Moisture Barrier Bag Dri-Shield® 3700
This foil moisture barrier bag provides superior protection for ESD
sensitive and moisture sensitive electronics, typically SMT (Surface
Mount Technology) items. Best practice is to use with Desiccant and
a Humidity Indicator Card. The bags are heat sealable and suitable
for vacuum packaging. Bags are printed with ESD protective and
moisture sensitive warning symbols and a lot code for traceability.
Meets ANSI/ESD S20.20, Packaging standard ANSI/ESD S541,
Static Control Bag ANSI/ESD S11.4 Level 1, and IPC/JEDEC J-STD-033.
Physical
Typical Value
Testing Method
Moisture Vapor
Transmission Rate
(MVTR)
< 0.0003 grams/100 sq. in./24 hrs
< 0.002 grams/100 sq. in./24 hrs
ASTM F1249
ASTM F392 condition E and
ASTM F2149
Tensile Strength
9900 PSI, 68 MPa
ASTM D882
Puncture Resistance
25 lbs, 111 N
MIL-STD-3010C Method
2065
15 lbs, 66 N
ASTM D882
SCS Moisture Barrier Bags Dri-Shield® 3700 are manufactured
from a laminate of polyester, foil, and polyethylene. The metal layer
Seal Strength
provides discharge shielding and minimizes the penetration of
Open Top Bag
ZipTop Bag
Thickness
electric fields and electrostatic discharges.
Tolerance: Width -0, +1/4"
Length +/- 1/8" Offset 0 to 1/4"
Seal width 3/8" with a tolerance of +/- 1/8"
Note: Standard bag markings shown
above are not to scale.
4.2 mils, 0.1067 mm +/-10%
MIL-STD-3010 Method 1003
Marking Adhesion
Pass
IPC-TM-650 2.4.1
Electrical
Typical Value
Testing Method
ESD Shielding
很抱歉,暂时无法提供与“D37128”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+8.649111000+1.10943
