INSTRUCTIONS MANUAL TB-6122
Limit Comparator
Operating Instructions
Made in America
5. Turn the rotary knob on the resistor box to "x Ω LOW"
(select x = 1.91MΩ or the optional low limit fail low,
according to what operator low limit the ZVM is calibrated
at). Observe the operator 1 LED display on the front of the
ZVM. The yellow LED should be illuminated (for
62030/62034/62036 units only, audible alarm will not sound
when testing the low limit) indicating the fail low condition.
6. Turn the rotary knob on the resistor box to "x Ω SAFE"
(select x = 1.91MΩ or the optional low limit pass safe,
at). The green LED on the ZVM operator 1 display should
be on, indicating the low limit pass safe condition.
Figure 1. 62170 Limit Comparator
1. The purpose of the DUAL WIRE Limit Comparator
Operator Calibration Check Resistor Box is to verify the
calibration of the ZVM 62002(ZVM1002) and the
62030(SE900-1) by checking 4 operator conditions: FAIL
LOW, PASS SAFE (low limit), PASS SAFE (high limit), and
FAIL HIGH.
2. There are 10 resistor settings on the resistor box, which
can be set using the rotary switch. Positions 3 through 8
have installed values. Positions 1, 2, 9, and 10 can be
installed by the user for one set each of custom low and
high limits. The standard settings are as follows:
POSITION:
1.)
2.)
-----------------------------3.)
1.91 MΩ FAIL LOW
4.)
1.91 MΩ PASS SAFE (ZVM default settings)
5.)
10 MΩ PASS SAFE
6.)
10 MΩ FAIL HIGH
-----------------------------7.)
35 MΩ PASS SAFE
8.)
35 MΩ FAIL HIGH
9.)
optional high limit pass safe
10.)
optional high limit fail high
7. Turn the rotary knob on the resistor box to "x MΩ SAFE"
(select x = 10MΩ , 35MΩ or the optional high limit pass
safe, according to what operator high limit the ZVM is
calibrated at). The green LED on the ZVM operator 1
display should be on, indicating the high limit pass safe
condition.
8. Turn the rotary knob on the resistor box to "x MΩ HIGH"
(select x = 10MΩ , 35MΩ or optional high limit fail high,
according to what operator high limit the ZVM or is
calibrated at). The red LED on the ZVM operator 1 display
should be on and the audible alarm should sound,
indicating the fail high condition.
9. Disconnect the resistor box plug from the operator 1
remote jack. Plug the resistor box plug into the operator 2
remote jack and repeat the four tests in steps 5 through 8 to
test operator 2.
10. The correct color LED's must light for each step for the
ZVM to completely pass the calibration check. If an
incorrect LED comes on during any portion of the test
(example: expecting the green LED to light in step 7 but
the ZVM red LED is on) recalibrate the ZVM with the ZVMPRG (making certain that the correct calibration resistances
are installed in the ZVM-PRG and the correct procedures
are followed for that unit) and test each operator again with
the EN445-ZVM cal check resistor box.
Installing Optional Low and High Limit Resistances
PLEASE NOTE THAT THE ZVM OPERATOR
CALIBRATION CHECK RESISTOR BOX IS USED TO
CHECK ONE OPERATOR AT A TIME.
A.) Use a hex wrench to remove the rotary switch knob.
Unscrew the 2 screws on the back of the unit and
disassemble the unit.
3. Ensure that the ZVM to be checked is set up as
described in the operating instructions and has power.
4. Connect the plug from the resistor box into the
OPERATOR 1 remote jack.
ESD Systems.com • 432 Northboro Road Central • Marlboro, MA 01752 • (508) 485-7390 • Fax (508) 480-0257 • Website: ESDSystems.com
© 2009 DESCO INDUSTRIES INC.
TB-6122 January 2009 Page 1 of 2
Employee Owned
B.) Two resistances must be installed for each limit: one
for PASS SAFE and another for FAIL. These two
resistances should be ±10% of the calibrating resistance.
For example:
C.) The table below specifies which numbered resistances
on the circuit board correspond to the optional low limit and
the optional high limit. Solder the appropriate resistors in
these places.
Contact and Warranty
ESD Systems
Marlboro, MA 01752
Tel: (508) 485-7390
Fax: (508) 480-0257
NOTE: Unauthorized servicing or modifications to your
monitor will void the product warranty and may create
dangerous conditions. Servicing should be performed
only at the factory, or by a Semtronics approved
technician.
LIMITED WARRANTY
NOTE: Two (three for position 10) resistor locations are
connected in series are provided in case resistors need to
be added to achieve the desired total resistance. Solder a
shorting wire across the resistor locations that are not used.
D.) Assemble the unit and mark the appropriate places on
the label for the optional limits.
E.) It is recommended to turn the rotary switch to the
optional positions and measure the resistance from the tip
to the body of the plug with an ohmmeter to verify the
resistances.
ESD Systems expressly warrants that for a period of
one (1) year from the date of purchase, the ESD
Systems Footwear Tester will be free of defects in
material (parts) and workmanship (labor). Within the
warranty period, a unit will be tested, repaired, or
replaced at our option, free of charge. Call Customer
Service at 909-627-8178 (Chino, CA) or 781-821-8370
(Canton, MA) for Return Material Authorization (RMA)
and proper shipping instructions and address. Include a
copy of your original packing slip, invoice, or other proof
of date of purchase. Any unit under warranty should be
shipped prepaid to the Semtronics factory. Warranty
replacements will take approximately two weeks. If your
unit is out of warranty, ESD Systems will quote repair
charges necessary to bring your unit up to factory
standards. Call Customer Service at 909-627-8178 for
proper shipping instructions and address. Ship your unit
freight prepaid.
WARRANTY EXCLUSIONS
THE FOREGOING EXPRESS WARRANTY IS MADE
IN LIEU OF ALL OTHER PRODUCT WARRANTIES,
EXPRESSED AND IMPLIED, INCLUDING
MERCHANTABILITY AND FITNESS FOR A
PARTICULAR PURPOSE WHICH ARE SPECIFICALLY
DISCLAIMED. The expres
s warranty will not apply to defects or damage due to
accidents, neglect, misuse, alterations, operator error,
or failure to properly maintain, clean or repair products.
LIMIT OF LIABILITY
Maintenance
Wipe the plug periodically with alcohol.
In no event will ESD Systems or any seller be
responsible or liable for any injury, loss or damage,
direct or consequential, arising out of the use of or the
inability to use the product. Before using, users shall
determine the suitability of the product for their intended
use, and users assume all risk and liability whatsoever
in connection therewith.
TB-6122 Page 2 of 2
Employee Owned
很抱歉,暂时无法提供与“62170”相匹配的价格&库存,您可以联系我们找货
