and secure coupling of the connectors. The arctic grip makes it easy to manipulate the connector while wearing gloves or when the connector is located in a difficult to access area. Features: – Ratchet-coupling mechanism (less than 3/4 turn to seat) – Compact design for space savings – Oil and fuel resistant – 360° screening for full EMC shielding – Colour coding / keying – Scoop proof – Threaded for MIL-DTL-38999M (series III) backshell – Lightweight – High vibration and shock resistance – Sealed to IP68 when mated – Standard or reverse gender configuration available – Pin configuration from 2 to 114 contacts Standard models (page 7) Straight plugs FM• Free and fixed sockets Fixed sockets EG• PM• EG• Backshell variant Backshell variant Watertight model (page 13) FG• EC• EC• PH• FX• ED• ED• PB• FW• PE• FA• PF• Fixed socket PT• Vacuumtight model (page 14) HE• High Speed models (page 15) 7 1 8 6 5 PV• Backshell variant Fixed socket HY• USB 2.0 models (page 17) Fibre Optic models (page 18) High Power models (page 20) 2 4 3 4 www.lemo.com ® ® Standard models part numbering system Plug 3 0 5 . X L C F M N . 1 M . Free socket 3 0 5 . X L M T P M N . 1 M . Fixed socket 3 0 5 . X L M E G N . 1 M . Cable group: 1 = For LM.232 configuration (p. 27) Model: (page 7) Alignment key: (page 22) Backshell options: (page 6) Blank = standard B = Ruggedized for heatshrink molded shapes T = Mold stop M = MIL-DTL-38999L shell thread Z = Standard for LM.232 configuration (page 27) Series: (page 7) Insert configuration: (page 23) Housing: X = Nickel-plated aluminium alloy (standard) 1) C = Chrome-plated brass L = Anodized aluminium 3) I = NiCorAITM Nickel fluorocarbon polymer aluminium alloy 2) Contact: (page 30) Insulator: L = PEEK (multipole page 23) R = PEEK (mixed multipole p. 25) FMN.1M.305.XLC = straight plug with key (N), knurled grip, 1M series, multipole type with 5 contacts, outer shell in anthracite nickelplated aluminium alloy, PEEK insulator, male crimp contacts. PMN.1M.305.XLMT = free socket with key (N), knurled grip, 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contacts and mold stop. EGN.1M.305.XLM = fixed socket with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contact. Note: 1) anthracite colour / 48 hours salt fog resistance. 2) anthracite colour / 500 hours salt fog resistance RoHS 2/REACH. 3) these connectors are designed for use with non-shielded cables as anodization is non conductive. Others models part numbering system Watertight (page 13) Vacuumtight (page 14) l High Speed (page 15) USB 2.0 (page 17) Fibre Optic (page 18) l High Power (page 20) l l l l Part section showing internal components Fixed socket 1 2 3 4 5 6 outer shell o-ring hexagonal nut insulator female contact earthing crown 5 4 6 3 2 1 1 3 2 7 5 6 Straight plug 4 1 2 3 4 5 6 7 outer shell insulator male contact rear seal tightening screw ratchet locking nut spring www.lemo.com 5 ® ® Locking nuts options M Series connectors offer 2 different options for coupling nut allowing to adapt ergonomics according to use cases. The Knurled grip is the default choice for most applications as it offers a good level of grip whilst keeping a very compact overall plug diameter. l The Artic grip offers maximum ergonomics enabling easy manipulation even with gloves. l Knurled grip (standard) Arctic grip (variant) Backshell options M Series connectors offers 4 different backshell options allowing for various cable assembly attachments. The standard backshell offers a simple design allowing to either use a crimp ring or a spring for shielding attachment. This is the default option if no specific termination is specified. l The Mold stop offers a special geometry enabling over molding termination for a clean and rugged cable assembly finish. l The Heat shrink molded shape offers the matching geometry to guarantee a perfect fit with heat shrink molded boots (see page 35). l The MIL-DTL-38999M (series III) offers the matching screw geometry allowing the use of standard D38999 compatible backshells. l Mold stop M J øF T øB øB J Inner ø Y øD Inner ø Y X øF øG B M Inner ø Y M 9 K See page 35 for heatshrink boot Series P 1.5 MIL-DTL-38999M (series III) N øD 2 Inner ø Y X e Heatshrink molded shapes øD Standard N Backshell variant dimensions (mm) B D e F G J K M N P X Y Code 1) MM 6.4 5.6 – 7.8 6.0 4.2 0.7 8.8 0.55 5.0 5.8 4.7 – 0M 8.8 8.0 – 10.7 8.4 5.1 0.7 9.7 0.60 5.8 6.7 6.6 – 1M 10.5 9.7 M12x1.0 12.4 10.1 5.1 0.7 8.3 A 2M 14.0 13.0 M15x1.0 15.5 13.4 5.1 0.7 10.1 0.80 5.8 7.1 11.6 B 3M 16.0 15.0 M18x1.0 17.5 15.4 5.1 0.7 10.1 0.80 5.8 7.1 13.6 C TM 17.9 16.7 M18x1.0 19.8 17.1 5.2 0.8 10.6 1.00 5.8 7.6 14.6 C 4M 20.7 19.5 M22x1.0 22.6 19.9 5.2 0.8 10.6 1.00 5.8 7.6 17.6 D LM 23.9 22.7 M25x1.0 25.8 23.1 5.2 0.8 10.6 1.00 5.8 7.6 20.6 E 5M 29.7 28.5 M31x1.0 31.4 28.9 5.2 0.8 10.6 1.00 5.8 7.6 26.6 G 9.7 0.60 5.8 6.7 Note: 1) MIL-DTL-38999M (series III) backshell connector size code (backshell not supplied) (not available in MM and 0M size). 