1501622
1501622
    SCS
    BAGSTATICSHLDMTLOUT22"X16"
1501622 数据手册
Metal-Out Static Shielding Bag 1500 This transparent metal-out static shielding bag is designed to provide static safe packaging for the shipment and/or storage of ESD sensitive items including outside ESD protected areas. Bags are printed with an ESD protective symbol and a lot code for traceability. Open Top and ZipTop styles are available. The bags are heat sealable. SCS Metal-Out Static Shielding Bags 1500 are manufactured from a top coat, metal, polyester, polyethylene laminate. The proprietary top coating is designed to protect the metal layer. Polyester dielectric, in concert with the metal layer, is intended to provide shielding of Electrostatic Discharge (ESD) and to help minimize the penetration of electric field. OpenTop Top Bag Bag Open ZipTop Bag ZipTop Bag Tolerance: Width -0, +1/4" Width -0, +0.250 Length Note:+/Standard bag markings shown Tolerance (inches): 0.125 Offset O to 0.250 Length Seal +/- 1/8" Offset to 1/4" above and are not to scale. width +/-00.125 Seal width 3/8" with a tolerance of +/- 1/8" Meets ANSI/ESD S20.20 Packaging Standard, ANSI/ESD S541, and Static Control Bag ANSI/ESD S11.4 Level 3 Physical Typical Value Testing Method Puncture Resistance 10 lbs, 44 N MIL-STD-3010 Method 2065 Seal Strength 14 lbs, 62 N ASTM D882 Thickness 3 mils, .0762 mm +/-10% MIL-STD-3010 Test Method 1003 Method B Marking Adhesion Pass IPC-TM-650 2.4.1 Transparency 40% Tobias Electrical Typical Value Testing Method Discharge Shielding
1501622
物料型号:1500系列金属外静电屏蔽袋
器件简介:该透明金属外静电屏蔽袋设计用于在ESD保护区域外运输和/或存储静电敏感物品的静电安全包装。袋子上印有ESD保护符号和批次代码,以实现可追溯性。提供开放式和ZipTop款式,袋子可热封。
引脚分配:文档中未提及引脚分配
参数特性: - 抗穿刺性:10磅,44N - 封口强度:14磅,62N - 厚度:3密耳,0.0762毫米±10% - 标记附着力:通过 - 透明度:40% - 电气特性: - 放电屏蔽:小于10nJ - 内部表面电阻:1x10^4至小于1x10^11欧姆 - 外部表面电阻:1x10^4至小于1x10^6欧姆 - 电荷保持:小于100伏特
功能详解:袋子由顶层涂层、金属层、聚酯层和聚乙烯层组成。顶层涂层旨在保护金属层。聚酯介质与金属层协同工作,提供静电放电屏蔽,并帮助最小化电场的穿透。
应用信息:符合ANSI/ESD S20.20包装标准、ANSI/ESD S541和ANSI/ESD S11.4级别3。
封装信息:袋子不含胺、辛酸、硅酮和重金属。产品仅供商业用途,不在国防标准化计划的合格产品列表上。规格和程序如有更改,恕不另行通知。
1501622 价格&库存
很抱歉,暂时无法提供与“1501622”相匹配的价格&库存,您可以联系我们找货
