74HC138-Q100; 74HCT138-Q100
3-to-8 line decoder/demultiplexer; inverting
Rev. 5 — 13 August 2021
Product data sheet
1. General description
The 74HC138-Q100; 74HCT138-Q100 decodes three binary weighted address inputs
(A0, A1 and A2) to eight mutually exclusive outputs (Y0 to Y7). The device features three enable
inputs (E1, E2 and E3). Every output will be HIGH unless E1 and E2 are LOW and E3 is HIGH.
This multiple enable function allows easy parallel expansion to a 1-of-32 (5 to 32 lines) decoder
with just four '138 ICs and one inverter. The '138 can be used as an eight output demultiplexer by
using one of the active LOW enable inputs as the data input and the remaining enable inputs as
strobes. Inputs include clamp diodes. This enables the use of current limiting resistors to interface
inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and from -40 °C to +125 °C
Wide supply voltage range from 2.0 to 6.0 V
CMOS low power dissipation
High noise immunity
Latch-up performance exceeds 100 mA per JESD 78 Class II Level B
Demultiplexing capability
Multiple input enable for easy expansion
Ideal for memory chip select decoding
Active LOW mutually exclusive outputs
Input levels:
• For 74HC138-Q100: CMOS level
• For 74HCT138-Q100: TTL level
Complies with JEDEC standards:
• JESD8C (2.7 V to 3.6 V)
• JESD7A (2.0 V to 6.0 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω)
Multiple package options
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
74HC138D-Q100
Temperature range
Name
Description
Version
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
74HCT138D-Q100
74HC138PW-Q100
74HCT138PW-Q100
74HC138BQ-Q100
74HCT138BQ-Q100
SOT763-1
4. Functional diagram
Y0
15
1
A0
Y1
14
2
A1
Y2
13
3
A2
Y3
12
Y4
11
Y5
10
3-to-8
DECODER
ENABLE
EXITING
1
A0
Y0
15
2
A1
Y1
14
3
A2
Y2
13
Y6
9
Y3
12
Y7
7
E1
Y4
11
E2
Y5
10
E3
Y6
9
Y7
7
4
5
6
4
E1
5
E2
6
E3
mna370
Fig. 1.
Logic symbol
mna372
Fig. 2.
Functional diagram
Y7
A2
Y6
A1
Y5
A0
Y4
E1
Y3
E2
Y2
E3
Y1
Y0
001aae059
Fig. 3.
Logic diagram
74HC_HCT138_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 15
Nexperia
5. Pinning information
5.1. Pinning
1
A0
terminal 1
index area
2
15 Y0
A2
3
14 Y1
E1
4
13 Y2
E2
5
12 Y3
E3
6
11 Y4
Y7
7
10 Y5
GND
8
9
Y6
A0
1
A1
2
16 VCC
15 Y0
A2
3
14 Y1
E1
4
13 Y2
E2
5
12 Y3
E3
6
11 Y4
Y7
7
10 Y5
GND
8
9
Fig. 4.
Pin configuration SOT109-1
(SO16)
Fig. 5.
E1
4
13 Y2
E2
5
12 Y3
E3
6
Y7
7
GND(1)
11 Y4
10 Y5
001aae060
Transparent top view
Y6
Pin configuration SOT403-1
(TSSOP16)
14 Y1
(1) This is not a ground
pin. There is no electrical
or mechanical requirement
to solder the pad. In case
soldered, the solder land
should remain floating or
connected to GND.
aaa-028343
aaa-028342
A2
9
A1
74HC138
74HCT138
15 Y0
3
Y6
16 VCC
2
8
1
A0
A1
GND
74HC138
74HCT138
16 VCC
74HC138
74HCT138
Fig. 6.
Pin configuration SOT763-1
(DHVQFN16)
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
A0, A1, A2
1, 2, 3
address input
E1, E2
4, 5
enable input (active LOW)
E3
6
enable input (active HIGH)
Y0, Y1, Y2, Y3, Y4, Y5, Y6, Y7
15, 14, 13, 12, 11, 10, 9, 7
output
GND
8
ground (0 V)
VCC
16
supply voltage
74HC_HCT138_Q100
Product data sheet
3 / 15
Nexperia
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care.
