D27430
D27430
    SCS
    BAGMOISTUREBARDUALLAYER30X4
D27430 数据手册
Moisture Barrier Bag Dri-Shield® 2700 This aluminized moisture barrier bag is designed to provide a static safe environment for sensitive electronic devices. A stronger polyester layer helps to prevent sharp trays from puncturing the bag. The bags are heat sealable and suitable for vacuum packaging. Bags are printed with ESD and moisture warning symbols and a lot code for traceability. SCS Moisture Barrier Bags Dri-Shield® 2700 are manufactured from a laminate of multiple layers of aluminized polyester and polyethylene. Polyester provides puncture resistance. Metal layers are intended to provide shielding of Electrostatic Discharge (ESD) and to help minimize the penetration of electric field. OPENING OFFSET Moisture Barrier Bag DRI-SHIELD® 2700 Discharge Shielding LENGTH OTHER Testing Method Moisture Vapor Transmission Rate (MVTR) < 0.030 grams/100 sq. in./24 hrs MIL-STD-3010C Method 3030 Tensile Strength 6550 PSI, 45 MPa ASTM D882 Puncture Resistance 30 lbs, 133 N MIL-STD-3010 Method 2065 Seal Strength 20 lbs, 89 N ASTM D882 Thickness 7 mils, 0.007" ±10% MIL-STD-3010 Method 1003 Marking Adhesion Pass IPC-TM-650 2.4.1 Electrical Typical Value Testing Method ESD Shielding
D27430 价格&库存
很抱歉,暂时无法提供与“D27430”相匹配的价格&库存,您可以联系我们找货
