48514
48514
    DESCO
    BAG 8300 METAL OUT 3MIL 14X18
48514 数据手册
RICHMOND 8300 SERIES Specifications: Electrical Properties Surface Resistance:   Outer Surface   Aluminum Layer   Inner Surface Typical Values Test Procedures/Method 30 cycles Sutherland Abr. (.0000 Steel Wool) Outgassing Pass ASTM E595 Non-corrosive Pass MIL-STD-3010, M3005 Side Weld Seals 3/8 in. Item No. Size (in.) W x L Item No. Size (in.) WxL 48500 4 x 4 48509 10 x 14 48501 4 x 6 48510 11 x 15 48502 5 x 8 48511 12 x 16 48503 6 x 8 48512 12 x 18 48504 6 x 10 48513 14 x 16 48505 8 x 8 48514 14 x 18 48506 8 x 10 48515 14 x 24 48507 8 x 12 48516 18 x 24 48508 10 x 12 Packaged 100 per package Chemical Properties Corrosion Polycarbonate Capability, No Amines N-Octanoic Acid No effect on aluminum, copper, silver, Sn-Pb coated foil, stainless steel, low carbon steel High Performance Yes Static Dissipative Not present Abrasion Resistant Coating Mixed Unsortable Plastic Scrap 7 Mixed unsortable plastic scrap shall contain assorted plastics of multiple grades that are co-extruded, bonded or laminated together which are unsortable into individual grades. Protektive Pak’s bags are recyclable Employee Owned Polyester Layer Static Dissipative Inner Polyethylene Layer A fundamental ESD control principle (see ANSI/ESD S20.20 Foreword): ESD susceptible items should be transported and stored outside an Electrostatic protected Area enclosed in low charging, static shielding protective packaging. The bag’s material meets the performance specification requirements of ANSI/ESD S541. Bag is free of amines, N-octanoic acid, and heavy metals. Made in the United States of America RICHMOND 8300, TRANSPARENT STATIC SHIELDING BAG (METAL OUT) PROTEKTIVE PAK 13520 MONTE VISTA AVENUE, CHINO, CA 91710 PHONE (909) 627-2578, FAX (909) 363-7331 www.ProtektivePak.com © 2012 DESCO INDUSTRIES INC. Aluminum Shielding Layer DRAWING NUMBER 48500 DATE: December 2012
48514 价格&库存
很抱歉,暂时无法提供与“48514”相匹配的价格&库存,您可以联系我们找货
