v
DATA SHEET
THIN FILM CHIP RESISTORS
High precision - high stability
RT series
0.01% TO 1%, TCR 5 TO 50
sizes 0100/ 0201/ 0402/ 0603/ 0805/ 1206/
1210/ 2010/ 2512
Product specification – May 06, 2025 V.16
RoHS compliant
2
Chip Resistor Surface Mount
RT
10
0100 to 2512
SERIES
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes RT series
high precision - high stability chip
resistors with lead-free terminations
made by thin film process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
RT XXXX F X X XX XXXX L
Converters
Printing equipment
Server board
Telecom
Consumer
FEATURES
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
(1)
(2) (3) (4)
(2) TOLERANCE
L = ± 0.01%
P = ± 0.02%
W = ± 0.05%
B = ± 0.1%
C = ± 0.25%
RoHS compliant
D = ± 0.5%
High component and equipment
reliability
Saving of PCB space
(7)
RT0100 / 0201 / 0402 / 0603 / 0805 / 1206 / 1210 / 2010 / 2512
Halogen Free Epoxy
Reducing environmentally
hazardous wastes
(6)
(1) SIZE
(5)
F = ± 1%
(3) PACKAGING TYPE
R = Paper/PE taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
A = 5 ppm/°C
None forbidden-materials used in
products/production
C = 15 ppm/°C
Moisture sensitivity level: MSL 1
D = 25 ppm/°C
B = 10 ppm/°C
E = 50 ppm/°C
(5) TAPING REEL
07 = 7 inch dia. Reel
10 = 10 inch dia. Reel
13 = 13 inch dia. Reel
7W= 7 inch dia. Reel with high power (1W for 2512)
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point.
Detailed resistance rules show in table of “Resistance rule of global part number”.
(7) DEFAULT CODE
Letter L is system default code for order only (Note)
number
Resistance code rule
Example
XRXX
(1 to 9.76 Ω)
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
O RDERING EXAMPLE
The ordering code of a RT0603
chip resistor, TC 50 value 56 Ω
with ± 0.5% tolerance, supplied in
7-inch tape reel is:
RT0603DRE0756RL.
NOTE
1. All our RSMD products meet RoHS
compliant and Halogen Free. "LFP" of
the internal 2D reel label mentions
"Lead Free Process"
2. On customized label, "LFP" or
specific symbol can be printed
www.yageo.com
May 06, 2025 V.16
RT
SERIES
3
10
0100 to 2512
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products. For matching traditional types with size codes, please refer to “Comparison table of traditional
types and sizes”.
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC CODE
2390
(1)
X
XX
(2)
X
(4)
(3)
(2)
START TCR
PACKING CODE TOL . (4)
WITH (1) (ppm/°C) BY SIZE (inch) (3) (%)
2390
8 = ± 10 0402: 07 = 7'' reel
XXXX
(5)
RESISTANCE
RANGE
7 = ±1
The remaining 4 digits
7 = ± 15
47 = 13'' reel 6 = ± 0.5 represent the resistance
value with the last digit
6 = ± 25 0603: 04 = 7'' reel 5 = ± 0.25 indicating the multiplier
4 = ± 50
24 = 10'' reel 4 = ± 0.1 as shown in the table of
44 = 13'' reel 3 = ± 0.05 “Last digit of 12NC”.
0805: 01 = 7'' reel
41 = 13'' reel
1206: 11 = 7'' reel
51 = 13'' reel
1210: 12 = 7'' reel
52 = 13'' reel
2010: 15 = 7'' reel
L
(6)
DEFAULT
CODE
(NOTE)
Letter L is
system
default
code for
order only
(Note)
types and sizes
TF
X
X
X
(1)
(2)
START SIZE
WITH CODE
TF
(4)
(3)
TCR
TOL.
