Specifications:
Date & Lot Code
Printed for QC
Traceablility
Weld
Seal
Side Weld Seals 3/8 in. (±0.10)
Soft Fold Bottom
** Bags are printed (hot stamp or thermal) with an ESD
protective symbol and a lot code for traceability. **
Low Charging Static
Dissipative Proprietary
Outer Polyester Layer
Aluminum Shielding Layer
Low Charging Static
Dissipative Proprietary Inner
Polyethylene Layer
Mixed Unsortable Plastic Scrap
7
Mixed unsortable plastic scrap shall contain assorted
plastics of multiple grades that are co-extruded,
bonded or laminated together which are unsortable
into individual grades.
Protektive Pak bags are recyclable
Statshield® bags are packaged 100 per package in an oversized shielding bag.
See Shielding Bag Storage at TB-7057.
STATSHIELD® METAL-IN SERIES
Standard Document
ANSI/ESD S541 (ANSI/ESD S20.20)
ANSI/ESD S11.4
Electrical Properties
Surface Resistance:
Outer Surface
Inner Surface
Discharge Shielding
Charge Generation
Capacitance Probe (to dissipate 1 KV)
Typical Values
Meets Requirements of:
ESD Protective Packaging
Level 3 Technical Requirements
Test Procedures/Method
1 x 104 to < 1 x 1011 ohms
10 lbs/in
375°F, 1/2 sec 60 psi
4600 PSI, 32 MPa
ASTM 882
>10 lbs
MIL-STD-3010, 2065
Pass
MIL-STD-3010, M3005
Not detected
ASTM E168
Pass
IPC-TM-650 2.4.1
Chemical Properties
Corrosion
No effect on aluminum, copper, silver, Sn-Pb coated foil,
stainless steel, low carbon steel
ANSI/ESD S541 Section 6.2 Outside an EPA
“Transportation of sensitive products outside of an EPA shall require packaging that provides:
1. Low charge generation
2. Dissipative or conductive materials for intimate contact
3. A structure that provides electrostatic discharge shielding.”
RoHS, REACH and Conflict Minerals Statement
See the Desco Industries RoHS, REACH, and Conflict Minerals Statement:
Regulatory_Statement_Statshield_Bags.pdf
See Protektive Pak’s Limited Warranty:
ProtektivePak.com/Limted-Warranty
Statshield® and Statfree® are Registered Trademarks of Desco Industries Inc.
See Bag Selection Chart Click HERE.
STATSHIELD® BAG, SHIELDING, METAL-IN, 0.0030" (0.0762mm)
PROTEKTIVE PAK
13250 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578
ProtektivePak.com
© 2021 DESCO INDUSTRIES INC
Employee Owned
Made in the
United States of America
Specifications and procedures subject to change without notice.
DRAWING NUMBER
48700
DATE:
September
2021
很抱歉,暂时无法提供与“48691”相匹配的价格&库存,您可以联系我们找货
