PRG3216P-22R0-D-T5
PRG3216P-22R0-D-T5
    SUSUMU
    贴片电阻 1206 22Ω ±0.5% 1W ±25ppm/℃
PRG3216P-22R0-D-T5 数据手册
High power thin film chip resistors (long side terminal) ■PRG series AEC-Q200 Compliant Features ・ Long side terminal enabling higher power capability ・ Significantly larger power handling capability than conventional same size resistors Thin film surface mount resistors Size: 3216 ~ 6432, power ratings: 0.5 ~ 3.0W, Resistance range: 2.5 ~ 250KΩ ・ Precision resistance tolerance: ±0.1%, very small TCR: ±25ppm/°C ・ Thin film structure enabling low noise and anti-sulfur Applications ・ Automotive electronics ・ DC motor, inverters PRG series ・ Robotics, Industrial control system ◆Part numbering system PRG 3216 Series code P - 1001 - B - T5 Packaging quantity: T4(4,000pcs) (PRG6432, PRG5025) T5(5,000pcs) (PRG3216) Size: PRG3216, PRG5025, PRG6432 Resistance tolerance Temperature coefficient of resistance Nominal resistance value (E-24, E-96: all 4 digit) ◆Electrical Specification Type Power ratings Temperature coefficient of resistance (ppm/°C) Resistance range(Ω) Resistance tolerance ±0.1% (B) 47≦R≦200k 200V 2.5≦R≦200k ±50(Q) 10≦R≦250k ±25(P) 47≦R≦250k 2.0W ~ 3.0W ±50(Q) 25 400V 2.5≦R≦250k E-24, E-96 -55℃ ~ 155℃ T4    PRG6432 T5 150V 10≦R≦200k ±25(P) 1.5W ~ 2.0W Packaging quantity 2.5≦R≦100k ±50(Q) PRG5025 Operating temperature ±0.5% (D) 47≦R≦100k 1.0W Resistance value series 10≦R≦100k ±25(P) PRG3216 Maximum voltage ◆Dimensions Type L a a W Size (inch) W L a b t 1206 3.20+0.40/-0.20 1.60±0.20 0.30±0.20 0.35±0.20 0.45+0.15/-0.10 PRG5025 2010 5.00±0.20 2.50±0.20 0.55±0.20 0.60±0.20 0.45+0.15/-0.10 PRG6432 2512 6.40+0.20/-0.40 3.20±0.20 0.40±0.20 0.55±0.20 0.45+0.15/-0.10 t b (unit:mm) b PRG series ◆Reliability specification Standard ≦47Ω ≧47Ω Test items Condition (test methods (JIS C5201-1) Life (biased) 70℃, rated voltage,* 1 90min on 30min off, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) High temperature high humidity 85℃, 85%RH, 1/10 of rated power, 90min on 30min off, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Temperature shock -55℃ (30min) ~ 125℃ (30min) 1000cycles ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) High temperature exposure 155℃, no bias, 1000hours ±(0.25%+0.05Ω) ±(0.1%+0.01Ω) Resistance to soldering heat 260±5℃, 10 seconds (reflow) *1 Thin film surface mount resistors PRG3216 ±(0.1%+0.01Ω) ±(0.05%+0.01Ω) Rated voltage is given by E= R x P E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W) If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage. 26 High power thin film chip resistors (long side terminal) ■PRG series ◆Reliability test data 0.12 0.12 0.10 0.10 0.08 0.08 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.08 -0.10 -0.10 -0.12 PRG series Resistance drift(%) Resistance drift(%) Thin film surface mount resistors ○Biased life test -0.12 10         100        1000       10000 Test duration(h) 10         100        1000       10000 Test duration(h) 0.30 Resistance drift(%) 0.25 0.20 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 -0.20 -0.25 -0.30 10         100        1000       10000 Test