(ppm/°C) (%)
3 = 0402 4 = ± 10 0 = ± 1
2 = 0603 3 = ± 15 1 = ± 0.5
1 = 0805 1 = ± 25 2 = ± 0.25
0402: 4.7Ω ≤ R ≤ 240KΩ
0 = 1206 2 = ± 50 3 = ± 0.1
0603: 1 Ω ≤ R ≤ 1MΩ
5 = 1210
0805: 1Ω ≤ R ≤ 1.5 MΩ
7 = 2010
1206: 1Ω ≤ R ≤ 1.5 MΩ
6 = 2512
4 = ± 0.05
1210: 4.7Ω ≤ R ≤ 1 MΩ
Example:
2010: 4.7Ω ≤ R ≤ 1 MΩ
TF321 = RT0402, TC50, ± 0.5% tolerance
2512: 4.7Ω ≤ R ≤ 1 MΩ
2512: 18 = 7'' reel
Resistance decade (3)
Last digit
1 to 9.76
10 to 97.6
8
9
100 to 976
Exceptions to above packing code definitions:
1
1 to 9.76 k
0805 TC50 with 1%, supplied in 13" reel, the packing code is 02.
2
10 to 97.6 k
3
100 to 976 k
4
1 to 9.76 M
5
10 to 97.6 M
6
0603 TC50 with 1%, supplied in 13" reel, the packing code is 03.
2512 TC15, in 7" reel, the packing code is 35.
2010 TC15, in 7" reel, the packing code is 31.
O RDERING EXAMPLE
The ordering code of a TF221 resistor, TC50, value 56 , with ± 0.5%
tolerance, supplied in tape of 5,000 units per reel is: 239040465609L or
RT0603DRE0756RL.
Example:
1
33 k
10 M
1008 or 108
3303 or 333
1006 or 106
NOTE
1. All our RSMD products meet RoHS compliant and Halogen Free. "LFP" of the internal 2D reel label mentions "Lead Free Process"
2. On customized label, "LFP" or specific symbol can be printed
www.yageo.com
May 06, 2025 V.16
RT
4
10
0100 to 2512
SERIES
MARKING
RT0100 / RT0201 / RT0402 / RESISTANCE VALUE IS NOT IN E-24 / E96 SERIES
No marking
ynsc007
Fig. 1
RT0603
ynsc003
E-24 series: exception values 10/11/13/15/20/75 of E -24 series, one short bar
under marking letter
Fig. 2 Value = 56 kΩ
E-96 series: including values 10/11/13/15/20/75 of E-24 series, 3 digits
Fig. 3 Value = 12.4 kΩ
RT0805 / RT1206 / RT1210 / RT2010 / RT2512
YNSC004
Fig. 4 Value = 10 kΩ
Either resistance in E-24 or E-96: 4 digits
First three digits for significant figure and 4th digit for number of zeros
For further marking information, please see special data sheet “Chip resistors marking”.
CONSTRUCTION
The resistors are constructed out of a high-grade ceramic
body. Internal metal electrodes are added at each end and
connected by a resistive layer. The resistive layer is adjusted
to give the approximate required resistance and laser cutting
of this resistive layer that achieves tolerance trims the value.
The resistive layer is covered with a protective coat and
printed with the resistance value. Finally, the two external
terminations (matte tin) are added. See fig. 5.
OUTLINES
For dimension see Table 1
marking layer
protective coat
resistive layer
inner electrode
H
termination (Ni / matte tin)
ceramic substrate
I2
DIMENSION
Table 1 For outlines see fig. 5
TYPE
RT0100
I1
L (mm)
W (mm)
H (mm)
0.40± 0.02
0.20± 0.02
0.13± 0.02
I1 (mm)
I2 (mm)
0.10± 0.03
0.10± 0.03
RT0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.03
RT0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05
RT0603 1.60 ± 0.10 0.80 ± 0.10 0.45 ± 0.10
RT0805 2.00 ± 0.10 1.25 ± 0.10 0.50 ± 0.10
0.10 ± 0.05 0.15 ± 0.05
RT1206 3.10 ± 0.10 1.60 ± 0.10 0.55 ± 0.10
RT1210 3.10 ± 0.10 2.60 ± 0.15 0.55 ± 0.10
RT2010 5.00 ± 0.10 2.50 ± 0.15 0.55 ± 0.10
RT2512 6.35 ± 0.10 3.20 ± 0.15 0.55 ± 0.10
0.45 ± 0.20 0.40 ± 0.20
W
0.20 ± 0.10 0.25 ± 0.10
YNSC064
0.25 ± 0.15 0.25 ± 0.15
0.35 ± 0.20 0.35 ± 0.20
0.50 ± 0.20 0.50 ± 0.20
L
Fig. 5 Chip resistor outlines
0.60 ± 0.20 0.50 ± 0.20
www.yageo.com
May 06, 2025 V.16
RT
SERIES
5
10
0100 to 2512
ELECTRICAL CHARACTERISTICS
Table 2
TYPE
RT0100
RT0201
Operating
Temperature
Range
–55°C
to
+125°C
–55°C
to
+125°C
Max.
