Page 1 of 1
Clock Generator
Part No.
Datasheet
W83115RG-965
Request PDF
The W83115RG-965 is a CK505 Clock Synthesizer for Intel chipsets. The W83115RG-965 provides all clocks
required for the high-speed microprocessor and provides step-less frequency programming and 32 different
frequencies of CPU, PCI, and SRC clocks setting. The W83115RG-965 also supports SATA and DOT clock
outputs. All clocks are externally selectable with smooth transitions.
Description
The W83115RG-965 provides I2C serial bus interface to program the registers to enable or disable each clock
output and provides -0.5% down type spread spectrum or programmable S.S.T. scale to reduce EMI.
The W83115RG-965 accepts a 14.318 MHz reference crystal as its input and runs on a 3.3V supply.
2 pairs of push-pull Differential clock outputs for CPU, 1 free running.
7 pairs of push-pull Differential clock outputs for SRC.
1 pair push-pull Differential clock outputs for CPU/SRC.
1 pair push-pull Differential clock outputs for DOT/SRC.
5 PCI clock outputs, 1 free running.
1 48 MHz clock output for USB.
1 14.318MHz REF clock output.
Smooth frequency switch with selections from 100 to 400MHz.
Step-less frequency programming, and programmable S.S.T. scale to reduce EMI in M/N mode.
I2C 2-wire serial interface and support byte read/write and block read/write.
-0.5% down type spread spectrum in H/W and software select mode.
Programmable registers to enable/disable each output and select mode.
Programmable clock output slew rate control and skew control.
Features
Diagram
N/A
Package
SSOP56
Other Files
N/A
Development
Tools
N/A
Others
N/A
Contact us:ComputerIC@nuvoton.com
https://www.nuvoton.com/hq/enu/productandsales/productlines/cloudandcomputingic/voltagelevelshiftic/voltagel... 8/27/2013
很抱歉,暂时无法提供与“W83115RG-965”相匹配的价格&库存,您可以联系我们找货
