BMK.2M.200.CAZ
www.lemo.com
SUMMARY
# Wires
Image is for illustrative purpose only
Series
2M
Termination type
No contacts / Accessory
IP rating
68 when mated
AWG wire size
0.00 - 0.00
Cable Ø
0.00 - 0.00 mm
Status
active
Download
Request a quote
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
BMK*: Blanking caps, large washer for fixed sockets(knurled grip)
Keying
No keying
Housing Material
Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290]
brass latch sleeve and mid pieces
Weight
6.88 g
Performance
Configuration
Insulator
Rated Current
Specifications
Contact LEMO for performance details.
Others
Temp (min / max): -55°C / +135°C
Humidity (max): 21 days at 95%
Gunfire vibration: 25 Hz - 2000 Hz, 3 axis (Apache helicopter)
Vibration-Sine: 30 g, 3 axes, 12 hr [10 Hz - 2000 Hz]
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/2
Vibration-Random: 37.8 g rms - 3 axes, 4 hr amb [50 Hz - 2000 Hz]
Shock Resistance: 300 g [ 3 ms]
Lighting strike EIA 364-75: 10K amps - 6 times
Thermal shock: 5 cycles: -65°C to +150°C
EMI Shielding EIA 364-66A: >= 80 dB (1 GHz), >=70 dB (3 GHz), >= 58 dB (6 GHz), >= 40 dB (10 GHz)
Salt Spray Corrosion: >1000 hr
DRAWINGS
Dimensions
A
C
L
N
P
X
mm.
17.6
17.2
17.2
21
23.4
85
in.
0,69
0,68
0,68
0,83
0,92
3,35
RECOMMENDED BY LEMO
Tools
2/2
很抱歉,暂时无法提供与“BMK.2M.200.CAZ”相匹配的价格&库存,您可以联系我们找货
