74LVC257A
Quad 2-input multiplexer with 5 V tolerant inputs/outputs;
3-state
Rev. 6 — 28 November 2011
Product data sheet
1. General description
The 74LVC257A is a quad 2-input multiplexer with 3-state outputs, which select 4 bits of
data from two sources and are controlled by a common data select input (pin S). The data
inputs from source 0 (pins 1I0 to 4I0) are selected when pin S is LOW and the data inputs
from source 1 (pins 1I1 to 4I1) are selected when pin S is HIGH. Data appears at the
outputs (pins 1Y to 4Y) in true (non-inverting) form from the selected inputs. The device is
the logic implementation of a 4-pole, 2-position switch, where the position of the switch is
determined by the logic levels applied to pin S. The outputs are forced to a
high-impedance OFF-state when pin OE is HIGH.
Inputs can be driven from either 3.3 V or 5.0 V devices. When disabled, up to 5.5 V can be
applied to the outputs. These features allow the use of these devices as translators in
mixed 3.3 V and 5 V applications.
2. Features and benefits
5 V tolerant inputs/outputs, for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low-power consumption
Direct interface with TTL levels
Output drive capability 50 transmission lines at 85 C
Complies with JEDEC standard:
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A (2.3 V to 2.7 V)
JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115B exceeds 200 V
CDM JESD22-C101E exceeds 1000 V
Specified from 40 C to +85 C and 40 C to +125 C
74LVC257A
Nexperia
Quad 2-input multiplexer with 5V tolerant; 3-state
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC257AD
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74LVC257ADB
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
TSSOP16
plastic thin shrink small outline package; 16 leads;
body width 4.4 mm
SOT403-1
74LVC257APW 40 C to +125 C
74LVC257ABQ
40 C to +125 C
DHVQFN16 plastic dual in-line compatible thermal enhanced very
thin quad flat package; no leads; 16 terminals;
body 2.5 3.5 0.85 mm
SOT763-1
4. Functional diagram
1
15
2
1I0
3
1I1
5
2I0
1Y
4
6
2I1
2Y
7
11
3I0
3Y
9
10
3I1
4Y
12
14
4I0
13
4I1
2
3
G1
EN
1
MUX
4
1
5
7
6
11
9
10
14
S
OE
1
15
12
13
mna865
Fig 1.
Logic diagram
74LVC257A
Product data sheet
mna866
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 18
74LVC257A
Nexperia
1I1
1Y
1I0
2I1
2Y
2I0
2
1I0
3
1I1
5
2I0
6
2I1
11
3I0
10
3I1
14
4I0
13
4I1
1Y
4
3I1
3Y
2Y
3-STATE
MULTIPLEXER
OUTPUTS
SELECTOR
7
3I0
3Y
9
4I1
4Y
4Y 12
4I0
1 S
OE
15 OE
S
mna867
mna868
Fig 3.
Functional diagram
Fig 4.
Logic diagram
5. Pinning information
5.1 Pinning
16 VCC
1I0
2
15 OE
1I1
3
14 4I0
terminal 1
index area
S
1
1
S
5
12 4Y
2I1
6
11 3I0
2Y
7
10 3I1
GND
8
9
1I1
3
14 4I0
1Y
4
2I0
5
2I1
6
2Y
7
3Y
13 4I1
257A
GND(1)
12 4Y
11 3I0
10 3I1
9
2I0
15 OE
3Y
13 4I1
2
8
4
1I0
GND
1Y
16 VCC
74LVC257A
001aad098
Transparent top view
001aad097
(1) This is not a supply pin. The substrate is attached to this
pad using conductive die attach material. There is no
electrical or mechanical requirement to solder this pad.
However, if it is soldered, the solder land should remain
floating or be connected to GND.
Fig 5.
Pin configuration for SO24 and (T)SSOP24
74LVC257A
Product data sheet
Fig 6.
Pin configuration for DHVQFN24
3 of 18
74LVC257A
Nexperia
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
S
1
1I0
2
data input from source 0
1I1
3
data input from source 1
1Y
4
3-state multiplexer output
2I0
5
2I1
6
2Y
7
GND
8
ground (0 V)
3Y
9
3I1
10
3I0
11
4Y
12
4I1
13
4I0
14
OE
15
3-state output enable input (active LOW)
VCC
16
supply voltage
6. Functional description
Table 3.
Function table[1]
Input
Output
OE
S
nI0
nI1
nY
H
X
X
X
Z
L
H
X
L
L
L
H
X
H
H
L
L
L
X
L
L
L
H
X
H
[1]
H = HIGH voltage level
L = LOW voltage level
X = don’t care
Z = high-impedance OFF-state
74LVC257A
Product data sheet
4 of 18
74LVC257A
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0
[1]
Min
Max
Unit
0.5
+6.5
V
50
mA
0.5
+6.5
V
50
mA
HIGH or LOW state
[2]
0.5
VCC + 0.5
V
output 3-state
[2]
0.5
+6.5
V
50
mA
VO > VCC or VO < 0
IO
output current
ICC
supply current
100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
Ptot
total power dissipation
500
mW
[1]
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
[2]
The output voltage ratings may be exceeded if the output current ratings are observed.
