D30625
D30625
    SCS
    BAGMOISTUREBARRMTLIN25"X6"
D30625 数据手册
Moisture Barrier Bag Dri-Shield® 3000 This foil moisture barrier bag provides protection for ESD sensitive and moisture sensitive electronics, typically SMT (Surface Mount Technology) items. Best practice is to use with Desiccant and a Humidity Indicator Card. A nylon layer helps to strengthen the bag. The bags are heat sealable and suitable for vacuum packaging. Bags are printed with ESD protective and moisture sensitive warning symbols, and a lot code for traceability. SCS Moisture Barrier Bags Dri-Shield® 3000 are manufactured from a laminate of nylon, foil, and polyethylene. The metal layer provides discharge shielding and minimizes the penetration of electric fields and electrostatic discharges. OPENING OFFSET Moisture Barrier Bag DRI-SHIELD® 3000 ** Bags are printed (hot stamp or thermal) with an ESD protective symbol and a lot code for traceability. ** Discharge Shielding LENGTH SEAL 7 11 OTHER PA/ALU/PE ATTENTION: Contents may be Moisture and Static Sensitive LOT 40910987654321 Tolerance: Width -0, +1/4" Length +/- 1/8" Offset 0 to 1/4" Seal width 3/8" with a tolerance of +/- 1/8" Note: Standard bag markings shown above are not to scale. FOLD SEAL WIDTH WIDTH STATIC DISSIPATIVE NYLON FOIL SHIELD STATIC DISSIPATIVE POLYETHYLENE SCS Moisture Barrier Bags are packaged in a polyethylene bag. RoHS, REACH, and Conflict Minerals Statement See the SCS RoHS, REACH, and Conflict Minerals Statement: http://staticcontrol.com/PDF/Regulatory_Statement_SCS_Bags.pdf See the SCS Limited Warranty: StaticControl.DescoIndustries.com/Limited-Warranty.aspx Meets ANSI/ESD S20.20, Packaging standard ANSI/ESD S541, Static Control Bag ANSI/ESD S11.4 Level 1, and IPC/JEDEC J-STD-033. Physical Typical Value Moisture Vapor Transmission Rate (MVTR) < 0.0003 grams/100 sq. in./24 hrs ASTM F1249 < 0.002 grams/100 sq. in./24hrs ASTM F392 condition E and ASTM F1249 Tensile Strength 3800 PSI, 26 MPa ASTM D882 Puncture Resistance 16 lbs, 71 N MIL-STD-3010C Method 2065 Seal Strength 15 lbs, 66 N ASTM D882 Thickness 6 mils, 0.006" +/-10% MIL-STD-3010C Method 1003 Marking Adhesion Pass IPC-TM-650 2.4.1 Electrical Typical Value Testing Method ESD Shielding
D30625
物料型号:Dri-Shield® 3000
器件简介:Dri-Shield® 3000 是一种防潮袋,用于保护静电敏感和潮湿敏感的电子产品,特别是表面贴装技术(SMT)部件。
建议与干燥剂和湿度指示卡一起使用。
袋子由尼龙层加固,可热封,适合真空包装。
袋子上印有防静电和潮湿敏感警告符号以及用于追溯的批号。
引脚分配:文档中未提及。
参数特性: - 材料:尼龙、箔、聚乙烯层压材料 - 尺寸公差:宽度±1/4英寸,长度±1/8英寸,偏移0至1/4英寸 - 密封宽度:3/8英寸,公差±1/8英寸 - 表面电阻:内部1x10^3至<1x10^4欧姆,外部1x10^3至<1x10^4欧姆 - ESD屏蔽效能:<10纳焦 - EMI衰减:45分贝(1至10吉赫)
功能详解:金属层提供放电屏蔽,最小化电场和静电放电的穿透。
袋子可保护电子产品免受潮湿和静电损害。
应用信息:用于电子产品的防潮和防静电包装,特别是SMT部件。
封装信息:袋子由尼龙、箔和聚乙烯制成,可热封,适合真空包装。
此外,Dri-Shield® 3000 符合ANSI/ESD S20.20、ANSI/ESD S541、ANSI/ESD S11.4 Level 1和IPC/JEDEC J-STD-033标准。
产品仅供商业用途,不在美国国防标准化计划的合格产品列表上。
产品不含胺、硅酮和重金属。
产品规格和程序如有变更,恕不另行通知。
D30625 价格&库存
很抱歉,暂时无法提供与“D30625”相匹配的价格&库存,您可以联系我们找货
