70MRCK24-HL
70MRCK24-HL
    GRAYHILLINC.
    I/O MOUNTING BOARD MINI 24POS
70MRCK24-HL 数据手册
System 50 RACKS 24 Channel (In-Line) FEATURES • For use with System 50 Style Controllers • Available for Standard, Miniature, G5 and OpenLine® Modules • UL, CSA Certified 24 CHANNEL RACK: Standard Part No. 70RCK24 Dimensions are shown in inches (and millimeters). Tolerances are ± 0.010 (0,25) unless indicated otherwise. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 5A FUSE 18.75 (476,3) 16.50 (419,1) 11.00 (279,4) STANDOFF I.D. 0.15 (3,8) DIA. (8 PLACES) CLEARANCE FOR #6 SCREWS 5.50 (139,7) 1.12 (28,4) FIELD WIRING TERMINAL STRIP 4.50 (114,3) 4.00 (101,6) 0 1 –+ 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 Y AC INPUT B AC OUTPUT W DC INPUT R DC OUTPUT 21 22 23 0.25 (6,4) 1A FUSE SOCKETS FOR OPTIONAL 1A FUSE LOGIC SUPPLY TERMINAL STRIP 0.40 (10,2) KEY SLOT PINS 23/25 2.60 (66,0) 1.00 (25.4) (2 PLACES) 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) 8.08 (205,2) 2.20 (55,9) MAX. 0.75 (19,1) G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 System 50 System 50 18 System 50 24 CHANNEL RACK: Miniature Part No. 70MRCK24 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 13.45 (341,6) 12.00 (304,8) 8.00 (203,2) 0.73 (18,5) 4.00 (101,6) FIELD WIRING TERMINAL STRIPS (3 PLACES) 0.35 (8,9) 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 5A FUSE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 3.75 (95,3) STATUS LED 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 Y B W R 3.05 (77,5) 20 AC INPUT AC OUTPUT DC INPUT DC OUTPUT 21 22 23 – + LOGIC SUPPLY TERMINAL STRIP SOCKETS FOR OPTIONAL 1A FUSE 1A FUSE PIN 1 KEY SLOT PINS 23/25 2.60 (66,0) 0.40 (10,2) 5.42 (137,7) MODULE HOLD DOWN STRIP WITH THUMB SCREWS 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTE) STANDOFF I.D. 0.15 (3,8) DIA. (8 PLACES) CLEARANCE FOR #6 SCREWS 2.20 (55,9) MAX. 0.75 (19,1) 24 CHANNEL RACK: OpenLine® Part No. 70LRCK24 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 0.250 (6,3) M0 M1 M2 M3 7.500 (190,5) 7.000 (177,8) M4 M5 M6 M7 M8 M9 M10 M11 4.270 (108,5) 50-PIN STRAIGHT HEADER CONNECTOR 50 49 A B 2 1 System 50 REMOVABLE JUMPER CONNECTS GND TO EARTH GROUND 3.800 (96,5) PIN 1 5A FUSE 0.238 (6,0) STANDOFF I.D. (3,81) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW FIELD WIRING TERMINAL STRIP NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. +5 +5 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 3.383 (85,9) MAX. LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GROUND 0.750 (19,0) REF. System 50 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 19 System 50 24 CHANNEL RACK: OpenLine® DIN Rail Mount for System 50 Part No. 70LRCK24-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. DIN CARRIER 7.7 (194.56) PCB 7.5 (190.50) M0 M1 M2 M3 M4 M5 M6 M7 M8 M9 M10 M11 DIN CARRIER 4.7 (119.13) 50-PIN STRAIGHT HEADER CONNECTOR 50 49 A B PCB 4.3 (108.46) REMOVABLE JUMPER CONNECTS GND TO PLATED HOLE FOR GROUNDING PIN 1 2 1 5A FUSE NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND +5 +5 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 3.8 (95.81) REF 48 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 2.2 (56.49) SCHEMATIC: Part Nos. 70RCK24 and 70MRCK24 LOGIC SUPPLY TERMINAL STRIP – + 1A OPTIONAL 1A FUSE 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 WIRING FIELD 1 2 3 4 5 TERMINAL STRIP 5A System 50 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 MODULE POSITION 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS 3.3K G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 20 System 50 SCHEMATIC: Part No. 70LRCK24 1 MOUNTING POST FOR EARTH GROUND CONNECTION LOGIC SUPPLY TERMINAL STRIP – – + + M0 2 1 2 3 4 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 FIELD 48 WIRING TERMINAL STRIP M1 5 6 7 8 9 M2 M3 M4 M5 M6 M7 M8 M9 M10 M11 MODULE LOCATION 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 PULL-UP RESISTOR NETWORK 10K OHM (3 PLACES) ORDERING INFORMATION Part Number 70RCK24 70RCK24-HL 70MRCK24-EC 70MRCK24-HL 70LRCK24-HL 70LRCK24-DIN I/O 24 24 24 24 24 24 (modules ordered separately) UL ejector levers ejector levers ejector levers rail mount X X X X X X CSA X X X X X X Style Standard Standard Mini Mini OpenLine ® OpenLine® Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. Description Card edge 50-pin header with Card edge 50-pin header with 50-pin header with 50-pin header, DIN System 50 System 50 21 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
70MRCK24-HL 价格&库存
很抱歉,暂时无法提供与“70MRCK24-HL”相匹配的价格&库存,您可以联系我们找货
70MRCK24-HL
    • 1+2021.83322
    • 6+1816.68518
    • 11+1741.97488
    库存:2
    70MRCK24-HL
    • 1+2640.744041+341.62056
    • 10+2351.1318910+304.15481
    • 25+2244.7677525+290.39498
    库存:9
