70L-IDC
70L-IDC
    GRAYHILLINC.
    Module
    INPUT MODULE DC 18MA 5VDC
70L-IDC 数据手册
DC Input Modules FEATURES • Fast Switching Polarized Input Types • UL, CSA, CE, TÜV Certified (TÜV not available on OpenLine ®) • Optical Isolation • OpenLine® and G5 Modules have Built-in Status LED 70L-IDC 70G-IDC 70-IDC 70M-IDC CIRCUITRY Standard, Mini, G5 + 1 OpenLine® I/O MODULE PIN # + 1 1 FILTER OPTICAL ISOLATION Rx TYPICAL WIRING FOR MODULE 0 6 Vcc CH. A STATUS GND VDC 2 A 7 HYSTERESIS INPUT DEVICE – +VCC 3 5 INPUT VOLTAGE HYST. CIRC. CURRENT REGULATING 2 2 + + DC SUPPLY INPUT DEVICE 3 3 FILTER OPTICAL ISOLATION B HYSTERESIS 8 CH. B STATUS OUTPUT 4 GROUND 5 – TERMINAL BLOCK # 4 BASE OR RACK 4 – 0Ω 9 MODULE ID Status LED in G5 modules only. MODULE SPECIFICATIONS: By Package Style Package Style Specifications Output Current Range Minimum Output Breakdown Voltage Isolation Voltage1 Vibration2 Mechanical Shock3 Storage Temp. Range Operating Temp. Range Warranty 1 2 3 Std (70-) Units mA Vdc Vrms 1-50 50 4000 MIL-STD-202 MIL-STD-202 -40 to 125 -40 to 100 Lifetime Mini (70M-) G5 (70G-) OL (70L-) I/O Modules °C °C 1-50 50 4000 MIL-STD-202 MIL-STD-202 -40 to 125 -40 to 100 Lifetime 1-50 50 4000 MIL-STD-202 MIL-STD-202 -40 to 125 -40 to 100 Lifetime 1-50 50 2500 IEC68-2-6 IEC68-2-27 -40 to 100 -40 to 85 Lifetime Field to logic and channel-to-channel if Grayhill racks are used. MIL-STD-202, Method 204, 20G, 10-2000 Hz or IEC68-2-6, 0.15 mm/sec2, 10-150 Hz. MIL-STD-202, Method 213, Condition F, 1500G or IEC68-2-27, 11 mS, 15g. I/O 18 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DC Input Modules SPECIFICATIONS: By Part Number Standard and Miniature Modules Type/Function Miniature, Polarized Standard, Non-Polarized Specifications Maximum Input Voltage Input Voltage Range1 Input Current @ Maximum Input Voltage Maximum Turn-On Time Maximum Turn-Off Time Nominal Input Resistance (Rx) Maximum Pick-Up Voltage (Output Low) Minimum Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Units Vdc Vdc mA mSec mSec Ω Vdc Vdc Vdc Vdc mA 32 3-32 18 0.20 0.40 1.8K 3 1 5 3-6 10 32 3-32 18 0.050 0.075 1.8K 3 1 5 3-6 18 16 2.5-16 30 0.025 0.030 500 2.5 1 5 3.5-6 18 32 3-32 18 0.20 0.40 1.8K 3 1 15 8-18 10 32 3-32 18 0.20 0.40 1.8K 3 1 24 15-30 10 70M-IDC5 70-IDC5 70-IDC5B Grayhill Part Number 70-IDC5K 70M-IDC15 70-IDC15 70M-IDC24 70-IDC24 G5 Modules Type/Function G5, Polarized, Status LED Specifications Maximum Input Voltage Input Voltage Range1 Input Current @ Maximum Input Voltage Maximum Turn-On Time Maximum Turn-Off Time Nominal Input Resistance (Rx) Maximum Pick-Up Voltage (Output Low) Minimum Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Units Vdc Vdc mA mSec mSec Ω Vdc Vdc Vdc Vdc mA 32 3-32 18 0.20 0.40 1.8K 3 1 5 4.5-6 10 32 3-32 18 0.050 0.075 1.8K 3 1 5 4.5-6 18 28 2.5-28 23 0.050 0.075 1.2K 2.5 1 5 4.5-6 10 16 2.5-16 30 0.025 0.030 500 2.5 1 5 4.5-6 18 32 3-32 18 0.20 0.40 1.8K 3 1 15 10-18 10 32 3-32 18 0.20 0.40 1.8K 3 1 24 17-30 10 70G-IDC5 70G-IDC5B Grayhill Part Number 70G-IDC5D 70G-IDC5K 70G-IDC15 70G-IDC24 OpenLine® Modules Type/Function Dual, Polarized Specifications Maximum Input Voltage Input Voltage Range1 Input Current @ Max. Input Voltage Maximum Turn-on Time Maximum Turn-off Time Nominal Input Resistance (Rx) Maximum Pick-Up Voltage (Output Low) Minimum Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Module ID Resistance to Logic Ground 1 Grayhill Part Number 70L-IDC Units Vdc Vdc mA mSec mSec Ω Vdc Vdc Vdc Vdc mA Ω 32 0-32 18 0.20 0.40 1800 3 0.9 5 4.5-28 6/CH 0 32 0-32 18 0.05 0.075 900 3 0.9 5 4.5-28 6/CH 0 70L-IDCB Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. I/O Modules For input voltages in the range of 90 to 140 Vdc, use AC input modules 70-IAC5, 70M-IAC5, 70G-IAC5 or 70L-IAC. For input voltages in the range of 180 to 280 Vdc, use AC input modules 70-IAC5A, 70M-IAC5A, 70G-IAC5A or 70L-IACA. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com I/O 19
70L-IDC 价格&库存
很抱歉,暂时无法提供与“70L-IDC”相匹配的价格&库存,您可以联系我们找货
70L-IDC
  • 5+194.53214
  • 100+180.42194
库存:112