Control
Input
Output
E1
E2
E3
A2
A1
A0
Y7
Y6
Y5
Y4
Y3
Y2
Y1
Y0
H
X
X
X
X
X
H
H
H
H
H
H
H
H
X
H
X
X
X
L
L
L
H
L
L
L
H
H
H
H
H
H
H
L
L
L
H
H
H
H
H
H
H
L
H
L
H
L
H
H
H
H
H
L
H
H
L
H
H
H
H
H
H
L
H
H
H
H
L
L
H
H
H
L
H
H
H
H
H
L
H
H
H
L
H
H
H
H
H
H
H
L
H
L
H
H
H
H
H
H
H
H
H
L
H
H
H
H
H
H
H
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
Max
Unit
-0.5
+7
V
VCC
supply voltage
IIK
input clamping current
VI < -0.5 V or VI > VCC + 0.5 V
±20
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
±20
mA
IO
output current
VO = -0.5 V to (VCC + 0.5 V)
±25
mA
ICC
quiescent supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[1]
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
74HC_HCT138_Q100
Product data sheet
4 / 15
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol Parameter
Conditions
74HC138-Q100
74HCT138-Q100
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+25
+125
-40
+25
+125
°C
Δt/ΔV
input transition rise and fall rate VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
1.5
1.2
1.5
1.5
V
VCC = 4.5 V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
VCC = 2.0 V
0.8
0.5
0.5
0.5
V
VCC = 4.5 V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
VI = VIH or VIL
LOW-level
output voltage
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
±0.1
±1.0
±1.0
μA
80
160
μA
74HC138-Q100
VIH
VIL
VOH
VOL
HIGH-level
input voltage
LOW-level
input voltage
II
input leakage
current
ICC
supply current VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
CI
input
capacitance
3.5
74HC_HCT138_Q100
Product data sheet
VI = VCC or GND; VCC = 6.0 V
pF
5 / 15
Nexperia
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C
to +125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
74HCT138-Q100
VIH
HIGH-level
input voltage
VCC = 4.5 V to 5.5 V
2.0
1.6
2.0
2.0
V
VIL
LOW-level
input voltage
1.2
0.8
0.8
0.8
V
VOH
VI = VIH or VIL; VCC = 4.5 V
HIGH-level
output voltage
IO = -20 μA
4.4
4.5
4.4
4.4
V
3.98
4.32
3.84
3.7
V
IO = -4 mA
VOL
LOW-level
output voltage
IO = 20 μA
0.1
0.1
V
0.15
0.26
0.33
0.4
V
±0.1
±1.0
±1.0
μA
8.0
80
160
μA
per input pin; An inputs
150
540
675
735
μA
per input pin; En inputs
125
450
562.5
612.5
μA
per input pin; E3 input
100
360
450
490
μA
3.5
pF
IO = 4.0 mA
II
input leakage
current
ICC
VCC = 5.5 V
ΔICC
VI = VCC - 2.1 V;
additional
supply current other inputs at VCC or GND;
VCC = 4.5 V to 5.5 V; IO = 0 A
CI
input
capacitance
74HC_HCT138_Q100
Product data sheet
VI = VCC or GND; VCC = 5.5 V
6 / 15
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Fig. 9.