6 www.lemo.com ® ® Standard models Fll Straight plug FMl P øC øA øD L øB Backshell option X FGl P øC ø A1 øD L øB Backshell option X Reference Dimensions (mm) Model Series A A1 B C D L P X Fll MM 11.1 12.0 6.4 10.7 5.6 15.5 5.5 5.8 Fll 0M 13.1 14.4 8.8 12.7 8.0 17.4 3.9 6.7 Fll 1M 14.6 15.9 10.5 14.2 9.7 17.4 3.9 6.7 Fll 2M 17.6 18.9 14.0 17.2 13.0 17.4 3.9 7.1 Fll 3M 19.6 20.9 16.0 19.2 15.0 17.4 3.9 7.1 Fll TM 22.5 23.4 17.9 22.0 16.7 21.0 3.4 7.6 Fll 4M 25.0 25.9 20.7 24.5 19.5 21.0 3.4 7.6 Fll LM 28.5 29.4 23.9 28.0 22.7 21.0 3.4 7.6 Fll 5M 34.0 34.9 29.7 33.5 28.5 21.0 3.4 7.6 Note: B, D and X dimensions are for standard backshell. For different backshell option see page 6. www.lemo.com 7 ® ® Fll Straight plug with square flange (these models are not IP68 due to the absence of panel sealing) FXl L H øD P øC ø A1 øE Backshell option øB N 1.5 øA X øV G K FWl L H P øC ø A2 øE Backshell option øD øA øB N 1.5 X øV K G FAl Non-locking straight plug L H øV Note: for integration in a rackable application please contact us for detailed informations linked to coupling constrains. Reference P øC øD Backshell option øE N øB øA X K G Dimensions (mm) Model Series A A1 A2 B C D E G H K L N P V X Fll MM 21.5 11.1 12.0 6.4 10.7 5.6 9.5 17.0 12.0 1.5 20.3 17.0 5.5 2.7 5.8 Fll 0M 26.9 13.1 14.4 8.8 12.7 8.0 12.2 18.9 15.1 1.5 22.4 20.6 3.9 2.7 6.7 Fll 1M 31.4 14.6 15.9 10.5 14.2 9.7 13.7 18.9 18.3 1.5 22.4 23.8 3.9 3.3 6.7 Fll 2M 34.6 17.6 18.9 14.0 17.2 13.0 16.7 18.9 20.6 1.5 22.4 26.1 3.9 3.3 7.1 Fll 3M 34.6 19.6 20.9 16.0 19.2 15.0 18.7 18.9 20.6 1.5 22.4 26.1 3.9 3.3 7.1 Fll TM 38.0 22.5 23.4 17.9 22.0 16.7 21.5 22.5 23.0 2.0 27.2 28.5 3.4 3.3 7.6 Fll 4M 40.3 25.0 25.9 20.7 24.5 19.5 24.0 22.5 24.6 2.0 27.2 30.1 3.4 3.3 7.6 Fll LM 43.7 28.5 29.4 23.9 28.0 22.7 27.5 22.5 27.0 2.0 27.2 32.5 3.4 3.3 7.6 Fll 5M 47.0 34.0 34.9 29.7 33.5 28.5 33.0 22.5 29.4 2.0 27.2 37.0 3.4 3.3 7.6 Note: B, D and X dimensions are for standard backshell. For different backshell option see page 6. 8 www.lemo.com ® ® EGl Fixed socket, nut fixing Ls/Lr G S1 P e øC 5.4 4.5 S2 D E maxi Ts/Tr Crimp contacts Reference Print contacts Dimensions (mm) Model Series C D e E G Ls Lr P S1 S2 Ts Tr EGl MM 10.7 5.2 M7x0.5 4.5 13.8 15.0 15.0 3.7 6.3 9.0 10.7 – EGl 0M 12.7 6.8 M9x0.6 5.0 16.8 18.3 18.3 5.3 8.2 11.0 12.4 – 9.5 13.0 12.4 EGl 1M 14.2 6.8 M11x1.0 4.5 16.8 18.3 18.3 5.3 EGl 2M 17.2 6.8 M14x1.0 4.5 16.8 18.3 18.3 5.3 12.5 17.0 12.4 – EGl 3M 19.2 6.8 M16x1.0 4.0 16.8 18.3 18.3 5.3 14.5 19.0 12.4 – EGl TM 22.0 9.4 M18x1.0 4.0 18.9 20.0 21.9 7.9 16.5 22.0 11.5 13.4 EGl 4M 24.5 9.4 M21x1.0 4.0 18.9 20.0 21.9 7.9 19.5 25.0 11.5 13.4 Panel cut-out (page 41). EGl LM 28.0 9.4 M24x1.0 4.0 18.9 20.0 21.9 7.9 22.5 30.0 11.5 13.4 PCB drilling pattern (page 42). EGl 5M 33.5 9.4 M30x1.0 4.0 18.9 20.0 21.9 7.9 28.5 36.0 11.5 13.4 Note: Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). – ECl Fixed socket with two nuts (these models are not IP68 due to the absence of panel sealing) Ls/Lr S1 5.4 e E maxi S2 øA P øB øC S3 4.5 G Crimp contacts Reference Print contacts Dimensions (mm) Model Series A B C E e G Ls Lr P S1 S2 S3 ECl MM 14.0 2.85 13.5 5.0 M10x0.50 13.8 15.0 15.0 3.7 9.0 11.0 12.0 ECl 0M 17.0 4.72 18.2 5.0 M13x0.75 16.8 18.3 18.3 5.3 11.5 14.0 16.0 ECl 1M 18.0 5.95 19.2 5.0 M14x1.00 16.8 18.3 18.3 5.3 12.5 16.0 17.0 ECl 2M 21.0 8.95 21.5 4.0 M17x1.00 16.8 18.3 18.3 5.3 15.5 18.0 19.0 ECl 3M 23.0 10.95 25.0 4.0 M19x1.00 16.8 18.3 18.3 5.3 17.5 20.0 22.0 ECl TM 27.0 12.30 28.0 2.5 M22x1.00 18.9 20.0 21.9 7.9 20.5 23.0 25.0 ECl 4M 29.0 13.95 34.0 2.5 M24x1.00 18.9 20.0 21.9 7.9 22.5 25.0 30.0 Panel cut-out (page 41). ECl LM 33.0 17.95 36.0 2.5 M28x1.00 18.9 20.0 21.9 7.9 26.5 29.0 32.0 PCB drilling pattern (page 42). ECl 5M 38.0 22.90 41.0 2.5 M33x1.00 18.9 20.0 21.9 7.9 31.5 34.0 37.0 Note: Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). www.lemo.com 9 ® ® EDl Fixed