Metal-Out Static Shielding Bag 2100R/2110R
The transparent, puncture resistant metal-out static shielding bag is
designed to provide static safe packaging for the shipment and/or
storage of ESD sensitive items including outside ESD protected areas.
The metal layer is positioned near the outer surface to help reduce
voltage retention and enhance static decay. Bags are printed with an
ESD protective symbol and a lot code for traceability. Open Top (2100R)
and ZipTop (2110R) styles are available. The bags are heat sealable.
SCS Static Shielding Bags are manufactured from a top coat, metal,
polyester, polyethylene laminate. The proprietary top coating is
designed to protect the metal layer. Polyester dielectric, in concert with
the metal layer, provides shielding of Electrostatic Discharge (ESD) to
minimize the penetration of electric fields and discharges.
Bag
OpenOpen
TopTop
Bag
ZipTopBag
Bag
ZipTop
Meets ANSI/ESD S20.20, Packaging Standard ANSI/ESD S541, and
Static Control Bag ANSI/ESD S11.4 Level 3
Physical
Typical Value
Testing Method
Tensile Strength
8000 PSI, 55 MPa
ASTM D882
Puncture Resistance
24 lbs, 106 N
MIL-STD-3010C Method 2065
Seal Strength
18 lbs, 80 N
ASTM D882
Thickness
3.2 mils, 0.081 mm ± 10%
MIL-STD-3010C Method 1003
Marking Adhesion
Pass
IPC-TM-650 2.4.1
Transparency
37%
Tobias
Electrical
Typical Value
Testing Method
ESD Shielding
很抱歉,暂时无法提供与“21135”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+210.2036410+27.21268
