70MRCK8-HL
70MRCK8-HL
    GRAYHILLINC.
    I/O MOUNTING BOARD MINI 8POS
70MRCK8-HL 数据手册
System 50 RACKS 8 Channel FEATURES • For use with System 50 Style Controllers • Available for Standard Miniature and OpenLine® Modules • Panel and DIN Rail Mount Versions • UL, CSA Certified 8 CHANNEL RACK: Standard Part No. 70RCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 8.00 (203,2) CARD EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS. (SEE NOTES) 0.45 (11,4) KEY SLOT PINS 5/7 7.50 (190,5) TERMINAL STRIP FOR LOGIC SUPPLY 25/49 TERMINAL STRIP FOR FIELD WIRING STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW - 1.40 (35,6) 0.30 (7,6) PIN 1 Y B W R AC INPUT AC OUTPUT DC INPUT DC OUTPUT 2.60 (66,0) 0 0.40 (10,2) 1 2 3 4 5 6 7 USER INSTALLABLE JUMPERS FOR +VCC (3 PLACES) 0.25 (6,4) 2.20 (55,9) MAX. 0.75 (19,1) G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 + + + 3.00 (76,2) 3.50 (88,9) 1 1 + System 50 0.25 (6,4) System 50 6 System 50 8 CHANNEL RACK: DIN Rail Mount Part No. 70LRCK8-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. DIN CARRIER 3.7 (92.96) PCB 3.5 (89.15) M0 M1 M2 M3 DIN CARRIER 4.7 (119.13) PCB 4.3 (108.46) 50-PIN STRAIGHT HEADER CONNECTOR 50 49 A B REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 3.15A FUSE PIN 1 2 1 FIELD WIRING TERMINAL STRIP NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. +5 +5 1 3 5 7 9 11 13 15 3.8 (95.81) REF 16 2 4 6 8 10 12 14 2.2 (56.49) LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND System 50 System 50 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 7 System 50 8 CHANNEL RACK: Miniature Part No. 70MRCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 0.40 (10,2) 0.45 (11,4) 6.00 (152,4) 5.20 (132,1) LOGIC SUPPLY TERMINAL STRIP FIELD WIRING TERMINAL STRIP 0.25 (6,35) NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS +– 2.60 66,0) 1.40 (35,6) KEY SLOT PINS 5/7 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 3.00 (76,2) 3.50 (88,9) PIN 1 CARD EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) MODULE HOLD DOWN STRIP WITH THUMB SCREWS Y B W R AC INPUT AC OUTPUT DC INPUT DC OUTPUT 0 1 2 3 4 5 6 7 STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW STATUS LED 5A FUSE 2.20 (55,9) MAX. 0.75 (19,1) 8 CHANNEL RACK: G5 Part No. 70GRCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 6.00 (152,4) .620 (15,75) 5.125 (130,18) LOGIC SUPPLY TERMINAL STRIP .250 (6,35) +– HOLES FOR USER INSTALLED JUMPER (22 AWG) COPPER WIRE 2.750 (69,85) 3.250 (82,55) System 50 PIN 1 50 PIN STRAIGHT HEADER CONNECTOR STATUS LED ON THE MODULE STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW FUSE PULLER 3.40 (86,4) MAX. .75 (19,1) .093 (2,36) REF. G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 8 System 50 8 CHANNEL RACK: OpenLine® System 50 Part No. 70LRCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 3.5 (88.90) .24 (6.05) .25 (6.35) 3.0 (76.20) M0 M1 M2 M3 50-PIN STRAIGHT HEADER CONNECTOR 50 49 A B 4.3 (108.46) 3.8 (96.52) 3.15A FUSE PIN 1 REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 2 1 FIELD WIRING TERMINAL STRIP STANDOFF I.D. 0.15 (3.81) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND 3.4 (85.93) MAX +5 +5 1 3 5 7 9 11 13 15 2 4 6 8 10 12 14 16 .75 (19.05) REF SCHEMATIC: Part Nos. 70RCK8, 70MRCK8 LOGIC SUPPLY TERMINAL STRIP – + 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 FIELD WIRING TERMINAL STRIP System 50 26 24 22 20 18 16 14 12 10 8 6 4 2 ••• 25 23 21 19 17 15 13 11 9 7 N/C 5 N/C 3 N/C 1 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 1 2 3 4 5 5A FUSE 0 1 2 3 4 5 6 7 MODULE POSITION N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C 26-PIN EDGE CONNECTOR FOR LOGIC SIGNALS 3.3K 50-PIN EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS USER INSTALLABLE JUMPERS FOR +VCC (3 PLACES) System 50 G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 9 System 50 SCHEMATIC: Part No. 70GRCK8 LOGIC SUPPLY TERMINAL STRIP – + USER INSTALLABLE JUMPER FOR +VCC 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 FIELD WIRING TERMINAL STRIP 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 1 2 3 4 5 0 1 2 3 4 5 6 7 MODULE POSITION N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C 3.3K 50 PIN HEADER CONNECTOR FOR LOGIC SIGNALS SCHEMATIC: Part No. 70LRCK8 – LOGIC – SUPPLY TERMINAL + STRIP + 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 FIELD WIRING TERMINAL STRIP 1 2 3 4 M0 M1 M2 MODULE LOCATION M3 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 5 6 7 8 9 N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C System 50 PULL-UP RESISTOR NETWORK 10K OHM ORDERING INFORMATION Part Number 70RCK8 70RCK8-HL 70MRCK8-EC 70MRCK8-HL 70GRCK8-HL 70LRCK8-HL 70LRCK8-DIN I/O 8 8 8 8 8 8 8 (modules ordered separately) UL with ejector levers with ejector levers with ejector levers with ejector levers with DIN rail mount X X X X X Pend Pend CSA X X X X X Pend Pend Style Standard Standard Mini Mini G5 OpenLine® OpenLine® Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Description Card edge 50-pin header Card edge 50-pin header 50-pin header 50-pin header 50-pin header G rayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 10
70MRCK8-HL 价格&库存
很抱歉,暂时无法提供与“70MRCK8-HL”相匹配的价格&库存,您可以联系我们找货
70MRCK8-HL
  • 1+1093.174231+141.43127
  • 10+973.4412010+125.94061
  • 25+929.4451125+120.24854
  • 50+897.4695250+116.11164
  • 100+866.57897100+112.11512
库存:5