socket with square flange Ls/Lr K P H 5.4 øC øA øB N 4.5 øV Ts/Tr G Crimp contacts Print contacts Dimensions (mm) Reference Model Series A B C G H K Ls Lr N P Ts Tr V EDl MM 18.6 4.70 10.7 13.8 9.5 1.5 17.0 17.0 14.5 3.7 4.1 – 2.7 EDl 0M 20.6 4.72 12.7 14.3 11.0 1.5 18.3 18.3 16.0 5.3 4.9 – 2.7 EDl 1M 23.8 5.95 14.2 14.3 12.9 1.5 18.3 18.3 18.4 5.3 4.9 – 3.3 EDl 2M 26.9 8.95 17.2 14.3 15.1 1.5 18.3 18.3 20.6 5.3 4.9 – 3.3 EDl 3M 29.0 10.95 19.2 14.3 16.6 1.5 18.3 18.3 22.1 5.3 4.9 – 3.3 EDl TM 31.4 12.30 22.0 16.5 18.3 2.0 20.0 21.9 23.8 7.9 4.4 6.3 3.3 EDl 4M 34.6 13.95 24.5 16.5 20.6 2.0 20.0 21.9 26.1 7.9 4.4 6.3 3.3 Panel cut-out (page 41). EDl LM 38.0 17.95 28.0 16.5 23.0 2.0 20.0 21.9 28.5 7.9 4.4 6.3 3.3 PCB drilling pattern (page 42). EDl 5M 43.7 22.90 33.5 16.5 27.0 2.0 20.0 21.9 32.5 7.9 4.4 6.3 3.3 Note: Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). PEl Fixed socket, nut fixing (back panel mounting) Ls/Lr S1 e øA øB P øF øC øD M Backshell option X 1.5 S2 E maxi R Reference Dimensions (mm) Model Series A B C D E F e Ls Lr Ls1) Lr1) M P R S1 S2 X PEl MM 14.0 6.4 13.8 5.6 4.0 7.8 M10x0.50 12.6 12.6 – – 8.8 3.7 10.5 9.0 11.0 5.8 PEl 0M 17.0 8.8 16.8 8.0 5.0 10.7 M13x0.75 15.9 15.9 – – 9.7 5.3 13.8 11.5 14.0 6.7 PEl 1M 18.0 10.5 17.8 9.7 5.0 12.4 M14x1.00 15.9 15.9 17.4 17.4 9.7 5.3 13.8 12.5 16.0 6.7 PEl 2M 21.0 14.0 20.8 13.0 5.0 15.5 M17x1.00 15.9 15.9 17.4 17.4 10.1 5.3 13.8 15.5 18.0 7.1 PEl 3M 23.0 16.0 22.8 15.0 5.0 17.5 M19x1.00 15.9 15.9 17.4 17.4 10.1 5.3 13.8 17.5 20.0 7.1 PEl TM 27.0 17.9 25.8 16.7 4.0 19.8 M22x1.00 18.9 19.5 19.2 21.1 10.6 7.9 16.9 20.5 23.0 7.6 PEl 4M 29.0 20.7 27.8 19.5 4.0 22.6 M24x1.00 18.9 19.5 19.2 21.1 10.6 7.9 16.9 22.5 25.0 7.6 PEl LM 33.0 23.9 31.8 22.7 4.0 25.8 M28x1.00 18.9 19.5 19.2 21.1 10.6 7.9 16.9 26.5 29.0 7.6 PEl 5M 38.0 29.7 36.8 28.5 4.0 31.4 M33x1.00 18.9 19.5 19.2 21.1 10.6 7.9 16.9 31.5 34.0 7.6 Panel cut-out (page 41). Note: Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). This model is not available with standard backshell option (backshell not supplied). For different backshell option see page 6. 1) Dimensions for MIL-DTL-38999M (series III) backshell connector size code (backshell not supplied) (not available in MM and 0M size). 10 www.lemo.com ® ® Fixed socket with square flange (these models are not IP68 due to the absence of panel sealing) M G 1.5 P øF øB øE Backshell option øC øA N øD PFl X øV H K Ls/Lr Reference Dimensions (mm) Model Series A B C D E F G H K Ls Lr Ls1) Lr1) M N P V X PFl MM 18.6 6.4 10.7 5.6 7.8 7.8 12.3 9.5 1.5 15.6 15.6 – – 8.8 14.5 3.7 2.7 5.8 PFl 0M 20.6 8.8 12.7 8.0 10.7 10.7 12.8 11.0 1.5 15.9 15.9 – 9.7 16.0 5.3 2.7 6.7 PFl 1M 23.8 10.5 14.2 9.7 12.4 12.4 12.8 12.9 1.5 15.9 15.9 17.5 17.5 9.7 18.4 5.3 3.3 6.7 PFl 2M 26.9 14.0 17.2 13.0 15.5 15.5 12.8 15.1 1.5 15.9 15.9 17.5 17.5 10.1 20.6 5.3 3.3 7.1 PFl 3M 29.0 16.0 19.2 15.0 17.5 17.5 12.8 16.6 1.5 15.9 15.9 17.5 17.5 10.1 22.1 5.3 3.3 7.1 PFl TM 31.4 17.9 22.0 16.7 19.8 19.8 14.5 18.3 2.0 18.9 19.5 19.2 21.1 10.6 23.8 7.9 3.3 7.6 PFl 4M 34.6 20.7 24.5 19.5 22.6 22.6 14.5 20.6 2.0 18.9 19.5 19.2 21.1 10.6 26.1 7.9 3.3 7.6 PFl LM 38.0 23.9 28.0 22.7 25.8 25.8 14.5 23.0 2.0 18.9 19.5 19.2 21.1 10.6 28.5 7.9 3.3 7.6 PFl 5M 47.0 29.7 33.5 28.5 33.0 31.4 14.5 29.4 2.0 18.9 19.5 19.2 21.1 10.6 37.0 7.9 3.3 7.6 – Panel cut-out (page 41). Note: Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). This model is not available with standard backshell variant (backshell not supplied). For different backshell option see page 6. 1) Dimensions for MIL-DTL-38999M (series III) backshell connector size code (backshell not supplied) (not available in MM and 0M size). Free socket Ls/Lr øC øD P øB Backshell option øA X Reference Ls/Lr P øB Backshell option ø A1 PHl øC PMl øD Pll X Dimensions (mm) Model Series A A1 B C D Ls Lr Ls1) Lr1) Ls2) Lr2) P X Pll MM 11.1 12.0 6.4 10.7 5.6 15.6 15.6 15.6 15.6 – – 3.7 5.8 Pll 0M 13.1 14.4 8.8 12.7 8.0 18.9 18.9 18.9 18.9 – – 5.3 6.7 Pll 1M 14.6 15.9 10.5 14.2 9.7 18.9 18.9 18.9 18.9 18.9 18.9 5.3 6.7 Pll 2M 17.6 18.9 14.0 17.2 13.0 18.9 18.9 18.9 18.9 18.9 18.9 5.3 7.1 Pll 3M 19.6 20.9 16.0 19.2 15.0 18.9 18.9 18.9 18.9 18.9 18.9 5.3 7.1 Pll TM 22.5 23.4 17.9 22.0 16.7 20.6 22.5 20.6 20.6 20.6 21.1 7.9 7.6 Pll 4M 25.0 25.9 20.7 24.5 19.5 20.6 22.5 20.6 20.6 20.6 21.1 7.9 7.6 Pll LM 28.5 29.4 23.9 28.0 22.7 20.6 22.5 20.6 20.6 20.6 21.1 7.9 7.6 Pll 5M 34.0 34.9 29.7 33.5 28.5 20.6 22.5 20.6 20.6 20.6 21.1 7.9 7.6 Note: Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). B, D and X dimensions are for standard backshell. For different backshell option see page 6. 