BAG, LOW CHARGING PINK POLY
Transparent light pink, low density polyethylene bags have low charging (antistatic) properties.
N
LE
Specifications:
H
GT
Electrical Properties
TH
WID
Static Decay:
Surface Resistance:
Polycarbonate Haze:
Corrosivity Observations:
Physical Properties
Typical Value
ASTM 101 Method 4046
ANSI/ESD STM11.11
72 hr contact
MIL-STD-3010, M3005
4.0mils (0.004", 0.1016mm), +/- 10%
0.050 gm/ 10 min
0.923 gm/cc
230 gms
MD 24,000 psi
MD 25,000 psi
ASTM D-1283
ASTM D-1505
ASTM D-1709
ASTM D-1894 (unmodified film)
ASTM D-882
49100
2" x 3"
49101
3" x 4"
Material Thickness:
Melt Index:
Density:
Dart Impact:
Coefficient of Friction:
1% Secant Modulus (Stiffness):
49102
3" x 5"
*Pink Poly bags should be used within a timely manner and should not be reused as the ESD properties will negate over time*
49103
4" x 6"
49106
6" x 8"
49108
6" x 10"
49109
8" x 10"
49110
8" x 12"
49111
10" x 12"
49112
10" x 14"
49114
12" x 16"
49116
15" x 18"
49119
18" x 24"
Item No. Size W x L
Packaged 100 per pack
Dimensional tolerances unless otherwise specified:
L: +/- 0.250" / W: +/- 0.250"
RoHS, REACH and Conflict Minerals Statement
See the Desco Industries RoHS, Reach and Conflict Minerals Statement:
Descoindustries.com/ROHS3.aspx
See the Protektive Pak Limited Warranty:
Protektivepak.Descoindustries.com/Limited-Warranty.aspx
© 2019 DESCO INDUSTRIES INC
Made in the
United States of America
Specifications are subject to change without notice.
TRANSPARENT LOW CHARGING (PINK POLY) BAGS
PROTEKTIVE PAK
13520 MONTE VISTA AVENUE, CHINO, CA 91710
PHONE (909) 627-2578
ProtektivePak.com
Employee Owned
Test Procedures/Method
< 1.0 sec.
1 x 109 to < 1 x 1013 ohms
NE
NE
DRAWING
NUMBER
49100
DATE
February
2019
很抱歉,暂时无法提供与“49113”相匹配的价格&库存,您可以联系我们找货
