D3413.12510.875
D3413.12510.875
    SCS
    BAGMOISTBARIN10.875X13.125
D3413.12510.875 数据手册
Moisture Barrier Bag Dri-Shield® 3400 This foil moisture barrier bag is designed to provide protection for ESD sensitive and moisture sensitive electronics, typically SMT (Surface Mount Technology) items. Best practice is to use with Desiccant and a Humidity Indicator Card. The bags are heat sealable and suitable for vacuum packaging. Bags are printed with ESD protective and moisture sensitive warning symbols, and a lot code for traceability. Meets ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, Static Control Bag ANSI/ESD S11.4 Level 1, and IPC/JEDEC J-STD-033. Physical Typical Value Testing Method Moisture Vapor Transmission Rate (MVTR) < 0.0003 grams/100 sq. in./24 hrs < 0.002 grams/100 sq. in./24 hrs ASTM F1249 ASTM F392 condition E and ASTM F2149 Tensile Strength 6000 PSI, 41 MPa ASTM D882 Puncture Resistance 20 lbs, 88 N MIL-STD-3010 Method 2065 15 lbs, 66 N ASTM D882 4 mils, 0.1016 mm +/-10% MIL-STD-3010 Method 1003 SCS Moisture Barrier Bags Dri-Shield® 3400 are manufactured from a Seal Strength laminate of polyester, foil, and polyethylene. The metal layer is intended Thickness to provide discharge shielding and to minimize the penetration of electric fields and electrostatic Opendischarges. Top Bag ZipTop Bag Marking Adhesion Tolerance: Width -0, +1/4" Length +/- 1/8" Offset 0 to 1/4" Seal width 3/8" with a tolerance of +/- 1/8" LO T 4 011 0 9 8 7 6 5 4 3 2 1 Note: Standard bag markings shown above are not to scale. Pass IPC-TM-650 2.4.1 Electrical Typical Value Testing Method ESD Shielding
D3413.12510.875
物料型号:Dri-Shield® 3400 器件简介:该铝箔防潮袋设计用于保护静电敏感和潮湿敏感的电子产品,特别是SMT(表面贴装技术)项目。建议与干燥剂和湿度指示卡一起使用。袋子可热封,适合真空包装。 引脚分配:文档中未提及引脚分配参数特性:包括水蒸气透过率(MVTR)小于0.0003克/100平方英寸/24小时,拉伸强度6000 PSI,穿刺抵抗力20磅,密封强度15磅,厚度4毫尔,标记粘附性通过测试。 功能详解:金属层旨在提供放电屏蔽,最小化电场和静电放电的渗透。袋子符合多个标准,包括ANSI/ESD S20.20、ANSI/ESD S541、ANSI/ESD S11.4 Level 1和IPC/JEDEC J-STD-033。 应用信息:产品仅用于商业用途,不包含在国防标准化计划的合格产品列表中。 封装信息:袋子由聚酯、铝箔和聚乙烯层压而成,袋子上印有静电放电保护和潮湿敏感警告符号以及用于可追溯性的批号。
D3413.12510.875 价格&库存
很抱歉,暂时无法提供与“D3413.12510.875”相匹配的价格&库存,您可以联系我们找货
