70GRCM32-HL
70GRCM32-HL
    GRAYHILLINC.
    I/O MOUNTING BOARD G5 32POS
70GRCM32-HL 数据手册
System 50 RACKS 32 Channel FEATURES • For Use with MicroDac or PAMUX Controllers • Available for G5 I/O Modules • UL, CSA Certified 32 CHANNEL RACK: G5 Part No. 70GRCM32 Dimensions are in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless indicated otherwise. 10.000 (254,00) 9.500 (241,3) LOGIC SUPPLY TERMINAL STRIP FIELD WIRING TERMINAL STRIP .250 (6,35) .250 (6,35) FUSE 5A 0Ω JUMPER 49 50 PIN STRAIGHT HEADER CONNECTOR 0 31 1 30 2 29 3 28 4 27 5 26 6 25 7 24 8 23 9 22 10 21 11 20 12 19 13 18 14 17 15 16 6.500 (165,1) 6.000 (152,4) 1 STANDOFF I.D. 0.15 (3,81) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW System 50 System 50 25 NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 3.338 (84,79) REF. .750 (19,05) REF. G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 SCHEMATIC: Part No. 70GRCM32 LOGIC SUPPLY TERMINAL STRIP 5A FUSE USER INSTALLABLE JUMPER FOR +VCC 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 +– FIELD 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 WIRING 1 2 3 4 5 6 7 8 1 2 3 4 5 TERMINAL STRIPS (POSITIONS 0-15) 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 MODULE POSITION 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 3.3KΩ RESISTOR NETWORKS 15 13 11 9 7 5 3 1 2 4 6 8 10 12 14 16 50 PIN EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS 31 5 4 3 2 1 MODULE POSITION 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 FIELD WIRING TERMINAL STRIPS (POSITIONS 16-31) System 50 ORDERING INFORMATION Part Number 70GRCM32-HL I/O 32 (modules ordered separately) UL X CSA X Style G5 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Description 50-pin header with ejector levers G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 26
70GRCM32-HL 价格&库存
很抱歉,暂时无法提供与“70GRCM32-HL”相匹配的价格&库存,您可以联系我们找货