Max.
Power Work
T.C.R.
Overload
Rating
(ppm/°C)
Vol. (1) Vol.
± 0.01%
1/32W 15V
1/20W 25V
30V
50V
RT0402
1/16W 50V
100V
RT0603
1/10W 75V
150V
RT0805
1/8W
150V
300V
RT1206
1/4W
200V
400V
–55°C
to
+155°C
1/4W
RT1210
RT2010
–55°C
to
+125°C
1/2W
3/4W
200V
200V
200V
400V
400V
400V
RT2512
1W
200V
400V
Resistance Range (E-24/E-96 series)(2) & Tolerance
± 0.02%
± 0.05%
± 0.1%
± 0.25%
± 0.5%
± 1.0%
± 50
50R~5K
50R~5K
50R~5K
50R~5K
± 25
50R~5K
50R~5K
50R~5K
50R~5K
± 50
10~75K
10~75K
10~75K
10~75K
± 25
10~75K
10~75K
10~75K
10~75K
± 15
22~5K
22~5K
± 10
22~5K
22~5K
±5
± 50
± 25
± 15
± 10
±5
± 50
± 25
± 15
± 10
±5
± 50
± 25
± 15
± 10
±5
± 50
± 25
± 15
± 10
±5
50.1~12K
50.1~12K
20~12K
20~12K
20~10K
50.1~30K
50.1~30K
50.1~100K
50.1~100K
20~30K
50.1~30K
50.1~30K
50.1~200K
50.1~200K
20~50K
50.1~30K
50.1~30K
50.1~500K
50.1~500K
20~100K
50.1~12K
50.1~12K
20~12K
20~12K
20~10K
50.1~30K
50.1~30K
50.1~100K
50.1~100K
20~30K
50.1~30K
50.1~30K
50.1~200K
50.1~200K
20~50K
50.1~30K
50.1~30K
50.1~500K
50.1~500K
20~100K
20~12K
20~12K
20~12K
20~12K
20~10K
4.7~100K
4.7~100K
4.7~100K
4.7~100K
20~30K
4.7~200K
4.7~200K
4.7~200K
4.7~200K
20~50K
5.6~500K
5.6~500K
5.6~500K
5.6~500K
20~100K
4.7~500K
4.7~240K
10~200K
10~200K
20~10K
1~2M
1~1M
4.7~680K
4.7~680K
20~30K
1~3M
1~1.5M
4.7~1M
4.7~1M
20~50K
1~3M
1~1.5M
5.6~1.5M
5.6~1.5M
20~100K
4.7~500K
4.7~240K
10~200K
10~200K
20~10K
1~2M
1~1M
4.7~680K
4.7~680K
20~30K
1~3M
1~1.5M
4.7~1M
4.7~1M
20~50K
1~3M
1~1.5M
5.6~1.5M
5.6~1.5M
20~100K
4.7~500K
4.7~240K
------1~2M
1~1M
------1~3M
1~1.5M
------1~3M
1~1.5M
4.7~500K
4.7~240K
------1~2M
1~1M
------1~3M
1~1.5M
------1~3M
1~1.5M
± 50
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 25
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 15
100~100K
4.7~100K
4.7~100K
± 10
100~100K
4.7~100K
4.7~100K
±5
± 50
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 25
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 15
100~100K
4.7~100K
4.7~100K
± 10
100~100K
4.7~100K
4.7~100K
±5
± 50
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 25
4.7~1M
4.7~1M
4.7~1M
4.7~1M
4.7~1M
± 15
100~100K
4.7~100K
4.7~100K
± 10
100~100K
4.7~100K
4.7~100K
±5
± 50
10Ω~1M
10Ω~1M
10Ω~1M 10Ω~1M 10Ω~1M
± 25
10Ω~1M
10Ω~1M
Unit weight
(mg/pcs)
0.037
0.169
0.564
2.128
4.642
9.996
16.370
25.011
40.351
NOTE
1. The maximum working voltage that may be continuously applied to the resistor element, see “IEC publication 60115-8”
2. Value of E-192 series is on request
www.yageo.com
May 06, 2025 V.16
RT
6
10
0100 to 2512
SERIES
FOOTPRINT AND SOLDERING PROFILES
For recommended footprint and soldering profiles, please see the special data sheet “Chip resistors mounting”.
