38900
38900
    DESCO
    BOX OPEN BIN PLASTEK 12X2X4
38900 数据手册
Features Made in the • Provides physical protection, with conductive material United States of America providing reliable path-to-ground • Many sizes available • Shipped knocked-down; easy to assemble • Conductive 1 x 102 to < 1 x 105 ohms material provides reliable path-to-ground • Superior strength and durability; made from extruded, high impact polypropylene materials • Chemical and moisture resistant • Ideal for use where corrugated and/or paper products cannot be used • Economical alternative to injection molded products • Reusable, ensuring best value* • Made in the United States of America D L Specifications W Item L x W x D (IN) L x W x D (MM) 38900 12 x 2 x 4 305 x 51 x 102 38901 12 x 4 x 4 305 x 102 x 102 38902 12 x 6 x 4 305 x 152 x 102 38903 12 x 8 x 4 305 x 203 x 102 38904 18 x 4 x 4 457 x 102 x 102 38905 18 x 6 x 4 457 x 152 x 102 38906 38907 18 x 8 x 4 24 x 4 x 4 457 x 203 x 102 610 x 102 x 102 38908 24 x 6 x 4 610 x 152 x 102 38909 18 x 2 x 4 457 x 51 x 102 Properties Resin Type Conductive Surface Resistance Humidity Independent Temperature Tolerance Melting Point Typical Values Polypropylene Permanently 1 x 102 to < 1 x 105 ohms per ANSI/ESD STM11.11 and ESD TR53 Yes -17° F to +230° F 324° F RoHS 2 and REACH Compliance Statement None of the RoHS 2 restricted materials or REACH substances of very high concern as of 2013/06/20 are intentionally added in manufacturing this product. Ref: European Union Directive 2011/65/EU and Regulation (EC) No. 1907/2006/CE. See Protektive Pak Limited Warranty at ProtektivePak.com. Per Packaging standard ANSI/ESD S54.1 section 6.1. Inside an ESD Protected Area “Packaging used within an EPA (that satisfies the minimum requirements of ANSI/ESD S20.20) shall be: 1. Low charge generation. 2. Dissipative or conductive materials for intimate contact.” 38910 24 x 2 x 4 610 x 51 x 102 38911 12 x 12 x 4 305 x 305 x 102 Unless otherwise noted, tolerance ± 10% 38912 18 x 12 x 4 457 x 305 x 102 Specifications and procedures subject to change without notice. Plastek™ Open Bin Boxes PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578 ProtektivePak.com © 2014 DESCO INDUSTRIES INC. Employee Owned DRAWING NUMBER 38900 DATE: January 2014
38900 价格&库存
很抱歉,暂时无法提供与“38900”相匹配的价格&库存,您可以联系我们找货
