37004
37004
    DESCO
    SHIPPER ESD SMALL 3-3/4X3-3/4X1
37004 数据手册
Features D W L • Efficient means of shipping or storing ESD sensitive circuit boards and other items, enclosed provides discharge sheilding protection. • For physical protection, foam secures items, minimizing movement and reduces stress from physical shock • Pink static dissipative foam (1/2" thick, Rtt < 1 x 1011 ohms) laminated to top, and conductive crosslink black polyethylene foam (1/4" thick, Rtt < 1 x 104 ohms) in bottom (All dimensions are ± 1/16") • Impregnated corrugated static dissipative surface of 1 x 106 to < 1 x 109 ohms per ANSI/ESD STM11.11 • No assembly required • Custom foam configurations available • Made in the United States of America ITEM Size ID - L x W x D (IN) ITEM Size ID - L x W x D (IN) 37000 2-1/2" x 1-1/4" x 1" 37009 4-3/8" x 4-3/8" x 1" 37008 2-3/4" x 2-3/4" x 1" 37002 4-1/2" x 1-1/4" x 1" 37001 3-1/2" x 1-1/4" x 1" 37010 • 4-1/2" x 3-3/4" x 1" 37003 3-7/16" x 2-1/8" x 1" 37007 5-1/4" x 1-1/4" x 1" 37004 3-3/4" x 3-3/4" x 1" 37005 7" x 3-1/2" x 1" 37006 4-1/8" x 3-1/16" x 1" 37011 • 12-7/8" x 4" x 1" Dimensional tolerances are +/- 1/8" unless otherwise specified • Items Made to Order Meets the required limits of ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, and worksurface standard ANSI/ESD S4.1 SPECIFICATIONS Properties Surface Resistance Sloughing Test Recyclability Typical Values Test Procedures/Method ANSI/ESD STM11.11 1 x 106 to < 1 x 109 ohms Negligible surface damage at 10 cycles and
37004 价格&库存
很抱歉,暂时无法提供与“37004”相匹配的价格&库存,您可以联系我们找货