1) Dimensions for mold stop and heatshrink molded shapes backshell option. 2) Dimensions for MIL-DTL-38999M (series III) backshell connector size code (backshell not supplied) (not available in MM and 0M size). www.lemo.com 11 ® ® Pll Fixed socket with antivibration flange (these models are not IP68 due to the absence of panel sealing) PBl Ls/Lr P K øC B1 øB H Backshell option øD N X 2.7 (MM) 3.3 (0M-5M) G PVl Ls/Lr øA P øC Backshell option øD K øB øC N1 X H1 ø 2.7 (MM-0M) ø 3.3 (1M-5M) G PTl Ls/Lr øA Backshell option P øD K1 øB øC øC N1 X H1 Reference M2.5 (MM-0M) M3.0 (1M-5M) G1 Dimensions (mm) Model Series A B B1 C D G G1 H H1 K K1 N N1 P Ls Lr Ls1) Lr1) Ls2) Lr2) X Pll MM 21.5 6.4 21.0 11.3 5.6 6.7 6.0 16.2 12.0 1.5 3.0 12.5 17.0 3.7 15.6 15.6 15.6 15.6 – – 5.8 Pll 0M 26.9 8.8 27.0 14.5 8.0 8.3 7.3 21.4 15.1 2.0 4.0 16.0 20.6 5.3 18.9 18.9 18.9 18.9 – – 6.7 Pll 1M 31.4 10.5 29.0 16.5 9.7 8.3 7.3 23.4 18.3 2.0 4.0 18.0 23.8 5.3 18.9 18.9 18.9 18.9 18.5 18.5 6.7 Pll 2M 34.6 14.0 32.0 19.5 13.0 8.3 7.3 26.4 20.6 2.0 4.0 21.0 26.1 5.3 18.9 18.9 18.9 18.9 18.5 18.5 7.1 Pll 3M 38.0 16.0 35.0 21.5 15.0 8.3 7.3 29.0 23.0 2.0 4.0 23.0 28.5 5.3 18.9 18.9 18.9 18.9 18.5 18.5 7.1 Pll TM 40.3 17.9 38.5 24.5 16.7 11.0 10.0 32.5 24.6 2.0 4.0 26.0 30.1 7.9 20.6 22.5 20.6 20.6 20.2 21.1 7.6 Pll 4M 43.7 20.7 41.0 27.5 19.5 11.0 10.0 35.0 27.0 2.0 4.0 29.0 32.5 7.9 20.6 22.5 20.6 20.6 20.2 21.1 7.6 Pll LM 47.1 23.9 44.0 30.5 22.7 11.0 10.0 38.0 29.4 2.0 4.0 32.0 34.9 7.9 20.6 22.5 20.6 20.6 20.2 21.1 7.6 Pll 5M 54.9 29.7 51.0 37.5 28.5 11.0 10.0 45.0 34.9 2.0 4.0 39.0 40.4 7.9 20.6 22.5 20.6 20.6 20.2 21.1 7.6 Note: Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). B, D and X dimensions are for standard backshell. For different backshell option see page 6. 1) Dimensions for mold stop and heatshrink molded shapes backshell option. 2) Dimensions for MIL-DTL-38999M (series III) backshell connector size code (backshell not supplied) (not available in MM and 0M size). Panel cut-out (page 41). 12 www.lemo.com ® ® Watertight model (unmated) H E Part numbering system Fixed socket 3 0 5 . X L N P H E N . 1 M . Model: HE Alignment key: (page 22) Series: (see below) Potting: P = Epoxy Insert configuration: (page 23) Contact: (page 30) Housing: C = Chrome-plated brass X = Nickel-plated aluminium alloy 1) Insulator: L = PEEK (multipole page 23) R = PEEK (mixed multipole p. 25) HEN.1M.305.XLNP = fixed socket, nut fixing, with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female print contacts, watertight. Note: 1) anthracite colour / 48 hours salt fog resistance. Environmental performance Characteristics Operating temperature Value Standard -20°C/+80°C – Value Characteristics Unmated ingress protection IP68 (at 2 m, 15 Hr) Standard IEC 60529 HEl Fixed socket, nut fixing, key (N) or keys (H, P, R, S, T, U, V, W and X), for printed circuit, watertight (back panel mounting) Ls/Lr P e H øA S1 øC 0.8 E maxi S2 R N Reference Dimensions (mm) Model Series A C e E H Ls Lr N P R S1 S2 HEl MM 14.0 13.8 M10x0.50 4.0 5.08 20.4 20.4 15.3 3.7 10.5 9.0 11.0 HEl 0M 17.0 16.8 M13x0.75 5.0 5.08 20.8 21.0 16.8 5.3 13.8 11.5 14.0 HEl 1M 18.0 17.8 M14x1.00 5.0 7.62 20.8 21.0 16.8 5.3 13.8 12.5 16.0 HEl 2M 21.0 20.8 M17x1.00 5.0 8.89 20.8 21.0 16.8 5.3 13.8 15.5 18.0 HEl 3M 23.0 22.8 M19x1.00 5.0 10.16 20.8 21.0 16.8 5.3 13.8 17.5 20.0 HEl TM 27.0 25.8 M22x1.00 4.0 12.70 24.6 24.6 19.9 7.9 16.9 20.5 23.0 Panel cut-out (page 41). HEl 4M 29.0 27.8 M24x1.00 4.0 13.97 24.6 24.6 19.9 7.9 16.9 22.5 25.0 PCB drilling pattern (page 42). HEl LM 33.0 31.8 M28x1.00 4.0 16.51 24.6 24.6 19.9 7.9 16.9 26.5 29.0 HEl 5M 38.0 36.8 M33x1.00 4.0 20.32 24.6 24.6 19.9 7.9 16.9 31.5 34.0 Note: in MM series, the four external earth contacts are shorter. Ls = standard gender, Lr = reverse gender (see page 22 for standard/reverse gender options). www.lemo.com 13 ® ® Vacuumtight model (unmated) H Y Part numbering system Fixed socket 3 0 5 . X L H W G E H Y N . 