PACKING STYLE AND PACKAGING QUANTITY
Table 3 Packing style and packaging quantity
PACKING STYLE
Paper/PE taping reel (R)
Embossed taping reel (K)
REEL RT0100 RT0201 RT0402 RT0603 RT0805 RT1206 RT1210 RT2010 RT2512
DIMENSION
7" (178 mm)
10,000
10,000
10,000
5,000
5,000
5,000
5,000
10" (254 mm)
20,000
20,000
20,000
10,000
10,000
10,000
10,000
13" (330 mm)
50,000
50,000
50,000
20,000
20,000
20,000
20,000
7" (178 mm)
4,000
4,000
NOTE
1. For Paper/Embossed tape and reel specification/dimensions, please see the special data sheet “Chip resistors packing”
FUNCTIONAL DESCRIPTION
POWER RATING
Each type rated power at 70°C:
RT0100=1/32W
RT0201=1/20W, RT0402=1/16W, RT0603=1/10W,
RT0805=1/8W, RT1206=1/4W, RT1210=1/4W,
RT2010=1/2W, RT2512=3/4W, 1W
P
(%Prated )
MLB206_RT_1
100
RT0402~1206
50
RT0100,RT0201, RT1210 ~ 2512
R ATED VOLTAGE
The DC or AC (rms) continuous working voltage
corresponding to the rated power is determined by
the following formula:
V= (PxR)
70
100
125 155
o
Tamb ( C)
Fig. 6 Maximum dissipation (P) in percentage of rated power as a
function of the operating ambient temperature (T amb )
or max. working voltage whichever is less
Where
V=Continuous rated DC or
AC (rms) working voltage (V)
P=Rated power (W)
R=Resistance value (Ω)
www.yageo.com
May 06, 2025 V.16
RT
SERIES
7
10
0100 to 2512
TESTS AND REQUIREMENTS
Table 4 Test condition, procedure and requirements
TEST
TEST METHOD
PROCEDURE
REQUIREMENTS
Temperature
Coefficient of
Resistance
(T.C.R.)
MIL-STD-202 Method 304
At +25/–55 °C and +25/+125 °C
Refer to table 2
Formula:
R2–R1
T.C.R= ------------------------- × 106 (ppm/°C)
R1(t2–t1)
Where
t1=+25 °C or specified room temperature
t2=–55 °C or +125 °C test temperature
R1=resistance at reference temperature in ohms
R2=resistance at test temperature in ohms
Life/Endurance
IEC 60115-1 4.25.1
MIL-STD-202 Method 108A
At 70± 5 °C for 1,000 hours, rated voltage applied
for 1.5 hours on, 0.5 hour off, still air required
± (0.5%+0.05 Ω)
High
Temperature
Exposure
IEC 60068-2-2
1000 hours at maximum operating temperature
depending on specification, unpowered
± (0.5%+0.05 Ω)
Moisture
Resistance
MIL-STD-202 Method 106G
Each temperature / humidity cycle is defined at 8
hours, 3 cycles / 24 hours for 10d. with 25 °C /
65 °C 95% R.H, without steps 7a & 7b,
unpowered
± (0.5%+0.05 Ω)
Parts mounted on test-boards, without
condensation on parts
Measurement at 24± 2 hours after
test conclusion
Thermal Shock
MIL-STD-202 Method 107G
-55/+125 °C
Number of cycles required is 300.
Devices mounted
± (0.5%+0.05 Ω)
Maximum transfer time is 20 seconds.
Dwell time is 15 minutes. Air – Air
Humidity
(steady state)
IEC 60115-1 4.24.2
Steady state for 1000 hours at 40 °C / 95% R.H.
± (0.5%+0.05 Ω)
rated voltage applied for 1.5 hours on and
0.5 hour off
www.yageo.com
May 06, 2025 V.16
RT
8
10
0100 to 2512
SERIES
TEST
Short Time Overload
TEST METHOD
PROCEDURE
REQUIREMENTS
IEC60115-1 4.13
2.5 times of rated voltage or maximum
± (0.5%+0.05 Ω)
overload voltage whichever is less for 5 sec at No visible damage
room temperature
Board Flex/
Bending
IEC 60115-1 4.33
Chips mounted on a glass epoxy resin PCB
(FR4)
Bending: see table 5 for each size
± (0.25%+0.05 Ω)
No visible damage
RT0100± (0.5%+0.05 Ω)
Bending time: 60± 5 seconds
Solderability
- Wetting
Electrical Test not required
J-STD-002 test B
Well tinned (≥95%
covered)
No visible damage
Magnification 50X
SMD conditions:
1st step: method B, aging 4 hours at 155°C
dry heat
2nd step: leadfree solder bath at 245± 3°C
Dipping time: 3± 0.5 seconds
- Leaching
- Resistance to
Soldering Heat
J-STD-002 test D
Leadfree solder, 260 °C, 30 seconds
immersion time
No visible damage
IEC 60115-1 4.18
Condition B, no pre-heat of samples.
