7001114
7001114
    SCS
    BAGMOISTBARRDUALLAYER14X11"
7001114 数据手册
Moisture Barrier Bag Dri-Shield® 2000 This aluminized moisture barrier bag is designed to provide packaging for ESD and moisture sensitive items, both inside and outside an ESD protected area. The bags are heat sealable and suitable for vacuum packaging. Bags are printed with ESD and moisture warning symbols and a lot code for traceability. SCS Moisture Barrier Bags Dri-Shield® 2000 are manufactured from a laminate of multiple layers of aluminized polyester and polyethylene. Polyester provides puncture resistance. Metal layers are intended to provide shielding of Electrostatic Discharge (ESD) and to help minimize the penetration of electric field while providing moisture protection. OPENING OFFSET Moisture Barrier Bag DRI-SHIELD® 2000 Discharge Shielding LENGTH Tolerance: Width -0, +1/4" Length ± 1/8" Offset 0 to 1/4" Seal width 3/8" with a tolerance of ± 1/8" Note: Standard bag markings shown above are not to scale. SEAL 7 11 OTHER PET/ALU/PE ATTENTION: Contents may be Moisture and Static Sensitive LOT 32910987654321 ** Bags are printed (hot stamp or thermal) with an ESD protective symbol and a lot code for traceability. ** FOLD WIDTH SEAL WIDTH STATIC DISSIPATIVE POLYESTER ALUMINUM SHIELD POLYESTER Meets ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, and Static Control Bag ANSI/ESD S11.4 Level 3 (except Transparency) Made in the United States of America Physical Typical Value Moisture Vapor Transmission Rate (MVTR)
7001114 价格&库存
很抱歉,暂时无法提供与“7001114”相匹配的价格&库存,您可以联系我们找货