duration(h) 0.30 0.12 0.25 0.10 0.20 0.08 Resistance drift(%) Resistance drift(%) ○High temperature high humidity (biased) 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 -0.20 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.25 -0.30 0.06 -0.10 -0.12 10        100         1000       10000 0.12 0.12 0.10 0.10 0.08 0.08 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.10 10        100        1000       10000 Test duration(h) 27 0.06 -0.08 -0.10 -0.12 10        100         1000       10000 Test duration(h) Resistance drift(%) Resistance drift(%) Test duration(h) -0.12 10        100        1000       10000 Test duration(h) 0.12 0.12 0.10 0.10 0.08 0.08 Resistance drift(%) Resistance drift(%) ○Temperature shock 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.10 -0.10 -0.12 10cycle    100cycle     1000cycle    10000cycle Test duration(h) 0.12 0.25 0.10 0.20 0.08 Resistance drift(%) 0.30 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 -0.20 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.25 -0.30 10cycle    100cycle     1000cycle    10000cycle PRG series Resistance drift(%) Test duration(h) Thin film surface mount resistors -0.12 0.06 -0.10 -0.12 10cycle    100cycle     1000cycle    10000cycle Test duration(h) 10cycle    100cycle     1000cycle    10000cycle Test duration(h) 0.12 0.12 0.10 0.10 0.08 0.08 Resistance drift(%) Resistance drift(%) ○High temperature exposure 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.08 -0.10 -0.12 0.06 -0.10 -0.12 10        100         1000       10000 0.30 0.12 0.25 0.10 0.20 0.08 0.15 0.10 0.05 0.00 -0.05 -0.10 -0.15 0.06 0.04 0.02 0.00 -0.02 -0.04 -0.06 -0.20 -0.08 -0.25 -0.10 -0.30 10        100         1000       10000 10        100         1000       10000 Test duration(h) Resistance drift(%) Resistance drift(%) Test duration(h) -0.12 Test duration(h) 10        100         1000       10000 Test duration(h) ◆Derating Curve ○PRG6432 Ratio to rated power (%) Ratio to rated power (%) ○PRG3216 100 50 0 -55     0     50 70  100     155 Ambient temperature (℃) 100 2.0W 50 0 3.0W -55     0   25  50 70  100     155 Ambient temperature (℃) 28
PRG3216P-22R0-D-T5
物料型号:PRG系列薄膜表面贴装电阻器。
器件简介:PRG系列电阻器是高功率薄膜芯片电阻器,符合AEC-Q200标准,无卤素,符合RoHS指令。
引脚分配:长边端子设计,提高了功率承载能力。
参数特性: - 尺寸范围:3216至6432,功率等级:0.5至3.0W,电阻范围:2.5至250KΩ。 - 精确电阻公差:±0.1%,非常小的温度系数:±25ppm/°C。 - 薄膜结构,低噪音,抗硫。
功能详解: - 应用领域包括汽车电子、直流电机、逆变器、机器人技术、工业控制系统。 - 封装数量:PRG6432和PRG5025为T4(4000件),PRG3216为T5(5000件)。
应用信息:适用于高要求的电子设备,特别是在汽车电子和工业控制领域。
封装信息:提供了不同尺寸的电阻器的详细物理尺寸和可靠性规格测试数据。
电气规格表详细列出了不同型号的电阻器的功率等级、温度系数、电阻范围、公差、最大电压、电阻值系列、工作温度和封装数量。
PRG3216P-22R0-D-T5 价格&库存
很抱歉,暂时无法提供与“PRG3216P-22R0-D-T5”相匹配的价格&库存,您可以联系我们找货
PRG3216P-22R0-D-T5
  • 1+2.643461+0.34265
  • 10+2.1947110+0.28448
  • 25+2.0307825+0.26323
  • 50+1.9199250+0.24886
  • 100+1.81408100+0.23514
  • 250+1.68713250+0.21869
  • 500+1.60058500+0.20747
  • 1000+1.522301000+0.19732
库存:4948
PRG3216P-22R0-D-T5
  • 5000+1.488095000+0.19289
  • 10000+1.4301210000+0.18537
  • 15000+1.3994615000+0.18140
  • 25000+1.3640525000+0.17681
  • 35000+1.3425535000+0.17402
  • 50000+1.3212550000+0.17126
库存:4948
PRG3216P-22R0-D-T5