1 M . O-ring material: E = EPDM PCB fixation: G = 4 ground pins Z = 4 threaded holes Model: HY Series: (see below) Potting: R = Silicone W = Silicone 100% vacuum tested Insert configuration: (page 23) Contact: H = female/male print (page 30) Housing: C = Chrome-plated brass X = Nickel-plated aluminium alloy 1) Insulator: L = PEEK (multipole page 23) R = PEEK (mixed multipole p. 25) Alignment key: (page 22) HYN.1M.305.XLHWGE = fixed socket, nut fixing, with key (N), 1M series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female print contacts, vacuumtight, with 4 ground pins and a EPDM o-ring. Note: 1) anthracite colour / 48 hours salt fog resistance. Environmental performance Characteristics Operating temperature Value Value Characteristics Standard -55°C/+150°C – < 10-7 mbar.l.s-1 Leakage rate Standard IEC 60512-7 test 14 b HYl Fixed socket, nut fixing, key (N) or keys (H, P, R, S, T, U, V, W and X), for printed circuit, vacuumtight (back panel mounting) L H Detail A J e E maxi øF S1 øA 1 øC 3 øV S2 R N Reference PCB fixation (Detail A) Dimensions (mm) Model Series A C e E F H J L N R S1 S2 V 14.0 13.8 M10x0.50 4.0 5.7 6.35 3.0 19.1 16.1 10.5 9.0 11.0 M2x0.4 HYl 0M 17.0 16.8 M13x0.75 5.3 7.8 8.89 5.0 22.4 19.4 13.8 11.5 14.0 M2x0.4 HYl 1M 18.0 17.8 M14x1.00 5.3 8.8 10.16 5.5 22.4 19.4 13.8 12.5 16.0 M2x0.4 HYl 2M 21.0 20.8 M17x1.00 5.3 11.8 11.43 7.0 22.4 19.4 13.8 15.5 18.0 M2x0.4 HYl 3M 23.0 22.8 M19x1.00 5.3 13.8 12.70 8.0 22.4 19.4 13.8 17.5 20.0 M2x0.4 HYl TM 27.0 25.8 M22x1.00 4.5 15.2 13.97 8.7 26.0 23.0 17.4 20.5 23.0 M3x0.5 HYl 4M 29.0 27.8 M24x1.00 4.5 16.8 15.24 9.5 26.0 23.0 17.4 22.5 25.0 M3x0.5 HYl LM 33.0 31.8 M28x1.00 4.5 20.8 17.78 11.5 26.0 23.0 17.4 26.5 29.0 M3x0.5 HYl 5M 38.0 36.8 M33x1.00 4.5 25.9 21.59 14.0 26.0 23.0 17.4 31.5 34.0 M3x0.5 Z 3.5 3.8 0.9 V HYl MM G Panel cut-out (page 41). PCB drilling pattern (page 44). Note: special anti-vibration thread to be used with standard metric screws (not supplied). 14 www.lemo.com ® 2 M 5 1 4 ® High Speed models Those configurations meet the Ethernet 10Gb/s data transfer requirements (CAT6, up to 250 MHz). Part numbering system Plug 5 1 4 . X L C T 6 F M N . 2 M . Free socket 5 1 4 . X L M T 6 P M N . 2 M . Fixed socket 5 1 4 . X L N P H E N . 2 M . Model: (page 15) Alignment key: (page 22) Series: 2M Maximum cable outer ø: 6, 7 and 8 (mm) Insert configuration: 514 (page 25) T = Mold stop P = Potted (HEl model only) Housing: X = Nickel-plated aluminium alloy 1) I = NiCorAITM Nickel fluorocarbon polymer aluminium alloy 2) 3) Contact: crimp or print (page 30) Insulator: L = PEEK FMN.2M.514.XLCT6 = straight plug with key (N), knurled grip, 2M series, multipole type with 8 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts. PMN.2M.514.XLMT6 = free socket with key (N), knurled grip, 2M series, multipole type with 8 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contacts and mold stop. HEN.2M.514.XLNP = fixed socket, nut fixing, with key (N), 2M series, multipole type with 8 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female print contacts, watertight. Note: 1) anthracite colour / 48 hours salt fog resistance. 2) anthracite colour / 500 hours salt fog resistance RoHS 2/REACH. 3) NiCorAlTM nickel plating is not allowed with hermetic models. FMl.2M.514 Straight plug, key (N) or keys (P and U) with knurled grip and mold stop 30 ø 17.2 ø 17.6 ø 13 0.5 ø 18.9 3.9 ø 17.2 12.6 ø 14 ø 15.5 Inner ø 11.6 1.5 9.6 FGl.2M.514 Straight plug, key (N) or keys (P and U) with arctic grip and mold stop 30 12.6 3.9 0.5 ø 13 ø 14 ø 15.5 Inner ø 11.6 1.5 9.6 www.lemo.com 15 ® 2 M 5 1 4 ® PEl.2M.514 Fixed socket, key (N) or keys (P and U) with mold stop (back panel mounting) 31.5 5.3 12.6 S 18 5 maxi ø 13 0.5 Inner ø 11.6 ø 21 M17x1 15.6 ø 14 ø 15.5 ø 20.8 S 15.5 13.8 1.5 PFl.2M.514 Fixed socket with square flange, key (N) or keys (P and U) with mold stop Note: (this model is not IP68 due to the absence of panel sealing) 12.8 1.5 5.3 Inner ø 11.6 0.5 15.1 ø 13 ø 14 ø 17.2 15.6 ø 15.5 ø 3.3 17.2 ø 26.9 20.6 1.5 12.6 PMl.2M.514 Free socket, key (N) or keys (P and U) with knurled grip and mold stop 31.5 ø 13 0.5 ø 17.6 ø 14 ø 15.5 5.3 ø 17.2 12.6 Inner ø 11.6 1.5 9.6 PHl.2M.514 Free socket, key (N) or keys (P and U) with arctic grip and mold stop ø 13 0.5 ø 18.9 ø 17.2 5.3 ø 14 ø 15.5 31.5 12.6 Inner ø 11.6 1.5 9.6 HEl.2M.514 Fixed socket, nut fixing, key (N) or keys (P and U), printed circuit, watertight, (back panel mounting) 21 5.3 8.89 ø 20.8 ø 21 S 15.5 M17x1 0.8 5 maxi S 18 13.8 16.8 Note: see page 41 for panel cut-out and page 42 for PCB drilling pattern. For HEl environmental performance see page 13. 