OPENING
OFFSET
Specifications:
LENGTH
SEAL
Date & Lot Code
FOLD
WELD
SEAL
WIDTH
Side Weld Seals 3/8 in. (± 1/8)
** Bags are printed (hot stamped or thermal transferred) with
an ESD protective symbol and a lot code for traceability. **
Static Dissipative
Polyester
Aluminum Shielding
Layer
Polyester Layer
Aluminum Shielding Layer
STATSHIELD® STANDARD MOISTURE BARRIER BAG
Standard Document
ANSI/ESD S541 (ANSI/ESD S20.20)
ANSI/ESD S11.4
Meets Requirements of:
ESD Protective Packaging
Level 2 except MVTR
Electrical Properties
Surface Resistance
(both exterior and interior)
Discharge Shielding
Static Shielding
Charge Generation
Teflon
Quartz
Typical Values
Test Procedures/Method
1 x 104 to < 1 x 1011 ohms
很抱歉,暂时无法提供与“13828”相匹配的价格&库存,您可以联系我们找货