[3]
For SO16 packages: above 70 C the value of Ptot derates linearly with 8 mW/K.
For (T)SSOP16 packages: above 60 C the value of Ptot derates linearly with 5.5 mW/K.
For DHVQFN16 packages: above 60 C the value of Ptot derates linearly with 4.5 mW/K.
8. Recommended operating conditions
Table 5.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Conditions
Min
Typ
Max
Unit
1.65
3.6
V
functional
1.2
V
V
HIGH or LOW state
VCC
V
3-state
V
40
+125
C
Tamb
ambient temperature
in free air
t/V
input transition rise and fall
rate
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
74LVC257A
Product data sheet
5 of 18
74LVC257A
Nexperia
9. Static characteristics
Table 6.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
HIGH-level
input voltage
VIH
LOW-level
input voltage
VIL
VOH
HIGH-level
output
voltage
LOW-level
output
voltage
VOL
VCC = 1.2 V
Typ[1]
40 C to +125 C
Max
Min
Max
Unit
1.08
1.08
V
0.65 VCC
0.65 VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
0.12
V
VCC = 1.65 V to 1.95 V
VCC = 1.2 V
0.12
0.35 VCC
0.7
0.7
V
0.8
0.8
V
VCC 0.2
VCC 0.3
V
IO = 4 mA; VCC = 1.65 V
1.2
1.05
V
IO = 8 mA; VCC = 2.3 V
1.8
1.65
V
IO = 12 mA; VCC = 2.7 V
2.2
2.05
V
IO = 18 mA; VCC = 3.0 V
2.4
2.25
V
IO = 24 mA; VCC = 3.0 V
2.2
2.0
V
IO = 100 A;
VCC = 1.65 V to 3.6 V
0.2
0.3
V
0.45
0.65
V
0.6
0.8
V
0.4
0.6
V
0.55
0.8
V
0.35 VCC V
VI = VIH or VIL
IO = 100 A;
VI = VIH or VIL
II
input leakage VCC = 3.6 V; VI = 5.5 V or GND
current
0.1
5
A
IOZ
OFF-state
output
current
VI = VIH or VIL; VCC = 3.6 V;
VO = 5.5 V or GND;
0.1
5
A
IOFF
power-off
leakage
current
VCC = 0 V; VI or VO = 5.5 V
0.1
10
A
ICC
supply
current
VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
A
ICC
additional
supply
current
per input pin;
VCC = 2.7 V to 3.6 V;
VI = VCC 0.6 V; IO = 0 A
5
500
5000
A
CI
input
capacitance
VCC = 0 V to 3.6 V;
VI = GND to VCC
5.0
pF
[1]
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 C.
74LVC257A
Product data sheet
6 of 18
74LVC257A
Nexperia
10. Dynamic characteristics
Table 7.
Voltages are referenced to GND (ground = 0 V). For test circuit see Figure 9.
Symbol Parameter
tpd
propagation delay
40 C to +85 C
Conditions
Min
Max
Min
Max
16
ns
1.5
5.2
10.6
1.5
12.3
ns
1.0
2.8
5.5
1.0
6.4
ns
VCC = 2.7 V
1.0
2.8
5.4
1.0
7.0
ns
VCC = 3.0 V to 3.6 V
1.0
2.4
4.6
1.0
6.0
ns
18
ns
1.0
6.0
14.8
1.0
17.1
ns
1.0
3.2
7.7
1.0
8.9
ns
VCC = 2.7 V
1.0
3.2
7.5
1.0
9.5
ns
1.0
2.7
6.4
1.0
8.0
ns
15
ns
1.5
5.8
12.7
1.5
14.7
ns
1.5
3.3
7.0
1.5
8.1
ns
VCC = 2.7 V
1.5
3.4
6.7
1.5
8.5
ns
1.0
2.7
5.6
1.0
7.0
ns
8
ns
nI0, nI1 to nY; see Figure 7
[2]
VCC = 1.2 V
S to nY; see Figure 7
[2]
VCC = 1.2 V
ten
enable time
OE to nY; see Figure 8
[2]
VCC = 1.2 V
tdis
disable time
[2]
VCC = 1.2 V
2.2
4.0
8.2
2.2
9.4
ns
0.5
2.2
4.4
0.5
5.1
ns
VCC = 2.7 V
1.5
3.0
4.7
1.5
6.0
ns
1.0
2.8
4.3
1.0
5.5
ns
1.0
1.5
ns
tsk(o)
output skew time
74LVC257A
Product data sheet
40 C to +125 C Unit
Typ[1]
[3]
7 of 18
74LVC257A
Nexperia
Table 7.
Dynamic characteristics …continued
Symbol Parameter
40 C to +85 C
Conditions
Min
CPD
[1]
[2]
power dissipation
capacitance
Typ[1]
40 C to +125 C Unit
Max
Min
Max
[4]
per input; VI = GND to VCC
8.0
pF
11.4
pF
14.4
pF
Typical values are measured at Tamb = 25 C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
ten is the same as tPZL and tPZH.
tdis is the same as tPLZ and tPHZ.
