74HC154D,653
74HC154D,653
    NEXPERIA(安世)
    SOIC24_300MIL
    4到16线解码器/多路分解器 SOIC24_300MIL 2~6V
74HC154D,653 数据手册
74HC154; 74HCT154 4-to-16 line decoder/demultiplexer Rev. 7 — 29 February 2016 Product data sheet 1. General description The 74HC154; 74HCT154 is a 4-to-16 line decoder/demultiplexer. It decodes four binary weighted address inputs (A0 to A3) to sixteen mutually exclusive outputs (Y0 to Y15). The device features two input enable (E0 and E1) inputs. A HIGH on either of the input enables forces the outputs HIGH. The device can be used as a 1-to-16 demultiplexer by using one of the enable inputs as the multiplexed data input. When the other enable input is LOW the addressed output will follow the state of the applied data. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2. Features and benefits     16-line demultiplexing capability Decodes 4 binary-coded inputs into 16 mutually-exclusive outputs Complies with JEDEC standard no. 7A Input levels:  For 74HC154: CMOS level  For 74HCT154: TTL level  ESD protection:  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V  Multiple package options  Specified from 40 C to +85 C and 40 C to +125 C 3. Ordering information Table 1. Ordering information Type number 74HC154D Package Temperature range Name Description Version 40 C to +125 C SO24 plastic small outline package; 24 leads; body width 7.5 mm SOT137-1 40 C to +125 C SSOP24 plastic shrink small outline package; 24 leads; body width 5.3 mm SOT340-1 40 C to +125 C TSSOP24 plastic thin shrink small outline package; 24 leads; body width 4.4 mm SOT355-1 40 C to +125 C DHVQFN24 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 24 terminals; body 3.5  5.5  0.85 mm 74HCT154D 74HC154DB 74HCT154DB 74HC154PW 74HCT154PW 74HC154BQ 74HCT154BQ SOT815-1 74HC154; 74HCT154 Nexperia 4-to-16 line decoder/demultiplexer 4. Functional diagram   $ $  $  $ (   '(&2'(5 (
74HC154D,653 价格&库存
很抱歉,暂时无法提供与“74HC154D,653”相匹配的价格&库存,您可以联系我们找货