16 www.lemo.com ® L M U 2 A ® USB 2.0 models Those configurations meet the USB 2.0 (480 Mb/s) data transfer requirements using USB Type A inserts. FMl.LM.U2A.XPAT Straight plug, key (W) or keys (R and H) with knurled grip and mold stop 31.6 ø 28 ø 28.5 ø 28 ø 29.4 ø 22.7 ø 25.8 3.4 ø 23.9 10.6 1.5 7.6 FGl.LM.U2A.XPAT Straight plug, key (W) or keys (R and H) with arctic grip and mold stop 31.6 ø 22.7 ø 25.8 3.4 ø 23.9 10.6 1.5 7.6 EGl.LM.U2A.XPP Fixed socket, female to female, nut fixing, key (W) or keys (R and H) 40.5 7.9 ø 28 M 24 x 1 S 22.5 S 30 4 maxi 9.4 31 EGl.LM.U2A.XPL Fixed socket, nut fixing, key (W) or keys (R and H) 18.9 7.9 S 30 ø 28 M 24 x 1 S 22.5 4 maxi 9.4 Note: see page 41 for panel cut-out. www.lemo.com 17 ® ® Fibre Optic models Fll Straight plug (contact to be ordered separately, see page 31) FMl L øA øC P S2 FGl S1 L S2 Part number S1 Dimensions (mm) A A1 C L P S1 S2 FlS.2M.03A.XLZTllZ 17.6 18.9 17.2 100.6 3.9 14.0 14.0 FlN.3M.95B.XLCTllZ 19.6 20.9 19.2 103.3 3.9 16.0 16.0 FlW.5M.03W.XLZTllZ 34.0 34.9 33.5 148.4 3.4 29.0 29.0 Pll øC ø A1 P Note: ll cable adaptor diameter defined upon request. The bend relief must be ordered separately (see page 37). Free socket (contact to be ordered separately, see page 31) PMl L øA øC P S2 PHl S1 L øA øC P S2 Part number S1 Dimensions (mm) A A1 C L P S1 S2 PlS.2M.03A.XLZTllZ 17.6 18.9 17.2 105.8 5.3 16.0 14.0 PlN.3M.95B.XLMTllZ 19.6 20.9 19.2 113.3 5.3 18.0 16.0 PlW.5M.03W.XLZTllZ 34.0 34.9 33.5 155.2 7.9 32.0 29.0 Note: ll cable adaptor diameter defined upon request. The bend relief must be ordered separately (see page 37). 18 www.lemo.com ® ® EGl Fixed socket, nut fixing (contact to be ordered separately, see page 31) Part number L S1 e øC P S2 D E maxi Dimensions (mm) C D e E L P S1 S2 EGS.2M.03A.XLZ 17.2 6.8 M14x1.0 4.5 28.9 5.3 12.5 17.0 EGN.3M.95B.XLM 19.2 6.8 M16x1.0 4.0 32.2 5.3 14.5 19.0 EGW.5M.03W.XLZ 33.5 9.4 M30x1.0 4.0 30.8 7.9 28.5 36.0 Panel cut-out (page 41). EDl Fixed socket with square flange (contact to be ordered separately, see page 31) Part number L P øC K øA øB N Dimensions (mm) A B C G H K L N P EDS.2M.03A.XLZ 26.9 8.95 17.2 12.8 15.1 1.5 28.9 20.6 5.3 EDN.3M.95B.XLM 29.0 10.95 19.2 12.8 16.6 1.5 32.2 22.1 5.3 EDW.5M.03W.XLZ 43.7 22.90 33.5 14.5 27.0 2.0 30.8 32.5 7.9 Panel cut-out (page 41). H ø 3.3 G www.lemo.com 19 ® ® High Power models Part numbering system Plug Free socket Fixed socket F G S . 3 M . H 1 4 . X L M P H S . 3 M . H 1 4 . X L C M P E S . 3 M . H 1 4 . X L C T H Model: (page 20) Variant: H = Watertight (PEl model only) Alignment key: (page 22) S, T, X or V (reverse gender only) Backshell options: (page 6) Blank = standard B = Ruggedized for heatshrink molded shapes T = Mold stop M = MIL-DTL-38999L shell thread Series: (page 20) Insert configuration: (page 28) Housing: C = Chrome-plated brass X = Nickel-plated aluminium alloy 1) I = NiCorAITM Nickel fluorocarbon polymer aluminium alloy 2) Contact: (reverse gender only) C = Male to crimp M = Female to crimp Insulator: L = PEEK FGS.3M.H14.XLM = straight plug with key (S), knurled grip, 3M series, high power contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contacts. PHS.3M.H14.XLCM = free socket with key (S), knurled grip, 3M series, high power contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts, MIL-DTL-38999L shell thread. PES.3M.H14.XLCTH = fixed socket with key (S), 3M series, high power contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, male crimp contacts, mold stop, watertight. Note: 1) anthracite colour / 48 hours salt fog resistance. 2) anthracite colour / 500 hours salt fog resistance RoHS 2/REACH. FMl / FGl Straight plug FXl / FWl / FAl Straight plug with square flange U øB øB U Reference øB (mm) Dimensions U (mm) Backshell options Standard Code B / T Code M Reference øB (mm) Dimensions U (mm) Backshell options Standard Code B / T Code M 3M.H14 11.0 5.5 2.5 3.6 3M.H14 11.0 0.5 – – TM.H15 12.3 5.5 2.5 4.1 TM.H15 12.3 – – – 4M.H16 14.0 5.5 2.5 4.1 4M.H16 14.0 – – – LM.H18 18.0 10.0 7.0 8.6 LM.H18 18.0 3.8 0.8 2.4 5M.H18 22.9 10.0 7.0 8.6 5M.H18 22.9 3.8 0.8 2.4 – – – – – – 5M.H34 / G33 22.9 Note: all others dimensions can be found on standard models (page 7). 5M.H34 / G33 22.9 Note: all others dimensions can be found on standard models (page 8). 