Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 3
MODEL: CEM-1606 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
FEATURES
• through hole
• 6 V rated
• externally driven
SPECIFICATIONS
parameter
conditions/description
Vo-p
rated voltage
operating voltage
current consumption
min
3.0
at rated voltage, 2,048 Hz square wave, ½ duty
at 10 cm (A-weight), rated voltage, 2,048 Hz square wave,
½ duty
coil resistance
dimensions
max
6.0
0V
rated frequency
sound pressure level
typ
Vo-p
12.0
Vo-p
50
mA
2,048
Hz
85
96
dBA
43.0
50.0
57.0
Ø16.0 x 14.0
4.6
PPO
terminal
pin type (Au plating)
Ω
mm
weight
material
units
g
operating temperature
-20
60
°C
storage temperature
-30
70
°C
max
units
380
°C
washable
yes
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
hand soldering
2
Notes:
min
for maximum 2 seconds
330
2. Not recommended for wave soldering
cuidevices.com
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CEM-1606 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
14.0 0.551
3.2 0.126
sound emission hole
7.0 0.276
0.7 0.028
0.1 (2 PLCS)
16.0 0.630
7.6 0.299
14.0 0.551
masking label
3.3 0.130
5.5 0.217
FREQUENCY RESPONSE CURVE
100
90
dB
80
70
60
50
APPLICATION CIRCUIT
Hz
2K
+VDC
+2.5V
0V
TR: 2SC1741AS or EQV
Vin
180Ω
cuidevices.com
20K
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
09/11/2006
1.01
brand update
01/06/2020
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CEM-1606”相匹配的价格&库存,您可以联系我们找货