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C Unit
to +125 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
41
150
190
225
ns
VCC = 4.5 V
15
30
38
45
ns
VCC = 5 V; CL = 15 pF
12
ns
12
26
33
38
ns
VCC = 2.0 V
47
150
190
225
ns
VCC = 4.5 V
17
45
ns
14
ns
14
26
33
38
ns
VCC = 2.0 V
47
150
190
225
ns
VCC = 4.5 V
17
45
ns
14
ns
14
26
33
38
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
67
pF
74HC138-Q100
tpd
propagation
delay
An to Yn; see Fig. 7
[1]
VCC = 6.0 V
E3 to Yn; see Fig. 7
[1]
VCC = 6.0 V
En to Yn; see Fig. 8
[1]
VCC = 6.0 V
tt
CPD
transition time Yn; see Fig. 7 and Fig. 8
power
dissipation
capacitance
74HC_HCT138_Q100
Product data sheet
CL = 50 pF; f = 1 MHz;
VI = GND to VCC
[2]
[3]
7 / 15
Nexperia
Symbol Parameter
Conditions
Tamb = 25 °C
Tamb = -40 °C
to +85 °C
Tamb = -40 °C Unit
to +125 °C
Min
Typ
Max
Min
Max
Min
Max
VCC = 4.5 V
44
53
ns
17
ns
VCC = 4.5 V
18
40
50
60
ns
19
ns
VCC = 4.5 V
19
40
50
60
ns
19
ns
7
15
19
22
ns
67
pF
74HCT138-Q100
tpd
propagation
delay
[1]
[1]
[1]
tt
[2]
VCC = 4.5 V
CPD
[1]
[2]
[3]
power
dissipation
capacitance
VI = GND to VCC - 1.5 V
[3]
tpd is the same as tPLH and tPHL.
tt is the same as tTHL and tTLH.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
Σ(CL × VCC × fo) = sum of outputs.
10.1. Waveforms and test circuit
VCC
An, E3
input
VM
GND
tPHL
tPLH
VOH
Yn
output
VM
VOL
tTHL
tTLH
mna373
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with the output load.
Fig. 7.
Propagation delay input (An) and enable input (E3) to output (Yn) and transition time output (Yn)
74HC_HCT138_Q100
Product data sheet
8 / 15
Nexperia
VCC
E1, E2
VM
input
GND
tPHL
tPLH
VOH
Yn
output
VM
VOL
tTHL
tTLH
mna374
Fig. 8.
Propagation delay enable input (En) to output (Yn) and transition time output (Yn)
Table 8. Measurement points
Type
Input
Output
VM
VM
74HC138-Q100
0.5VCC
0.5VCC
74HCT138-Q100
1.3 V
1.3 V
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
G
VI
DUT
VCC
VO
RL
RT
S1
open
CL
001aad983
Test data is given in Table 9.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
CL = Load capacitance including jig and probe capacitance.
RL = Load resistance.
S1 = Test selection switch.
Fig. 9.
Test circuit for measuring switching times
Table 9. Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
tPZH, tPHZ
tPZL, tPLZ
74HC138-Q100
VCC
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HCT138-Q100
3V
6 ns
15 pF, 50 pF
1 kΩ
open
GND
VCC
74HC_HCT138_Q100
Product data sheet
9 / 15
Nexperia
11. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 10. Package outline SOT109-1 (SO16)
74HC_HCT138_Q100
Product data sheet
10 / 15
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 11. Package outline SOT403-1 (TSSOP16)
74HC_HCT138_Q100
Product data sheet
11 / 15
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 12. Package outline SOT763-1 (DHVQFN16)
74HC_HCT138_Q100
Product data sheet
12 / 15
Nexperia
12. Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MIL
Military
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74HC_HCT138_Q100 v.4
20210813
Product data sheet
74HC_HCT138_Q100 v.3
Modifications:
20200407
Modifications:
20180326
Modifications:
Section 2 updated.
Section 2 updated.
Fig. 6 corrected (Errata).
Table 4: Derating values for Ptot total power dissipation updated.
20150126
Modifications:
74HC_HCT138_Q100 v.1
20120716
Product data sheet
Product data sheet
74HC_HCT138_Q100 v.2
The format of this data sheet has been redesigned to comply with the identity guidelines
of Nexperia.
Legal texts have been adapted to the new company name where appropriate.
74HC_HCT138_Q100
Product data sheet
Product data sheet
Section 9: OFF-state output current removed because device has no 3-state outputs.
Section 10: Power dissipation capacitance condition for 74HCT138 is corrected.
Product data sheet
13 / 15
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74HC_HCT138_Q100
Product data sheet
14 / 15
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 3
6. Functional description................................................. 4
7. Limiting values............................................................. 4
8. Recommended operating conditions..........................5
9. Static characteristics....................................................5
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 8
11. Package outline........................................................ 10
12. Abbreviations............................................................ 13
13. Revision history........................................................13
14. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 13 August 2021
74HC_HCT138_Q100
Product data sheet
15 / 15