20 www.lemo.com ® ® EGl / ECl Fixed socket EDl Fixed socket øB U Dim. (mm) ø B Reference U 3M.H14 11.0 11.7 TM.H15 12.3 13.1 4M.H16 14.0 13.1 LM.H18 5M.H18 U Dim. (mm) ø B U 3M.H14 11.0 14.2 TM.H15 12.3 15.5 4M.H16 14.0 15.5 18.0 17.6 LM.H18 18.0 20.0 22.9 17.6 5M.H18 22.9 20.0 øB Reference 5M.H34 / G33 22.9 10.6 5M.H34 / G33 22.9 13.0 Note: all others dimensions can be found on standard models (page 9). Note: all others dimensions can be found on standard models (page 10). PEl / PFl Fixed socket PMl / PHl Free socket U Reference øB (mm) øB øB U Dimensions U (mm) Backshell options Code B / T Code M Reference øB (mm) Dimensions U (mm) Backshell options Standard Code B / T Code M 3M.H14 11.0 2.5 2.1 3M.H14 11.0 2.5 – 0.6 TM.H15 12.3 1.9 1.9 TM.H15 12.3 1.9 0.8 1.9 4M.H16 14.0 1.9 1.9 4M.H16 14.0 1.9 0.8 1.9 LM.H18 18.0 6.4 6.4 LM.H18 18.0 6.4 5.3 6.4 5M.H18 22.9 6.4 6.4 5M.H18 22.9 6.4 5.3 6.4 – – – – – 5M.H34 / G33 22.9 5M.H34 / G33 22.9 Note: all others dimensions can be found on standard models (p. 10, 11). Note: all others dimensions can be found on standard models (p. 11). PBl / PVl / PTl Fixed socket with antivibration flange øB U Reference øB (mm) Dimensions U (mm) Backshell options Standard Code B / T Code M 3M.H14 11.0 2.5 – 1.0 TM.H15 12.3 1.9 0.8 1.9 4M.H16 14.0 1.9 0.8 1.9 LM.H18 18.0 6.4 5.3 6.4 5M.H18 22.9 6.4 5.3 6.4 – – – 5M.H34 / G33 22.9 Note: all others dimensions can be found on standard models (p. 12). www.lemo.com 21 ® ® Alignment key Alignment key and Polarized keying system MM to 3M Front view of a socket Model M series connector model part numbers are composed of three letters. The LAST LETTER indicates the keys corresponding to a particular contact type. For example, straight plugs with H, N, P, R, U or W keys, are fitted with male contacts; whereas with S, T, V or X keys, plugs are fitted with female contacts. Sockets with H, N, P, R, U or W keys, are fitted with female contacts; whereas with S, T, V or X keys, sockets are fitted with male contacts. ll β N blue P yellow U green ll S red T orange Model ll Colour code ll γ ll α β W blue ll R yellow ll H green ll δ γ TM to 5M Front view of a socket Colour code ll X red ll V orange Contact type Gender Plug Socket standard male female reverse female male Contact type Gender Plug standard male Socket female Angles Nb of keys 3 3 β γ 165° 30° 150° 60° 130° 100° 155° 50° 135° 90° Nb of keys 5 Angles α β γ δ 95° 115° 35° 25° 105° 115° 30° 20° 120° 95° 25° 45° reverse female male 5 100° 125° 40° 20° 110° 120° 35° 25° Colour coding M Series connector attributes a colour code for each alignment key thus allowing for easy identification of matching plugs and sockets within the system. l l Standard plated versions only have a light colour ring on the plug nut and socket for identification. Anodized aluminum version are proposed with the complete body matching the corresponding colour code / key. Colour code Standard nickel-plated aluminium version Anodized aluminium version 22 www.lemo.com ® ® Insert configuration Contact type 1M 2M 3M 2 303 3 0.5 l l 28-30-32 1.15 0.95 3.0 304 4 0.5 l l 28-30-32 0.95 0.90 2.0 302 303 3 0.9 l l 20-22-24 1.70 1.40 8.0 304 4 0.7 l l 22-24-26 1.35 0.90 7.0 305 5 0.7 l l 22-24-26 1.25 1.00 6.5 302 2 1.3 l l 16-18-20 1.55 1.10 19.0 303 3 1.3 l l 16-18-20 1.05 0.95 15.5 305 5 0.9 l l 20-22-24 1.30 1.30 9.0 307 7 0.7 l l 22-24-26 1.45 1.20 7.0 308 8 0.7 l l 22-24-26 1.30 1.10 5.0 304 4 1.3 l l 16-18-20 1.55 1.35 15.5 308 8 0.9 l l 20-22-24 1.95 1.10 10.0 310 10 0.9 l l 20-22-24 1.80 1.20 8.0 312 12 0.7 l l 22-24-26 1.65 1.15 7.0 316 16 0.7 l l 22-24-26 1.20 1.00 4.5 319 19 0.7 l l 22-24-26 1.20 1.00 4.0 312 12 0.9 l l 20-22-24 1.40 1.25 6.0 322 22 0.7 l l 22-24-26 1.25 1.15 4.0 330 30 0.7 l l 22-24-26 1.10 1.00 3.5 2 0.9 l Rated current (A)2) 3 AWG 3 Print (straight)3) 2 Crimp 1 ø A (mm) 4 Number of contacts 0M 4 Reference MM 1 Test voltage (kV rms)1) Contact-shell Female insert øA Male insert Test voltage (kV rms)1) Contact-contact Multipole l 20-22-24 1.45 1.00 10.0 www.lemo.com 23 ® ® Contact type 25 0.9 l l 20-22-24 1.10 1.25 5.0 332 32 0.7 l l 22-24-26 1.25 1.20 3.5 340 40 0.7 l l 22-24-26 1.05 1.20 3.0 340 40 0.7 l l 22-24-26 1.20 1.35 3.5 348 48 l l 22-24-26 1.10 1.35 3.0 355 55 0.9 l l 20-22-24 1.65 1.95 3.5 368 68 l l 22-24-26 1.40 1.65 2.5 366 66 0.9 l l 20-22-24 1.60 1.70 3.0 114 114 l 22-24-26 1.37 1.34 2.0 0.7 0.7 0.7 l Rated current (A)2) 325 AWG Print (straight)3) 2 Crimp 5M 1 3 ø A (mm) LM 4 3 Number of contacts 4M 4 2 Reference TM 1 Test voltage (kV rms)1) Contact-shell Female insert øA Male insert Test voltage (kV rms)1) Contact-contact Multipole Note: 1) test voltage according to IEC 60512-2 test 4a. Altitude correction factor is given in IEC 60664-1 table A.2. 