2101014
2101014
    SCS
    SHIELD BAG 10X14" MTL-OUT 100PK
2101014 数据手册
Metal-Out Static Shielding Bag 2100R/2110R The transparent, puncture resistant metal-out static shielding bag is designed to provide static safe packaging for the shipment and/or storage of ESD sensitive items including outside ESD protected areas. The metal layer is positioned near the outer surface to help reduce voltage retention and enhance static decay. Bags are printed with an ESD protective symbol and a lot code for traceability. Open Top (2100R) and ZipTop (2110R) styles are available. The bags are heat sealable. SCS Static Shielding Bags are manufactured from a top coat, metal, polyester, polyethylene laminate. The proprietary top coating is designed to protect the metal layer. Polyester dielectric, in concert with the metal layer, provides shielding of Electrostatic Discharge (ESD) to minimize the penetration of electric fields and discharges. Bag OpenOpen TopTop Bag ZipTopBag Bag ZipTop Meets ANSI/ESD S20.20, Packaging Standard ANSI/ESD S541, and Static Control Bag ANSI/ESD S11.4 Level 3 Physical Typical Value Testing Method Tensile Strength 8000 PSI, 55 MPa ASTM D882 Puncture Resistance 24 lbs, 106 N MIL-STD-3010C Method 2065 Seal Strength 18 lbs, 80 N ASTM D882 Thickness 3.2 mils, 0.081 mm ± 10% MIL-STD-3010C Method 1003 Marking Adhesion Pass IPC-TM-650 2.4.1 Transparency 37% Tobias Electrical Typical Value Testing Method ESD Shielding
2101014 价格&库存
很抱歉,暂时无法提供与“2101014”相匹配的价格&库存,您可以联系我们找货