Leadfree solder, 260 °C, 10 seconds
immersion time
Procedure 2 for SMD: devices fluxed and
cleaned with isopropanol
± (0.5%+0.05 Ω)
No visible damage
Table 5 Bending for sizes 0100 to 2512
TYPE
Specification (mm)
RT0100
RT0201
RT0402
RT0603
RT0805
RT1206
RT1210
RT2010
RT2512
5
5
5
3
3
2
2
2
2
www.yageo.com
May 06, 2025 V.16
RT
SERIES
0100 to 2512
9
10
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
DESCRIPTION
Version 16
May 06, 2025 -
- RT0201 extend resistance range
- Add feature MSL=1
Version 15
Mar. 13, 2023 -
- RT0402 extend resistance range
Version 14
Nov. 23, 2022 -
- Add unit weight information
Version 13
July 07, 2022
Version 12
Apr. 21, 2020 -
Version 11
July 2, 2019
- Add 1W for 2512
Version 10
Jun. 12, 2019
- Extend resistor value
Version 9
Sep. 12, 2017 -
- Add ± 0.02% tol. for 0402 to 1206
Version 8
May 31, 2017 -
- Add 10" packing
Version 7
Jan. 17, 2017
Version 6
May. 11, 2015 -
Version 5
Aug. 22, 2014 -
- Add RT0201
- RT0402/0603/0805/1206: resistance range and operating temperature
range updated
- Fig. 6 updated
Version 4
Oct 21, 2009 -
- Test Items and methods updated
- Test requirements upgraded
Jul 11, 2008
- Change to dual brand datasheet that describe RT0402 to RT2512 with
RoHS compliant
- Description of "Halogen Free Epoxy" added
- Define global part number
- Modify electrical characteristic
Dec 26, 2005 -
- New datasheet for thin film high precision - high stability chip resistors
sizes of 0201/0402/0603/0805/1206/1210/2010/2512, 1%, 0.5%, 0.25%,
0.1%, 0.05%, TC25/50 with lead-free terminations
- Replace the 0402 to 1210 parts of pdf files: TFx10_1_1, TFx11_.5_2,
TFx12_.25_2, TFx13_.1_3, TFx14_.05_1, TFx20_1_2, TFx21_.5_2,
TFx22_.25_2, TFx23_.1_2, TFx24_.05_1, and combine into a document.
- Test method and procedure updated
- PE tape added (paper tape will be replaced by PE tape)
Version 3
Version 2
- RT0402/RT0603/RT0805/RT1206 Extend resistor range
- Add RT0100
- Modified resistance range
- Add ± 0.01% tol. for 0402 to 1206
www.yageo.com
May 06, 2025 V.16
RT
SERIES
10
10
0100 to 2512
LEGAL DISCLAIMER
YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any
errors, inaccuracies or incompleteness contained in any product related information, including but not limited
to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or
improvements to product related information at any time and without notice.
YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any
particular purpose or the continuing production of any of its products. To the maximum extent permitted by
law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii)
any and all liability, including without limitation special, consequential or incidental damages, and (iii) any and all
implied warranties, including warranties of fitness for a particular purpose, non -infringement and
merchantability.
YAGEO products are designed for general purpose applications under normal operation and usage conditions.
Please contact YAGEO for the applications listed below which require especially high reliability for the
prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace
equipment (artificial satellite, rocket, etc.), Atomic energy -related equipment, Aviation equipment, Disaster
prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly
public information network equipment, data-processing equipment , Medical devices, Military equipment, Power
generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and
Undersea equipment, or for any other application or use in which the failure of YAGEO products could result
in personal injury or death, or serious property damage. Particularly YAGEO Corporation and its affiliates
do not recommend the use of commercial, automotive, and/or COTS grade products for high
reliability applications or manned space flight.
Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights
for revising this content without further notification, as long as products are unchanged. Any product change
will be announced by PCN.
www.yageo.com
May 06, 2025 V.16
