13715
13715
    DESCO
    BAG SHLD MET-IN ZIP 15X18
13715 数据手册
STATSHIELD® METAL-IN SERIES Low Charging Clear Zipper Specifications: Standard Document ANSI/ESD S541 (ANSI/ESD S20.20) ANSI/ESD S11.4 Lip 1" (±0.125") Electrical Properties Surface Resistance:   Outer Surface   Inner Surface Discharge Shielding Charge Generation Capacitance Probe (to dissipate 1 KV) Physical Properties Date & Lot Code Weld Seal Side Weld Seals 0.375" (±0.10") Soft Fold Bottom ** Bags are printed (hot stamped or thermal transferred) with an ESD protective symbol and a lot code for traceability. ** Low Charging Static Dissipative Proprietary Outer Polyester Layer Aluminum Shielding Layer Low Charging Static Dissipative Proprietary Inner Polyethylene Layer 7 Film Thickness Width (Inside Dimensions) Length (Inside Dimensions) Light Transmission Heat Seal Tensile Strength Puncture Resistance Silicone Marking Adhesion Meets Requirements of: ESD Protective Packaging Level 3 Technical Requirements Typical Values Test Procedures/Method 1 x 104 to < 1 x 1011 ohms 1 x 104 to < 1 x 1011 ohms 10 lbs/in 4600 PSI, 32 MPa >10 lbs Not detected Pass MIL-STD-3010, 1003 ANSI/ESD S541 Section 6.2 Outside an EPA “Transportation of sensitive products outside of an EPA shall require packaging that provides: 1. Low charge generation 2. Dissipative or conductive materials for intimate contact 3. A structure that provides electrostatic discharge shielding.” RoHS, REACH and Conflict Minerals Statement See the Desco Industries RoHS, REACH, and Conflict Minerals Statement: https://desco.descoindustries.com/pdf/Regulatory_Statements_Desco_Statshield_Bags.pdf See the Desco Limited Warranty: Desco.DescoIndustries.com/Limited-Warranty.aspx Mixed Unsortable Plastic Scrap Mixed unsortable plastic scrap shall contain assorted plastics of multiple grades that are co-extruded, bonded or laminated together which are unsortable into individual grades Desco’s bags are recyclable Statshield® bags are packaged 100 per package in an oversized shielding bag. See Shielding Bag Storage at TB-7057. Statshield® and Statfree® are Registered Trademarks of Desco Industries Inc. See Bag Selection Chart Click HERE STATSHIELD® BAG, SHIELDING, METAL-IN CONSTRUCTION, ZIPPER, 3.0 MIL (0.07mm) DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407 PHONE (781) 821-8370 © 2021 DESCO INDUSTRIES INC Made in the United States of America Specifications and procedures subject to change without notice. DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com PHONE (909) 627-8178 Employee Owned ASTM D-1003 375°F, 1/2 sec 60 psi ASTM 882 MIL-STD-3010, 2065 FTIR IPC-TM-650 2.4.1 DRAWING NUMBER 13605 DATE: September 2021
13715 价格&库存
很抱歉,暂时无法提供与“13715”相匹配的价格&库存,您可以联系我们找货