[3]
[4]
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in Volts
N = number of inputs switching
(CL VCC2 fo) = sum of the outputs
11. Waveforms
VCC
VM
S, nl0, nl1 input
GND
tPHL
tPLH
VOH
VM
nY output
VOL
mna869
VM = 1.5 V at VCC 2.7 V;
VM = 0.5 VCC at VCC < 2.7 V;
VOL and VOH are typical output voltage levels that occur with the output load.
Fig 7.
Input (S, nI0 and nI1) to output (nY) propagation delays
74LVC257A
Product data sheet
8 of 18
74LVC257A
Nexperia
VI
OE input
VM
GND
t PLZ
t PZL
VCC
output
LOW-to-OFF
OFF-to-LOW
VM
VX
VOL
t PZH
t PHZ
VOH
VY
output
HIGH-to-OFF
OFF-to-HIGH
VM
GND
output
enabled
output
disabled
output
enabled
mna870
VM = 1.5 V at VCC 2.7 V.
VM = 0.5 VCC at VCC < 2.7 V.
VX = VOL + 0.3 V at VCC 2.7 V;
VX = VOL + 0.15 V at VCC 2.7 V;
VY = VOH 0.3 V at VCC 2.7 V;
VY = VOH 0.15 V at VCC 2.7 V.
Fig 8.
3-state enable and disable times
74LVC257A
Product data sheet
9 of 18
74LVC257A
Nexperia
VI
tW
90 %
negative
pulse
VM
0V
tf
tr
tr
tf
VI
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VEXT
VCC
VI
RL
VO
G
DUT
RT
RL
CL
001aae331
Test data is given in Table 8.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Fig 9.
Table 8.
Test circuit for measuring switching times
Test data
Supply voltage
Input
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
1.2 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
1.65 V to 1.95 V
VCC
2 ns
30 pF
1 k
open
2 VCC
GND
2.3 V to 2.7 V
VCC
2 ns
30 pF
500
open
2 VCC
GND
2.7 V
2.7 V
2.5 ns
50 pF
500
open
2 VCC
GND
3.0 V to 3.6 V
2.7 V
2.5 ns
50 pF
500
open
2 VCC
GND
74LVC257A
Product data sheet
Load
VEXT
10 of 18
74LVC257A
Nexperia
12. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 10. Package outline SOT109-1 (SO16)
74LVC257A
Product data sheet
11 of 18
74LVC257A
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig 11. Package outline SOT338-1 (SSOP16)
74LVC257A
Product data sheet
12 of 18
74LVC257A
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
detail X
w M
bp
e
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 12. Package outline SOT403-1 (TSSOP16)
74LVC257A
Product data sheet
13 of 18
74LVC257A
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
A
B
D
A
A1
E
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
2
7
y
y1 C
v M C A B
w M C
b
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
mm
A(1)
max.
A1
b
1
0.05
0.00
0.30
0.18
c
D (1)
Dh
E (1)
Eh
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
e
0.5
e1
L
v
w
y
y1
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig 13. Package outline SOT763-1 (DHVQFN16)
74LVC257A
Product data sheet
14 of 18
74LVC257A
Nexperia
13. Abbreviations
Table 9.
Abbreviations
Acronym
Description
CDM
Charged Device Model
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
14. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC257A v.6
20111128
Product data sheet
74LVC257A v.5
Modifications:
74LVC257A v.5
Value changes for tpd, ten and tdis in Table 7 “Dynamic characteristics”
Typographical errors corrected
20111108
Modifications:
Product data sheet
74LVC257A v.4
The format of this document has been redesigned to comply with the new identity guidelines of
NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 4, Table 5, Table 6, Table 7 and Table 8: values added for lower voltage ranges.
74LVC257A v.4
040123
Product specification
74LVC257A v.3
74LVC257A v.3
031117
74LVC257A v.2
74LVC257A v.2
980729
74LVC257A v.1
74LVC257A v.1
74LVC257A
Product data sheet
15 of 18
74LVC257A
Nexperia
15. Legal information
15.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
15.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
74LVC257A
Product data sheet
16 of 18
74LVC257A
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor tested
in accordance with automotive testing or application requirements. Nexperia
non-automotive qualified products in automotive equipment or applications.
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s product specifications.
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards, customer
(a) shall use the product without Nexperia’s warranty of the
product for such automotive applications, use and specifications, and (b)
whenever customer uses the product for automotive applications beyond
15.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
16. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74LVC257A
Product data sheet
17 of 18
Nexperia
74LVC257A
17. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
15.1
15.2
15.3
15.4
16
17
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 3
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4
Functional description . . . . . . . . . . . . . . . . . . . 4
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 5
Recommended operating conditions. . . . . . . . 5
Static characteristics. . . . . . . . . . . . . . . . . . . . . 6
Dynamic characteristics . . . . . . . . . . . . . . . . . . 7
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 11
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 15
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 15
Legal information. . . . . . . . . . . . . . . . . . . . . . . 16
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 16
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 16
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 17
Contact information. . . . . . . . . . . . . . . . . . . . . 17
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Date of release: 28 November 2011