2) the specified rated current can be applied simultaneously to all the contacts. It corresponds to an average temperature rise of 40°C of the connector (measured according to IEC 60512-3 test 5a). 3) for EGl , ECl , EDl , HEl , HYl socket. 24 www.lemo.com ® ® Rated current (A)2) AWG 2 Crimp 1 3 ø A (mm) 4 3 Number of contacts 4 2 Reference 1 Print (straight)3) Contact type Test voltage (kV rms)1) Contact-shell Female insert øA Male insert Test voltage (kV rms)1) Contact-contact Mixed multipole 1M 304 2 0.7 22-24-26 1.20 1.30 11.0 l l 2 1.3 16-18-20 1.45 2.00 18.5 2M 306 3 0.7 22-24-26 1.55 1.40 10.5 l l 3 1.3 16-18-20 2.05 1.35 18.0 308 6 0.7 22-24-26 1.95 1.40 7.0 l l 2 1.3 16-18-20 1.75 1.60 23.0 310 8 0.7 22-24-26 1.35 1.35 6.0 l l 2 1.3 16-18-20 1.90 1.15 23.0 316 10 0.7 22-24-26 0.90 0.95 2.0 l l 6 1.3 16-18-20 1.35 1.15 11.0 366 44 0.7 l l 22-24-26 22 1.3 4) 3M 5M 1.65 2.70 3.0 1.95 1.80 6.0 Note: 1) test voltage according to IEC 60512-2 test 4a. Altitude correction factor is given in IEC 60664-1 table A.2. 2) the specified rated current can be applied simultaneously to all the contacts. It corresponds to an average temperature rise of 40°C of the connector (measured according to IEC 60512-3 test 5a). 3) for EGl , ECl , EDl , HEl , HYl socket. 4) reduced crimp barrel. Multipole high speed ethernet cat6 2M 2 3 4 1 8 5 7 6 7 1 8 6 5 2 4 3 514 8 0.7 l Rated current (A)2) Test voltage (kV rms)1) Contact-shell 2 Crimp contact 1 3 ø A (mm) 4 3 Number of contacts 4 2 Reference 1 Test voltage (kV rms)1) Contact-contact Female insert øA Male insert 1.5 1.5 8 Note: 1) test voltage according to IEC 60512-2 test 2) the specified rated current can be applied 4a. Altitude correction factor is given in IEC 60664-1 table A.2. simultaneously to all the contacts. It corresponds to an average temperature rise of 40°C of the connector (measured according to IEC 60512-3 test 5a). www.lemo.com 25 ® ® 4 l 1.20 0.95 n.a. Rated current (A)2) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Solder contact Female insert front view Reference Male insert front view Number of contacts USB 2.0 LM U2A Note: see models on page 17. 1) test voltage according to IEC 60512-2 test 4a. Altitude correction factor is given in IEC 60664-1 table A.2. 2) the specified rated current can be applied simultaneously to all the contacts. It corresponds to an average temperature rise of 40°C of the connector (measured according to IEC 60512-3 test 5a). Multi fibre and Hybrid fibre optic + low voltage Low voltage contact – 3M 95B 4 4 0.9 03W – – – Rated current (A)2) – Crimp contact Test voltage (kV rms)1) Contact-shell 2 Crimp 03A ø A (mm) 2M Number of contacts Number of F7 FO contacts Contact type Test voltage (kV rms)1) Contact-contact Female insert Reference Male insert – l 1.00 0.80 8.0 5M 21 – – – – – – Note: contacts must be ordered separately (see page 31). 4a. Altitude correction factor is given in IEC 60664-1 table A.2. simultaneously to all the contacts. It corresponds to an average temperature rise of 40°C of the connector (measured according to IEC 60512-3 test 5a). 1) test voltage according to IEC 60512-2 test 2) the specified rated current can be applied 26 www.lemo.com ® ® Mixed high speed coax 2M X04 2 0.9 1 l 2 1.3 Rated current (A)2) Test voltage (kV rms)1) Contact-shell AWG Crimp contact Contact type C Reference øA Coax ø A (mm) Coax Test voltage (kV rms)1) Contact-contact Low voltage contact Female insert Number of contacts Male insert 22-24-26 0.75 1.05 10 16-18-20 7 Note: contacts must be ordered separately (see pages 30 and 31). 1) test voltage according to IEC 60512-2 test 4a. Altitude correction factor is given in IEC 60664-1 table A.2. 2) the specified rated current can be applied simultaneously to all the contacts. It corresponds to an average temperature rise of 40°C of the connector (measured according to IEC 60512-3 test 5a). Multi coaxial This new configuration is available with all standard models presented in M series catalogue, and follow the standard models part numbering system. LM 232 12 50 0R Rated current (A)2) Test voltage (kV rms)1) Contact-screen VSWR (max.) Sheath ø max. Dielectric ø max. Cond. ø max. Cable group Reference Contact type Coax Coax Impedance (Ω) Female insert Number of contacts Male insert
BGE.2M.200.XAZ 价格&库存
很抱歉,暂时无法提供与“BGE.2M.200.XAZ”相匹配的价格&库存,您可以联系我们找货
